How Much should I lift my 4runner?
Discussion in 'Suspension' started by sam95, Jan 16, 2024.
  1. Jan 16, 2024 at 8:03 PM
    sam95
    sam95 [OP] New Member
    Samuel
    2014 4Runner Sr5 premium 4x4
    I want to lift my 2014 sr5 4runner, I made a post a day or two ago about what lift I should get and I think I have decided on a Bilstein kit, with JBA UCAs. But I would love some insight on how much lift I should do, with the kit I can either do a 2", 2.5", or 3". I recently watched a Tinkers Adventure video that showed how a higher lift can take away flex. I was originally going to go with 3" because in my head bigger sounds better. But now I am a bit more unsure of which ride height I should go with. But if any of you have thoughts and/or experience with these different ride heights I would love to hear them.
  2. Jan 16, 2024 at 8:23 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    High enough to fit 40s
  3. Jan 16, 2024 at 8:42 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    You'll get all kinds of answers. I left mine stock, and I'll keep it that way until I can't get somewhere I wanted to.
  4. Jan 16, 2024 at 9:06 PM
    CygnusX-4
    CygnusX-4 Member
    21 TRD OR
    Tires size, wheel offset, added weight, and what you're planning on doing should factor into your decision. Do you want it to sit level? I personally like 2 or 2.5 and would cut and weld if more clearance is needed. Check out this gallery for some ideas of different combinations. You'll have to navigate the spring options to see the lift heights, but they give good descriptions based on how much weight you will have.
    https://exitoffroad.com/gallery/gallery-toyota-5th-gen-4runner-2010-2020/
    Stoney Ranger and sam95[OP] like this.
  5. Jan 16, 2024 at 9:11 PM
    steelevo
    Utah
    I bought a pro with the full intention of keeping it stock.
  6. Jan 16, 2024 at 9:19 PM
    HuskyMike
    HuskyMike New Member
    Portals... it's all about Portals these days.
  7. Jan 16, 2024 at 9:24 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP @sam95
    If I could do it over I would buy an SR5 Premium, over Trail Edition w/ KDSS.
    I lifted 3" front, 2" rear, Bilstein all four corners. OME springs, ICON coils. SPC UCA. Doing a 1" body lift too prolly next year.
    But I want higher, still. Believe me, I really like and admire The Tinkerer but a lot of folks say a lot of stuff. You can safely do at least 3" no sweat. Do 3" bro, send it.
    I think 6" is badass, but a clean 4" suspension lift would be my answer.
    sam95[OP] likes this.
  8. Jan 16, 2024 at 9:24 PM
    Omg portals yes
    HuskyMike[QUOTED] likes this.
  9. Jan 16, 2024 at 10:16 PM
    3JOH22A Toyota Gigolo
    Depends on the terrain in your region. On my local trails, I'm usually clearance-limited, so more lift (like 3") is beneficial and worth the tradeoff in downtravel.
    sam95[QUOTED][OP] likes this.
  10. Jan 17, 2024 at 1:10 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Chicks are all about the portals. OP will get laid on the daily if he gets portals. Dudes guna need a crow bar to pry them off
  11. Jan 17, 2024 at 8:10 AM
    sam95
    Samuel
    I will not deny that portals are pretty sick but I don't got 20,000 dollars laying around. Thanks for yalls ideas I think I will go with the 3".
  12. Jan 17, 2024 at 8:14 AM
    Why stop at 3 inches? I'm going to lift mine 10 inches, install portals, then install 44 inch mud swamper tires. Because I want to look as cool as possible when I troll the Instagram and crawl at the fucking mall.
    Oh, and I'm going to put every single aftermarket light on it. Ditch, Raptor, Fang lights, overhead light bar, grill light bar. I think I'll even put a light bar on my light bar!
    akakaiser and sam95[OP] like this.
