HVAC fan flutter
Discussion in '5th Gen 4Runners (2010-2024)' started by banjos-n-beer, Jan 14, 2022.
  1. Jan 14, 2022 at 2:10 PM
    banjos-n-beer
    banjos-n-beer [OP] New Member
    Steve
    Maine
    2018 Pro
    My fan has always had a very faint flutter, but it’s never really bothered me. On a recent couple of sub freezing mornings it started chirping at low speeds (most obvious at notch 3). Still not a big deal, but a quick google search proves it’s a common issue (bad bearings). I’ll inspect the cabin filter and see if there is any debris in the fan, before deciding if dropping it is necessary.
    For those of you that have replaced the fan, did you go OEM or aftermarket? I’m leaning aftermarket if these things are that fragile.
    Thx!
    CameramanA73 and Thatbassguy like this.
  2. Jan 14, 2022 at 3:27 PM
    MNT_GOAT
    MNT_GOAT New Member
    2021 4Runner TRD Off Road Premium
    It is kind of a whizzing or light whistling sound? My 2021 does that as well and has always bothered me a little. Mine is also most noticeable on speed three.
  3. Jan 14, 2022 at 3:40 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    I guess it could be described as such. YouTube comments reinforce this issue is rather common.
  4. Jan 14, 2022 at 3:58 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    It’s like a $140 part and it takes like 10 minutes to replace.
    I would clean it thoroughly before you do.
    banjos-n-beer[OP] likes this.
  5. Jan 15, 2022 at 6:35 AM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    I'll check the cabin air filter and look for debris down in the fan. If it requires removal for cleaning I won't do it until the weather warms up this spring. $140 sounds about right from my research if it ultimately needs replacing.
  6. Jan 15, 2022 at 1:42 PM
    Matt83
    Matt83 New Member
    Northeast
    Cabin air filter wont fix it. My fan has always been noisy. No chirping though, normally that indicates bad motor bearings in the fan.
  7. Jan 15, 2022 at 4:37 PM
    banjos-n-beer
    Steve
    Maine
    2018 Pro
    Yeah, I only meant I’d inspect the cabin air filter because you have to remove it to look at the fan/motor from above.
  8. Jan 16, 2022 at 9:07 AM
    CameramanA73
    CameramanA73 New Member
    White TRD Pro 4R
    my 2019 has always had a weird sound on anything above low... fluttering... id describe it as... Ive always wondered if a thicker cabin filter would solve this...
  9. Jan 18, 2022 at 5:55 PM
    MAXIM
    MAXIM New Member
    I replaced my noisy fan with new OEM Toyota one and it is not as loud but still is noisy. Save your $140 and turn up the music.
    Slopemaster likes this.
  10. Jan 18, 2022 at 5:57 PM
    MAXIM
    MAXIM New Member
    Also, there is no bearing but rather a direct drive motor/fan assembly.
  11. Jan 18, 2022 at 6:01 PM
    My fan flutters some at low speed too, but I figured it’s normal since there are so many people noticing it.
  12. Jan 18, 2022 at 6:25 PM
    BourbonNcigars
    BourbonNcigars New Member
    When I run my heater it sounds like a little leaf is flapping down in the dash somewhere. Fairly faint and very fast. Maybe I should first check for a leaf...
