How to connect the Vantrue dash cam kit to a 2024 4Runner.
Discussion in '5th Gen 4Runners (2010-2024)' started by Juanramos, Oct 6, 2024.
  1. Oct 6, 2024 at 11:57 AM
    Juanramos
    Juanramos [OP] New Member
    Juan
    2024 Grey 4Runner
    Greetings. I bought a Vantrue dash cam with the Hardwire kit to leave it connected 24/7. How to connect the Vantrue dash cam kit to a 2024 4Runner. I am looking at the fuse panel layout but I cannot identify which one is for the 4Runner's internal lights and where in the box to connect the direct cable to the battery. Thanks for your help.https://www.amazon.com/dp/B083XB8T7T
  2. Oct 6, 2024 at 12:14 PM
    Pentangler
    Pentangler Happy Member
    There is a way to tap into the rear view mirror using a DIY harness. Perhaps someone more knowledgeable can chime in. Good luck.
    Juanramos[OP] likes this.
  3. Oct 6, 2024 at 12:35 PM
    You don't have to hard wire it, if you don't want to. Use this adapter: https://trailgridpro.com/products/d...W8twKTyoJlwzRv8dgPc-yV2vXI1uY6IaAiX2EALw_wcB/
    ...and tap directly into your rear view mirror. That is, if you have the HomeLink style rear view mirror. I know base model's don't have it. Yours probably does.
