Hum after lift
Discussion in '5th Gen 4Runners (2010-2024)' started by PHX4RnR, Jun 2, 2023.
  1. Jun 2, 2023 at 12:09 AM
    PHX4RnR
    PHX4RnR [OP] New Member
    2021 SR5
    Hey Gang!
    I just had a 3” Ready lift installed and now have a strange hum from about 35 mph to 55???
    WTF???
  2. Jun 2, 2023 at 12:47 AM
    Mtbpsych
    Mtbpsych New Member
    I would be saying the same thing!
  3. Jun 2, 2023 at 2:12 AM
    Matt83
    Matt83 New Member
    Northeast
    Right back to the shop who installed it.
  4. Jun 2, 2023 at 5:35 AM
    hvac guy
    hvac guy New Member
    If you have 4WD, does it go away while in 4WD? If it does then it would most likely be the front diff bearing, most people replace with the ECGS bushing
  5. Jun 2, 2023 at 6:49 AM
    ^^^That.
    At the same time, you have to expect that after raising the truck 3" (most recommend 2"), things can be be affected, as you are experiencing.
    Ripper238 and Thatbassguy like this.
  6. Jun 2, 2023 at 7:17 AM
    +1 for possible needle bearing. It's a known issue that affects a percentage of 4Runners. Lifting can trigger the issue.
    Like @hvac guy mentioned, get it on a straight section of road, at ~30 MPH, put it in 4HI and see if it stops. If it does, and returns when you shift back to 2wd, it's the needle bearing.
    3" is also starting to push it with CV angles.
    Did you get it aligned after the lift?
  7. Jun 2, 2023 at 9:38 AM
    I had the same 3/2 Readylift kit and didn’t experience any unusual noises as a result. Possibly as others have stated that the lift exasperated an existing problem with the needle bearing or maybe a pinion angle issue.
    On a side note, attached is a link to a thread I started last summer regarding issues I had with my Readylift spacer lift. I have since removed the lift kit.
    https://www.4runners.com/threads/shock’ing-discovery.26659/
  8. Jun 2, 2023 at 9:48 AM
    Yup, agree that it’s likely the needle bearing. Check to see if the noise goes away when you shifting to 4hi as mentioned above.
    Mine made the same noise intermittently ever since day 1 off the dealer lot, with stock suspension. Common issue. If the dealer replicates the problem under warrantee, their solution is to swap out the entire diff.
    Alternatively, the ECGS bushing is considered the only permanent solution. One thing to keep in mind though, don’t screw up the install on that. If you drive it in too deep, the diff has to be split to get the bushing out.
  9. Jun 2, 2023 at 11:10 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    What are you running for tires? Did you change them at the same time?
  10. Jun 2, 2023 at 1:18 PM
    PHX4RnR
    2021 SR5
    Thanks gang I’ll start the investigation!
  11. Jun 2, 2023 at 2:40 PM
    PHX4RnR
    2021 SR5
    Okay boys it goes away in 4hi.
    So forgive my ignorance and naivety, evidently I’ve more money than sense…
    Tell me more about the CV angle and solutions. Also is the needle bearing and ECGS bushing the same thing? Or do I need to do both?
    I’m on summer vacation with my 3 teenage daughters in route to Kansas City MO via Duck Creek UT, Jackson WY, Devils Tower WY, and The Badlands in SD. We just did Zion today with Bryce Canyon on for tomorrow. Is this something I should get fixed sooner than later? Can I run in 4Hi till KCMO?
  12. Jun 2, 2023 at 3:57 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    East Coast Gear Supply makes a bushing that replaces the needle bearing. They make a tool that can help. Check out YouTube for tutorials.
    The CV angles are probably too high - caused by the 3” lift. It will cause premature wear on the CVs and make for a harsh ride. Check out tinkeres adventure for great explanations of IFS and lifts
    Your trip sounds great!
    Cheers
  13. Jun 2, 2023 at 4:20 PM
    PHX4RnR
    2021 SR5
    Thanks Mike!
    Cheers!
  14. Jun 2, 2023 at 4:26 PM
    JETSPD1477
    JETSPD1477 New
    Typical 4Runner
    i wouldn’t call it critical but i’d do it sooner that later. don’t do 4H on pavement.
  15. Jun 2, 2023 at 4:36 PM
    PHX4RnR
    2021 SR5
    31s from the dealer. Shit tires: Ironman RB SUVs