  13. Jan 17, 2024 at 8:23 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    For what portals cost it would be cheaper to just buy the chicks by the hour plus you don’t have to worry about them getting attached and sticking around just so they can admire your rig.
  14. Jan 17, 2024 at 10:40 AM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    :facepalm:
    brownersd and sam95[OP] like this.
  15. Jan 17, 2024 at 11:03 AM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    OP, TinkersAdventure has a lot of good information. If you want to do off roady/Overlanding and still want a sound daily driver, I wouldn't get too extreme. I suggest you avoud the exotic/expensive lift kits and go with something like the Eibach or Bilstien 2-2 1/2" kit and consider Dobinsons upper control arms that have 3 degrees of castor built in and are rebuildable (not necessary but makes it easier to do correct alignments. No need for a differential drop or panhard bar correction.
    Don't try to get any tire poke with offset or spacers as it will only increase the arc of the wheels/tires causing additional rubbing.
    Trail Runnah likes this.
  16. Jan 17, 2024 at 11:12 AM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel kit (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. Custom High Clearance Fender Liners *Coming soon Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered, coming soon Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Mall Crawler -> Leveling Kit $
    Simple lift -> 2" Bilstein $$
    Overlanding -> 2-3" OME $$
    Hardcore OffRoading -> 2-3" Dobinsons Long Travel $$$
    Nothing wrong with a simple leveling kit. Toyota's suspension is super soft and rides real smooth.
    I chose OME because I carry a lot of gear (my wife is not a minimalist) and needed ground clearance.
    People (me included) will be quick to offer opinions. But there is a lot of free bad advice out there. Try to decide what you want to do with the truck first. Then research products with those goals in mind.
  17. Jan 17, 2024 at 5:10 PM
    TrailSpecial22 New Member
    PA
    i love my set up:
    2” lift Bilstein 6112 w/600 lb coils front, 1.5” lift Eibach T13 coils rear, Bilstein 5100 rear shocks, 285/70/17 Falken WP AT3, Energy Suspension front bumpstops, Durobumps 4.25” rear
  18. Jan 17, 2024 at 5:43 PM
  19. Jan 17, 2024 at 6:19 PM
    Leighton
    Leighton New Member
    2023 4Runner TRD Pro
    My TRD Pro only has about 4000 miles on it, and I want to get the use out of what I paid for, but I'm looking at the Westcott Fox TRD Pro Lift Kit. I still don't know enough about stuff like this to know if that's a bad idea or not. So we'll see. The results from other threads look promising, especially for the price tag.
    Hopefully that won't be a problem when doing some decent offroading in Uwharrie.
  20. Jan 18, 2024 at 6:53 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Maybe you just need more credit cards? Put the purchase on a lot of credit cards?
  21. Jan 18, 2024 at 6:54 AM
    Thacrow
    Thacrow New Member
    2021 ORP
    Speed holes
    Ya know you're totally right I hadn't thought of that. You could straight up buy a hand full of humans fir that.
  22. Jan 18, 2024 at 7:04 AM
    2018 Limited
    BDR
    2018 Limited
    It’s more like a rental agreement.
  23. May 2, 2024 at 5:38 AM
    mainerunr
    mainerunr New Member
    Maine
    '23 TRD ORP
    Toyo AT3's, Greenlane Sliders
    2" or 2-1/2". 3" doesn't really gain you anything other than looks when you're at the mall. The higher you lift, the less droop you have left (unless you go with extended travel shocks and all the things that go with that)
  24. May 2, 2024 at 12:02 PM
    garoto
    garoto New Member
    I did 1.9” 6112 front and 1.5” 5160s rear with B8 springs standard load. I find it to be absolutely perfect for anything I’ll do with it. And leaves on road manners very much perfect. Also still allows for a good alignment without the neee for UCAs minimizing cost and minimizing a larger departure from what Toyota engineers were going for. I believe this setup also existed in earlier Pro’s but not at a 1.9” lift but rather a 1” lift.
