I think i over filled my oil ?
Discussion in '5th Gen 4Runners (2010-2024)' started by danep89, Dec 9, 2024.
  1. Dec 9, 2024 at 10:02 AM
    danep89
    danep89 [OP] New Member
    Dane
    2021 TRD Off-Road
    Eibach stage 2r, JBA Upper control arms, BFG ko3 285 70 r17
    So, I changed my oil last night and I know the 2021 4runner calls for about 6.6 quarts of oil. So I purchased 7 quarts of Amsoil 0w -20 and proceeded to change my oil . I drove around for about 10 minutes prior to changing the oil to put some heat into the engine. I drained all of the oil with the drain plug and let it drip out for about 5 minutes then drained the oil filter and replaced it with a new filter. I then added 6 quarts of oil then i started the truck and let it run then i checked the oil level with the dipstick. I was about halfway between the indication marks on the dip stick. I then added an additional half quart of oil and repeated the process. when checking the dip stick after adding the additional half quart of oil i was then above the full marks on the dipstick by about 3/8".
    I'm wondering if i should try to drain some of the oil out using the oil filter drain tool and a small ball valve or if i should just leave the oil in the truck. I know adding too much oil can cause a long list of issues with the motor but i am unsure how much an extra half quart of oil is really going to effect the motor.
    If anyone has experience doing this please help !
  2. Dec 9, 2024 at 10:10 AM
    Over filling your engine can cause major issues. Drain a small amount out first, check the dip stick, and repeat until you're just below the "full" marking on your dipstick.
  3. Dec 9, 2024 at 10:10 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Extra half quart isn't going to hurt anything.
    All good
    java likes this.
  4. Dec 9, 2024 at 10:15 AM
    1SilverRunner
    Tejas
  5. Dec 9, 2024 at 10:20 AM
    icebear Recovered Kia Owner
    If you drained it as you said and put in 6.5 qt, I'd be hard pressed to think you overfilled it. did you let the engine sit for a few after shutting off before checking the dipstick? I'd check again hot, cold (this technically isn't proper) and see what they say.
    Guppy1301 and danep89[OP] like this.
  6. Dec 9, 2024 at 10:27 AM
    danep89
    Dane
    2021 TRD Off-Road
    I just checked it cold this morning after it sat for about 3 hours and it was showing about 3/8" past the full mark on the dipstick. I don't think I am extremely overfilled but obviously I would want it to be perfect. Has anyone else had this happen before ?
  7. Dec 9, 2024 at 10:46 AM
    Guppy1301
    Guppy1301 New Member
    Silver 2019 TRD ORP
    How do you know your dipstick isn't off? Drain hot and check cold. If you put 6.5 qts in you are good!
  8. Dec 9, 2024 at 10:47 AM
    Hmm, I'm wondering where the discrepancy is coming from.
    What I can think of is:
    • Vehicle isn't level when measuring
    • Error when filling (but it's easy to see if you have half a quart left over)
    • Not drained enough (but it dripped)
    • Oil filter not changed (but it was)
    • Are you cleaning dipstick before checking?
  9. Dec 9, 2024 at 10:49 AM
    "Perfect" and the shitty 1GR dipstick design are mutually exclusive. I just put in the 6.6 qt and move on. Fool's errand trying to be any more precise with this dipstick design.
  10. Dec 9, 2024 at 11:03 AM
    danep89
    Dane
    2021 TRD Off-Road
    Yes I am cleaning the dip stick before checking it.
  11. Dec 9, 2024 at 11:25 AM
    Buckaroo
    Buckaroo New Member
    2005 Ltd T4R 4WD V6
    A little over full won't likely hurt anything but I do go by the dipstick, not the stated capacity. Just easier to keep track of usage. After I change the oil & filter, I fill it close to the full line, start the engine and check for leaks. Then I shut it off and fill it to the line.
    danep89[OP] likes this.
  12. Dec 9, 2024 at 12:29 PM
    ....and now we'll discuss HOW OFTEN do you change the oil?
    :crapstorm::devil:
  13. Dec 9, 2024 at 12:37 PM
    Blue 4ever Runner
    Blue 4ever Runner New Member
    2019 Blue 4Runner
  14. Dec 9, 2024 at 12:48 PM
    java
    java fauxrunner
    2023 ORP ice cap
    I do not check until the next morning, and even thrn I only get one shot, 4Runner dipstick sucks.
    Just put in 6.6qt, check for leaks and call it a day.
  15. Dec 9, 2024 at 7:18 PM
    Professional Toyota drivers (i.e. taxis) log operating hours :stirthepot:
    java likes this.
