Ignition system issue
Discussion in '2nd Gen 4Runners (1990-1995)' started by Mayor, Mar 16, 2019.
  1. Mar 16, 2019 at 1:52 PM
    Mayor
    Mayor [OP] New Member
    JAMIESON
    95 automatic by 210k
    Lifted
    Hi I just went to locksmith with my passenger side lock cylinder for him to get me a new key. Been driving using screwdriver in ignition switch with ignition key cylinder removed. No problem until I went to leave the shop. Now though I can engage just as well as always to turn ign switch, car nor accessories would get powered. I had to grab a little speaker wire and jumper the switch from back side of switch. Drove home got new switch. Replaced and look like I didn't do a thorough job testing because new switch h did not solve issue. Thought it might be neutral safety switch gone or some switch. Shoot trying to upload photo
  2. Apr 18, 2019 at 11:44 PM
    Nowhereman317
    Nowhereman317 New Member
    Jeremy
    Indiana
    94 4Runner 3.0 4WD MT 250K
    Stock just trying to keep her going 250K and counting
    Mine was having problems no lights, or power at all like key wasn’t even in it. Changed the ignition switch and got power back but no start. No signal to starter solenoid. Found an old anti theft device wired in there that had quit passing the signal to starter. It worked just fine before. Never knew it was there, although I always wondered what that black box was. Anyway I know some of those things can be wired in other ways. Got any mystery boxes on your firewall?
  3. Apr 19, 2019 at 1:11 PM
    Mayor
    JAMIESON
    Lifted
    Alright, it's still kinda acting up I gotta turn the screwdriver just right and then it crank. I'm gonna cal I'll it good for it. Still got to figure out my no spark issue in different forum
  4. Apr 19, 2019 at 7:20 PM
    Nowhereman317
    Jeremy
    Indiana
    Engine ground wires maybe. I’ve noticed someone replaced them on mine. I’m assuming they had an issue or they wouldn’t have bothered beefing them up. Judging from the amount of other obvious issues never addressed. The factory one on the drivers side was all ate up from the oil leaks breaking down the wire housing.
