How useful are Maxtraxx Minis?
Discussion in 'General 4Runner Talk' started by java, Sep 11, 2024.
  1. Sep 11, 2024 at 9:21 AM
    java
    java [OP] fauxrunner
    2023 ORP ice cap
    So I impulse bought a pair of brand new Maxtrax Minis for 100$ on FB marketplace(180$ new). They are small enough to fit perfectly on my rack. I would not be able to accomodate the longer ones easily. Anyways, I got them for just in case scenarios where I would be throwing rocks abd branches under the tire, I mainly overland and dont get myself into too sticky situations. The seller told me they are good for ATVs, Maxtraxx says they could be used for SUVs too. Did I just buy useles(for my truck) plastic or could I get some use from them if things came to it.
    Thanks!
  2. Sep 11, 2024 at 11:39 AM
    icebear Recovered Kia Owner
    I’m sure they’ll be handy in some situation. (I’d also sooner believe Maxtrax’s website versus a semi-random person)
    java[OP] likes this.
  3. Sep 12, 2024 at 1:37 PM
    geojag
    geojag New Member
    2016 Black 4Runner Limited
    Stock for now.
    I could see them being enough to ramp you out of a hole is some situations. I don't have MaxTrax, but have Go-Treads. The main thing I use them for is leveling the vehicle, I bet you could use the MaxTrax for that.
    Trouble24, java[OP] and MeefZah like this.
  4. Sep 12, 2024 at 4:21 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    As they are only 25" long, I think they will be minimally useful. Normally traction boards allow you the opportunity to gain a little momentum, which is what you need when bogged. So, it's likely those will not be long enough to allow you to gain any speed. You'll have some wheel spin, and then the board will shoot down or back and you'll be without momentum or traction.
    I'd say they will cause at least $100 worth of frustration and grief when trying to use them off road. Meaning, a 25" Maxtraxx is more trouble than it is worth.
  5. Sep 27, 2024 at 8:58 AM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    Maybe to help build a base for a jack, or level the truck, light digging or ???
  6. Sep 27, 2024 at 5:38 PM
    Nhmountainman
    Nhmountainman New Member
    2024 TRD Pro Terra
    I have multiple sets and sizes…I feel they are very practical cause they are easier to stow in your vehicle and are handy to use with a set of full size, mix and match, save a few bucks
    Trouble24, Ironguy and java[OP] like this.
