How much to repair this '96 with a cylinder misfire?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Zachj27, Mar 4, 2025.
  1. Mar 4, 2025 at 6:47 PM
    Zachj27
    Zachj27 [OP] New Member
    Zach
    Hi everyone, one of my neighbors is selling a 1996 4Runner 2wd with 241xxx miles. They say it has a cylinder 6 misfire, and they are willing to sell it for under 2,000. Any advice?, thank you.
    It started up good and still runs and drives, recently had a timing belt change, new trd wheels and tires and a brake upgrade
    Any idea on how much it would cost to get repaired?
  2. Mar 4, 2025 at 6:50 PM
    NICE! Get it! I had a cylinder 3 misfire and it was an injector.
    Toy4X4 and Zachj27[OP] like this.
  3. Mar 4, 2025 at 7:01 PM
    blinktwice
    blinktwice New Member
    2000 4Runner Limited
    3" suspension lift 33" tires Magnaflow outlander exhaust
    I'd give the same advice as above. Mine was misfiring cylinder 4 and I got a used junkyard injector for 30$ CAD and it's been running flawlessly! Super easy to do it yourself I just watched a few YouTube videos and it took me an afternoon.
    I suggest doing the valve cover gasket while you have it off
  4. Mar 4, 2025 at 7:23 PM
    All depends on what’s needed. Diagnose it before you throw parts at it.
    Toy4X4 and icebear like this.
  5. Mar 4, 2025 at 7:41 PM
    BLKNBLU
    BLKNBLU New Member
    2019 Nautical Blue OR
    This^
    Check the plugs. At the very least, have a look at the number 6 plug. Take a pic of it while you have it out. Check the wires. Swap the 1 & 3 coil packs and see if the misfire moves. (to #4) Re-assess from there.
  6. Mar 4, 2025 at 11:34 PM
    Zachj27
    Zach
    To add on, he believes there might be a possible head gasket leak
  7. Mar 5, 2025 at 2:45 AM
    Welcome from Wisconsin! You should get these problems diagnosed by a pro mechanic and go from there. It was/is a good deal even with problems if the rest of the vehicle is in "OK" shape... this is very do-able... you got this.
  8. Mar 5, 2025 at 4:54 PM
    It could be something simple like a spark plug, injector, coil pack.
    Or it could be a head gasket which would still be worth it.
    Or it could be a smoked valve or bad ring in the 6 cylinder. Which may require a possible full engine swap.
    Had a local acquaintance with a 2001 4Runner 2wd Limited lunch a valve and pretty much gave the rig away.
    -Mike
    Kyblack76 and icebear like this.
  9. Mar 6, 2025 at 5:15 AM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Smells like head gasket. Other wise, the dude would have fixed it already.
    Hell, it still may be worth it.
