How much lift do I need with 17x9 wheels and 285/70 tires
Discussion in '5th Gen 4Runners (2010-2024)' started by 907sr5, Sep 8, 2024.
  1. Sep 8, 2024 at 5:56 PM
    907sr5
    907sr5 [OP] New Member
    2016 4Runner SR5
    17x9 wheels 285/70 tires
    I bought 17x9in wheels with no offset and plan on putting 285/70 tires on my 4Runner. Wondering what lift I’ll need for the set up?
  2. Sep 8, 2024 at 6:34 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Search function is your friend.
  3. Sep 8, 2024 at 6:45 PM
    Acesandeights
    Acesandeights #34
    2024 ORP
    They will rub no matter how tall the lift.
    Thatbassguy and Trail Runnah like this.
  4. Sep 8, 2024 at 6:50 PM
    Lift doesn't actually clear larger tires on these, they're limited by the size of the wheelwell.
    You'll need to trim some plastic and push the front fender liner forward, and probably also have the body mount chop done.
  5. Sep 8, 2024 at 7:00 PM
    Kezin
    Kezin New Member I guess?
    ‘21 and ‘17 Limiteds
    Drive straight and never go over a bump and you can clear the tires with a small lift. If you want to truly clear them, listen to @Trail Runnah
  6. Sep 8, 2024 at 7:12 PM
    This.
  7. Sep 8, 2024 at 7:34 PM
    With my experience;
    2.5in front lift with pushing the fender liner will clear 285/70R17 on 17x7.5 (+15 offset) factory wheels on TRD ORP and Limited
    3in front lift with no trimming almost clear 285/70R17 on 17x7 (+15 offset) factory wheels on SR5. After few trail runs it seems to have clear the fender liner it self.LoL.
    I have not removed my mud flaps on any of the 4runners and never will.
    Edit -
    All these instances have sway bar relocation kit and don't have KDSS. Could be a reason why it clears.
    907sr5[OP] likes this.
  8. Sep 9, 2024 at 11:30 AM
    907sr5
    2016 4Runner SR5
    I'm totally fine with trimming and cutting where needed. Just wanting to see what other people did to make theirs work. Did you switch out the control arms for aftermarket? What lift kit did you use?
  9. Sep 9, 2024 at 11:57 AM
    I don't think @Trail Runnah is lifted.
    You generally don't need UCA's until you hit around 2 5-3" of lift. But, some aftermarket UCA's pull the tire towards the firewall, making it harder to clear tires.
    There are about a thousand options for lifting. How much money do you want to spend?
    SlvrSlug likes this.
  10. Sep 11, 2024 at 9:31 AM
    CA4runner
    CA4runner New Member
    Nor Cal
    2019SR5
    6112s, TRD F2 wheels
    2" and UCAs to shift the wheels forward
