How to replace window switch
Discussion in '5th Gen 4Runners (2010-2024)' started by BeachRunner33, Apr 23, 2024.
  1. Apr 23, 2024 at 5:29 PM
    BeachRunner33
    BeachRunner33 [OP] New Member
    2011 SR5
    Bilstein lift, Raceline wheels, Pioneer CarPlay radio with backup cam, AVS Visors, Husky floor mats.
    The master switch on my door for my driver side rear window will not work (the switch on the actual door does work). I tried the wait five seconds trick like you do after the battery dies and it didn’t work so I’m guessing the switch is shot. How do I replace it? Can I simply remove the black plastic plate around the switches or do I need to remove the door panel? I cannot find anything on the web about this. Thank you!
  2. Apr 23, 2024 at 5:55 PM
    More than likely, it's not the actual switch, perse. You probably have a dead fuse or the wire is faulty (or became ungrounded). So you may need to remove the door panel. But first, check your fuses!
  3. Apr 23, 2024 at 10:37 PM
    UncleShorty
    UncleShorty New Member
    If the fuse is blown you have another problem.
    Fuses just don't blow for the hell of it...
  4. Apr 24, 2024 at 5:11 AM
    Roadkill
    Roadkill New Member
    If it is a chafed wire then it would work intermittently. Does the switch feel normal. Usually if a switch goes bad it feels soft. I tend to agree with Borracho that it is probably a grounding issue in the harness or a broken wire and the only way to find it is follow the wires.
    BeachRunner33[OP] likes this.
  5. Apr 24, 2024 at 10:57 AM
    BeachRunner33
    2011 SR5
    Thanks guys. I will check the fuse first and then take the door panel off. The switch feels the same as the others. Where will the harness be located?
  6. Apr 25, 2024 at 5:19 AM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    You’ll need to remove the door panel to remove the switch assembly
  7. Apr 25, 2024 at 5:48 AM
    BeachRunner33
    2011 SR5
    Only problem I’m having is I can’t rule out the fuse because I can’t find the fuse panel. I know it’s supposed to be below the drivers side dash and I swear I don’t see a fuse panel anywhere. There is an airbag but no fuses.
  8. Apr 25, 2024 at 6:07 AM
    This video may help:
    The interior fuse panel can be hard to see. You have to contort your body. When I did it, I had to insert myself into the drivers footwell, upside down, then turn my head slightly to the right and up. Then, and only then, could I see it.
    It's a real mother fucker to find and get to. Toyota didn't make it easy.
  9. Jun 17, 2024 at 3:55 PM
    BeachRunner33
    2011 SR5
    Hi guys, sorry to drag you back into this but today I noticed that the window of the one that the master switch is not working, it actually opens and closes when the key isn’t even in the ignition and after the door has been opened and closed. This is not the case for any of the other windows. I was hoping this information would be helpful in diagnosing this problem. I checked the fuses and they are fine. Thanks!
