How should I repair?
Discussion in '3rd Gen Builds (1996-2002)' started by SMILes, Feb 9, 2024.
  1. Feb 9, 2024 at 8:57 PM
    SMILes
    SMILes [OP] New Member
    When taking off the harness the plastic screw hold broke off. Now I was thinking of using strap ties but worry the heat from the valve cover will melt. Any ideas on what is a good way to repair?
  2. Feb 10, 2024 at 12:23 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    You should be able to find similar replacement at an auto part store, the valve cover doesn't get hot enough to melt most plastic type wire retainers.
  3. Feb 10, 2024 at 1:02 PM
    Oakboro, N.C
    With the limited movement of that harness assembly, Even if you do not find anything at the parts depot, You should be ok.
