How to make add-on switches light up
Discussion in '5th Gen 4Runners (2010-2024)' started by Laguer2500, Feb 25, 2023.
  1. Feb 25, 2023 at 9:28 PM
    Laguer2500
    Laguer2500 [OP] New Member
    I haven't done much research lately, but had anybody discover how to make aftermarket switches light up when you turn on your headlights or Market lights? I don't want to go out of my way to make a whole form about it if it's been discovered, but I know how to do it the simple way I just don't want to go out of my way share the information if somebody else has already figured it out LOL. If that's not the case I can show you how to....let me know people I been holding back on making this post for over a year now
  2. Feb 25, 2023 at 9:33 PM
    Just tap into the illumination circuit.
  3. Feb 26, 2023 at 9:25 AM
    Wait — so you have some useful information to share, but you’re too lazy to post it and will only do so if someone else doesn’t step up? Don’t go out of your way, pal. What an inane post.
  4. Feb 26, 2023 at 12:10 PM
    Oakboro, N.C
    I second the above as a quick and easy requested way without creating a long form to follow.
    Welcome to the forum!
    Bob likes this.
  5. Feb 26, 2023 at 6:15 PM
    2020 4Runner
    2020 4Runner New Member
    Fl
    Probably talking about switches that are made for vehicle specific fitment such as AirOnBoard switches.
    Bob likes this.
  6. Feb 27, 2023 at 5:09 AM
    I'd love to hear where people are tapping into the illumination circuit. I added 2 OEM style switches for lighting, but skipped the backlight because I somehow got the impression that the other switches in the area used a switched ground for illumination.
    It sure seems odd to go out of your way to start a thread about a topic only to tell people that you don't want to go out of your way to start a thread about the topic. o_O
  7. Feb 27, 2023 at 7:27 AM
    According to the DrKDSS instructions:
    2010 to 2019: gray and green
    2020+: white and green
    OverRunner and Thatbassguy like this.
  8. Feb 27, 2023 at 7:37 AM
    Braumeister
    Braumeister Kampai, bitch!
    Bentley
    Northern MI
    2021 TRD Off-Road Premium
    For switch illumination I tapped into the TAIL fuse (tail lights) on the small cabin fuse panel; whenever my lights are on, my switches are illuminated.
    Power to the switch going to the relay comes from different fuse locations depending on the needs of the individual loads.
    Also used AirOnBoard switches—every other switch I tried jammed in the slot.
  9. Feb 27, 2023 at 7:46 AM
    Thank you! I got my switches from Caliraised, and one of them did get stuck a few times. It seems to have stopped doing it, though.
  10. Mar 31, 2023 at 10:39 AM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Thatbassguy if dash switches stick this is the trick
    7/8 OD, 3/4 ID, 1/16 thick rubber O ring
  11. Aug 30, 2023 at 4:47 PM
    dallas121469
    dallas121469 New Member
    Steve
    Blackfoot, Idaho
    2022 4Runner TRD OFF-ROAD
    None.
    Thanks. Worth a try.
    djwantke[QUOTED] likes this.
  12. Aug 30, 2023 at 4:50 PM
    Tis the solution
    dallas121469 likes this.
  13. Aug 30, 2023 at 7:16 PM
    Texrun50
    Texrun50 New Member
    2023 TRD ORP - Silver, Factory Off-Road Upgrade Package (black TRD wheels,sliders, etc.)
    None
    @Captain Spalding , your psychology worked yet again. The OP posted and then disappeared. You’re a magician!
    Captain Spalding likes this.
  14. Aug 30, 2023 at 8:53 PM
    Well I don’t usually spank ‘em on the first post but that just stuck in my craw.
    glwood54 and Texrun50[QUOTED] like this.
  15. Aug 30, 2023 at 11:19 PM
    I've been waiting for two years to make a post on how to...oh, never mind, people have probably already done it.
    Texrun50 and Captain Spalding like this.
