How many wish they had gone w/o KDSS?
Discussion in '5th Gen 4Runners (2010-2024)' started by java, Apr 15, 2024.
  1. Apr 15, 2024 at 4:12 PM
    java
    java [OP] fauxrunner
    2023 ORP ice cap
    I bought a new 23 ORP with KDSS last September. I had done some research and people generaly seemed happy with it. I also figured it would have a higher ressale value. Lastly I wanted no moonroof in Ice Cap, and in a couple of hundred mile radius it was the only one. Anyways, now I kinda wish it did not have the KDSS, it is an extra compoment that can fail and might get in the way of future mods.
  2. Apr 15, 2024 at 4:48 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    No regerts (<-- yep, on porpoise)(<-- the jokes keep rolling)
    I didn't buy it for better resale, I got it because I drove one with and one without and there was a noticeable difference. Also knew mods were years down the road and wouldn't be anything crazy. My opinion only, but if you are lifting higher than KDSS can handle then maybe it wasn't the best platform to start with. There is an argument for not qualifying for LT but again, IFS isn't known for flexing.
    As far as failures or it being a weak point, the only threads I've read dealing with that have been through neglect. Pull the KDSS skid to wash off salt after winters and dirt/mud/gravel from offroading and it will be fine. I've only heard of actuator/electrical issues due to corrosion under that skid
    Yotaholic, 2Toys, brodeyo and 3 others like this.
  3. Apr 15, 2024 at 4:49 PM
    I love mine. Actually I wish I didn’t have the moonroof because then I could have gone for the cargo tray.
    Yotaholic and java[OP] like this.
  4. Apr 15, 2024 at 4:58 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    2024 4Runner OR Solar Octane
    I had the front kdss piston start leaking at 31k miles. Luckily caught it 2 months before the bumper to bumper expired or it would have been a $5k fix.
  5. Apr 15, 2024 at 4:58 PM
    Being since it’s brand new, there’s no better time to get everything rust proofed. For those in the rust belt, that seems to lead to worst case situations. Proper application of a good wet-film rust control product like wool wax seems to be the most effective and safest way to keep those kdss lines, accumulators/manifolds etc from rusting away. You could even try some of the waxy set-up products that are coming out now (they probably don’t end up looking as dirty if you ever take it through mud).
    I’ve seen some pics of failures/leaks of the rams, but I would guess that would be way more repairable than having stuff rot away.
    If you take active steps to control corrosion early, chances are it will last as long as everything else. The KDSS system does give you some very real advantages both on-road and off road that a regular 4runner doesn’t have.
    I say enjoy it! But don’t neglect cleaning and rustproofing if you live in a salty area, or if you take your 4runners through mud or water.
  6. Apr 15, 2024 at 5:00 PM
    RUNNER4DAN
    Daniel
    Doesn't need any
    KDSS is a reliable, well designed system and it's one of the favorite options my 21 TRD ORP. I didn't even know it had it until after I brought the truck home. I knew that the truck cornered exceptionally well but did not realize it was KDSS.
    Much better system than XREAS
    Harringbr99, Yotaholic and 2Toys like this.
  7. Apr 15, 2024 at 5:05 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    That sucks, I'm sorry to hear that. I think that's the first one I've heard that wasn't a corrosion failure. I have seen as much as 7-10k to fix and not all dealers are familiar with the system
    Yotaholic likes this.
  8. Apr 15, 2024 at 5:08 PM
    I can’t even imagine the concept of cornering with my 4runner lol. But that’s probably because I don’t have KDSS. :p
    I’m ok with that though…there’s nothing wrong with having an old school 4x4 that corners like floppy drunk pig. :D I exaggerate a little. It feels fine in normal driving, the floppy pig comes out once you poke it a bit too much.
  9. Apr 15, 2024 at 5:15 PM
    I’m not doubting the estimates people have gotten for repair, but sometimes I have to wonder if those are “go away, we’re busy” quotes. That seems super excessive for any one thing on a vehicle outside of a transmission replacement.
