Ignition tumbler
Discussion in '3rd Gen 4Runners (1996-2002)' started by Carolshe, Jun 19, 2023.
  1. Jun 19, 2023 at 4:38 PM
    Carolshe
    Carolshe [OP] New Member
    Ohio
    1996 4 Runner
    I have a 1996 4 runner and about 8 months ago I replaced the ignition tumbler because I was having trouble turning the key to start the car. Now I'm having trouble with the key getting stuck and not being able to remove it after I shut the car off. This is an intermittent problem. Do I need to replace tumbler again or can this be caused by something else? Any thoughts would be appreciated!
  2. Jun 19, 2023 at 6:09 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Is it a new tumbler + new key, or new tumbler + old key?
  3. Jun 19, 2023 at 6:14 PM
    Mine did same thing I sprayed a can of WD-40 in the key hole didn’t seem to affect it. Had a new key cut by the dealership and working perfect still.
  4. Jun 19, 2023 at 6:17 PM
    Oakboro, N.C
    You may want to try some graphite to see if that would help.
  5. Jun 21, 2023 at 3:02 PM
    Carolshe
    Ohio
    1996 4 Runner
    It was a new tumbler and key. I'll try the graphite, thanks.
  6. Jun 21, 2023 at 6:14 PM
    backpacker
    2023 TRD ORP
    Bummer, I don't have any good suggestions for that scenario. I hope the graphite helps. I'd inform whoever did them of the situation and perhaps get the tumbler and key remade.
  7. Jun 21, 2023 at 6:59 PM
    Did you buy a Toyota OEM ignition switch? If not, that's probably the problem. Non OEM parts are just bad quality.
    PhantomTweak likes this.
