I need Mud flaps for pro that don’t melt!
Discussion in '5th Gen 4Runners (2010-2024)' started by ProtoJ, Aug 4, 2021.
  1. Aug 4, 2021 at 8:31 PM
    ProtoJ
    ProtoJ [OP] New Member
    The stock mud flaps were not keeping the rocks from chipping the rear doors so I upgraded to Rokblokz….and they provide awesome coverage. But the passenger rear melted. Do Rekgens withstand exhaust 7D193B1D-8DEA-4DCF-A4FA-ED85C0E9F65C.jpg heat better?
  2. Aug 4, 2021 at 8:52 PM
    Is that the TRD exhaust? Seems like a design flaw to have it exit right on the mudflap.
  3. Aug 4, 2021 at 8:55 PM
    ProtoJ
    It is the TRD exhaust….it didn’t melt the stock though. Tundras exit out the side as well.
  4. Aug 4, 2021 at 10:31 PM
    How do the rear mud flaps protect the rear passenger doors?
    I'd put the stock ones back on.
  5. Aug 5, 2021 at 4:19 AM
    ProtoJ
    Well they don’t….that is why I think I’m going to leave the front rokblokz on and use factory rear. Unless anyone knows if Rekgens won’t melt. I drive a lot of dirt roads and the 4 runner paint is taking a beating.
  6. Aug 5, 2021 at 5:44 AM
    DaRunna
    DaRunna New Member
    SE Mi
    2021 Venture
    How do the front rockblokz look? Imagine they work good? My tires keep stones and like to discharge them at 60+ mph!
  7. Aug 5, 2021 at 6:11 AM
    olliechristoper
    olliechristoper New Member
    Chris
    That's what I was thinking. I thought all of the exhausts exited out the back? Do all the TRD 4Runners exit out the side?
    I imagine the reason it melted your new flap is because it's wider than the OEM. How about calling RokBloks and asking them for a replacement flap and explain the situation to them?
    Don't feel too bad. OEM off the floor KTM enduros have an exhaust that melts off the turn signal within the first few miles of riding.
    Toy4X4 and Thatbassguy[QUOTED] like this.
  8. Aug 5, 2021 at 6:19 AM
    ProtoJ
  9. Aug 5, 2021 at 6:21 AM
    ProtoJ
    The fronts are perfect….wider, longer, have a cut out around the body mount.
  10. Aug 5, 2021 at 6:57 AM
    olliechristoper
    Chris
    OK I have an idea that will solve your issue and look really cool!! Remove the flap, get a heat gun and flatten the bubble (or trim it out). Then cut two pieces of thin aluminum sheet and sandwich them with small panned bolts/cap nuts or rivets. It will look clean if you file carefully. I also use a 60 grit wheel on drill bit or Scotchbrite to roughen it up. Before you cut your aluminum make a cardboard pattern that forms perfectly to the shape of the flap. You only need to make it large enough to cover the melted area with just a bit of overlap.
    Here is something similar I did recently when making a mount for my dual battery components:
  11. Aug 5, 2021 at 7:12 AM
    olliechristoper
    Chris
    Something like this. I'm not very good at freehand but you get the idea. You want to make are there are no sharp edges. This way the polymers integrity will stay intact. After zooming in on your pic this bubble will be very easy to just flatten out with a hammer or pressed out with a block of wood and heat gun.
  12. Aug 5, 2021 at 7:20 AM
    ProtoJ
    I am surprised they don’t make a heat shield type of thing like this for their product. Also interesting that the stock ones don’t melt….this is maybe 1/2” wider I’m guessing.
  13. Aug 5, 2021 at 8:36 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    I'd be interested to hear what RokBlokz says but I'm not sure there is much they will do as their website specifically says these are not for the side exhaust vehicles.
    FITMENT: Each RokBlokz mud flap set for the 2014-2020 Toyota 4Runner comes with 4 flaps, necessary mounting brackets, stainless steel mounting hardware, and instructions to fit factory hole locations for the 2014-2018 Toyota 4Runner. Fits SR5, Trail, SR5 Premium, and Trail Premium trim packages. (This kit does not currently work with the side exit exhaust on the TRD Pro, TRD Off Road, and TRD Off Road Premium.)
    Good looking mud flaps though. As yours the standard or XL size?
  14. Aug 5, 2021 at 8:38 AM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    How come Toyota can make plastic that doesn’t melt in close proximity to the exhaust tip, which includes both the back bumper and the back mudflap, but these “racing experts” can’t?
    Toy4X4 and jasonmcelroy like this.
  15. Aug 5, 2021 at 8:43 AM
    BgBmBoo
    BgBmBoo New Member
    Kansas
    Good question. They also list "Won't crack or warp from temperature extremes" in their description so hopefully they will warranty the part.
  16. Aug 5, 2021 at 8:50 AM
    ProtoJ
    Standard
  17. Aug 5, 2021 at 8:59 AM
    olliechristoper
    Chris
    If you compare the Factory to the aftermarket it's much narrower and the exhaust heat does not hit it.
  18. Aug 6, 2021 at 10:06 AM
    ProtoJ
    I reached out to RokBlokz and they do plan on making a higher temp rated model at some point…..no time frame yet. They will give me a discount on a set of rears when they come out. I also contacted RekGen and they will not be making a high temp rated one at this time.
  19. Aug 6, 2021 at 3:49 PM
    olliechristoper
    Chris
    So I think the aluminum sandwich might be your best option. It won't be symmetrical but I believe it will still look nice. Remember you can see only one side of the vehicle at a time....
  20. Aug 8, 2021 at 5:17 AM
    ProtoJ
    except since I took this picture the other day it’s melted and warped about 50% of the mud flap! Since it’s still functional, I’ll leave it on until it’s looks really bad! Then I’ll put the factory rears back on. At least the fronts will keep the chipping down.
  21. Aug 8, 2021 at 6:37 AM
    olliechristoper
    Chris
    That will be a good compromise.