    If that’s really the going price to replace one part of the KDSS system, I’d be really tempted to buy access to the factory repair procedure and try it myself. Does anyone here know why it might be that expensive?
    At least the OP has the advantage of having warranty. Keep it clean and protected early and make sure you do a careful inspection before the warranty expires.
  10. Apr 15, 2024 at 5:20 PM
    FN2187
    FN2187 Stormtrooper
    Earth
    Have no idea why it's so expensive. Especially when it's only 1500-2500 add-on? I think mine was only about 1k more than non-KDSS because there were so many on lots on 2019.
  11. Apr 15, 2024 at 5:30 PM
    Rott4r
    Rott4r New Member
    23 MGM 4Runner TRD orp kdss
    If kdss parts didn’t cost so much and labor to fix wasn’t so high, I don’t think it would be a big deal as it is now. But unfortunately that’s not the case.
  12. Apr 15, 2024 at 5:44 PM
    legend1011
    legend1011 New Member
    2024 White 4Runner TRD Offroad Premium (No KDSS)
    I researched this before we bought our 2024 and decided against KDSS. I did not even want to test drive one - I do not know what I missed. Our truck still handles much better than our 2001 Infiniti QX4.
    I wasn't so much concerned about the extra $1750, but more about the repair cost down the line. We live in a state with no salt (Colorado, not the northeast).
    I do think if you have a 5th gen you're overall happy with, it's probably not sweating. I would probably use fluid film on all the KDSS components and regularly clean the under body if we ended up with with one (I'm most likely going to do this anyway).
    WilVis, Yotaholic and java[OP] like this.
  13. Apr 15, 2024 at 5:46 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    This. The front piston alone is almost $2k depending on where you get it from. Then there is the special oil the system is charged with. There is also the special system pressurizing tool that the majority of dealers do not have on hand. In my case I had to wait a month and a half for my dealer to get the tool as it travels around from dealer to dealer.
    Superdave1.0, Yotaholic and java[OP] like this.
  14. Apr 15, 2024 at 6:17 PM
    Rott4r
    Rott4r New Member
    I’ve seen forums where people bought a hydraulic pump to mimic the SST pump tool, but if parts cost so much I’m not sure it’s worth fixing if not warrantied. 2k just for the front piston is just nuts. Probably better converting to regular sway bars at that point, looks like fronts needs threads tapped or riv nuts and rears need some fabricating work. Does anyone know if the kdss can be deactivated by tech stream if someone were to remove the system so the kdss light on the dash don’t stay on?
  15. Apr 15, 2024 at 6:20 PM
    Trident904
    Trident904 That Guy
    Brian
    Treasure Coast, FL
    22 TRD Offroad Premium on 35’s
    King 2.5 with resis, C4 Hybrid Front, TC Uppers, Victory Rack, Smitty 12k winch, 17x9 -38 SCS F5’s with 295/70 Ridge Graps
    I ordered my 22 TRD ORP without KDSS because I don’t run swaybars.
  16. Apr 15, 2024 at 6:37 PM
    java
    2023 ORP ice cap
    Lots of great thoughts here! I guess when if ever it breaks I'll just disable it. I might even do it as a fun oroject after the warranty runs out! And it took me 6 months to relaize, but I emptied two cans of FF on the frame a couple of weeks ago, including behind the KDSS skid
    If I could wind back time, I'd get a non KDSS. Still love my truck a lot tho, would not even trade for a brand nee one.
    McSpazatron and Yotaholic like this.
  17. Apr 15, 2024 at 6:43 PM
    java
    2023 ORP ice cap
    Ouch! Still cost the warranty 5k$?
  18. Apr 15, 2024 at 6:44 PM
    java
    2023 ORP ice cap
    Were you still able to drive during that period?
  19. Apr 15, 2024 at 7:00 PM
    Rott4r
    Rott4r New Member
    That’s my plan if it breaks, rip it out. Until that time comes I’m not going to worry so much about it. I just got into 4Runners and did not know what kdss was, I thought kdss was some kind of special shocks when I read kinetic dynamic suspension system on the sticker. sales guy didn’t know what it was lol. It is what it is, I wouldn’t sell or trade mine either, happy with what I got. End of the day it’s still a 4Runner regardless of kdss or not.
    Yotaholic and java[QUOTED][OP] like this.
  20. Apr 15, 2024 at 7:01 PM
    Tooly
    Tooly New Member
    Okanagan, BC Canada
    Toyota paid for it because it was warranty but with the labor and parts involved it was almost $5k.
    Yes still able to drive, no dummy lights or anything. If I hadn't swapped my winter wheels on and noticed the front piston weeping I would have never known.
  21. Apr 15, 2024 at 7:03 PM
    FourBelugas
    FourBelugas New Member
    23 white ORP
    that's my logic of having it. As long as it works, great. If it stops working and I don't feel like putting everything back, well, out comes all the parts and retrofit with SR5 parts. No biggie.
    Yotaholic and Rott4r like this.
  22. Apr 15, 2024 at 8:01 PM
    Rott4r
    Rott4r New Member
    Going off topic but Before I lifted mine I did researched and read about how it’s a lot harder then a non kdss. When I got around to lifting it, it wasn’t as hard as what people said it was on the forums. Did not loosen the kdss shutter valves either, I feel like that’s where some end up with a lean after a month or two, From tampering with the system.
    Yotaholic and Thatbassguy like this.
  23. Apr 15, 2024 at 8:23 PM
    Rott4r
    Rott4r New Member
    Is that the main cause of the failure is dirt and debris building up behind that skid?
  24. Apr 15, 2024 at 8:32 PM
    I did my lift without opening valves, also. No lean, here.
  25. Apr 15, 2024 at 8:37 PM
    Yotaholic
    Yotaholic New Member
    Olympia, WA
    I can't imagine driving this brick without KDSS.
  26. Apr 15, 2024 at 8:40 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    Anyone else feel that KDSS rides rough when lifted?
    Our 18 OR and current GX not as smooth riding as our 16 SR5
  27. Apr 15, 2024 at 8:47 PM
    siblue
    siblue Old member
    Ryan
    Socal
    24 Land Cruiser
    18 Bilstein 5100
    22 GX Dobinsons standard
    16 SR5 same 5100
  28. Apr 15, 2024 at 8:55 PM
    Klinsman55
    Klinsman55 New Member
    K
    Northern Nevada
    2024 LE silver
    XREAS. Cooper Discoverer Road and Trail AT 255/75r17. Trd Pro Wheels
    I have KDSS. Mainly got it b/c figured would give me extra control around corners and or if ever having to make quick evasive maneuvers. More as an extra safety feature
    It does really give it a more sporty planted controlled feel.
    with that said I feel it is maybe a little stiffer driving and potentially something to need repaired in future.
    I like the non KDSS better, feels more bouncy, leans like a pirate ship turning and maybe a little softer driving on road
    im not planning a lift more than 1.5” so I should be fine
    I really wish I didn’t have a moonroof. Seems near impossible to find one without moonroof
    WilVis, java[OP] and Yotaholic like this.
  29. Apr 15, 2024 at 9:09 PM
    Yotaholic
    Olympia, WA
    Offroad it is rough, yes. But it still corners amazingly. TRD Pro is probably more comfy offroad at speeds over 15 mph.. I run my KDSS at 10-15 psi and it does ok at high speed offroading
  30. Apr 15, 2024 at 9:19 PM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    Well, short of becoming another "KDSS or no KDSS" philosophical thread, I think the straight answer is you won't find anyone who intentionally bought KDSS wishing they didn't have it. I waited 6 months for it and there's a reason. Anyone who got it "accidentally" or "incidentally", as it may be, would likely hate driving a non-KDSS, even if they don't think they care about it now.
