How many of ya'll are running TRD ROCK WARRIOR FORGED WHEELS P/N: 45-35010!?
Discussion in '5th Gen 4Runners (2010-2024)' started by djwantke, Jan 9, 2024.
  1. Jan 9, 2024 at 6:43 PM
    djwantke [OP] New Member
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Firesq14 likes this.
  2. Jan 10, 2024 at 11:43 AM
    HuskerRunner
    HuskerRunner I joined 2.5 years after Rick G
    O,NE
    2023 SR5P
    Taco to 4R Mod
    Would be a good looking option used. Not for $860 a pop though
    djwantke[OP], Han4Run and 2ndGen22re like this.
  3. Jan 10, 2024 at 1:05 PM
    Is that the price eh!? Not real beadlock even either.
    It's just money :D
    I wanna see someone with these, there's gotta be someone
  4. Jan 10, 2024 at 1:19 PM
    PJSnow
    PJSnow New Member
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    I almost picked up a used set until I realized they don't use the same lug nuts that our factory wheels use. Toyota has historically used mag type lug nuts but these rock warrior wheels use either the acorn or spherical style (the seller did not have the lug nuts on hand to confirm). To carry a spare tire around, you would either need a 5th rock warrior wheel to mount a spare onto (which is extremely difficult to find) or a separate set of lug nuts to use the factory spare (which seems impractical and the potential of misplacement skyrockets).
    The set I was looking at were also extremely faded and would require refinishing. At the time I was not interested in the effort but they seem to hold their value.
    To each their own, but if you are willing to change lug nut style, I think there are other better value (and better looking) wheels in the aftermarket. Personally, I prefer OEM quality and convenience, therefore I chose to stick with the TRD wheels (Sema wheels?).
  5. Jan 10, 2024 at 1:33 PM
    Mass4runner
    Mass4runner New Member
    2023 TRD ORP
    I've seen one 4runner locally that has these and they look amazing. Way too much money though.
  6. Jan 10, 2024 at 1:56 PM
    steelevo
    Utah
    The price isn't that far off for a forged one-piece wheel. It will definitely be much stronger than the cast or flow-formed wheels.
  7. Jan 10, 2024 at 1:57 PM
    TheGreekFreak
    TheGreekFreak New Member
    Personally prefer the 16" TRD "beadlock" style wheel that came on some of the TRD Tacomas. When I realized 16" won't work on the 5th gen, I considered these as well.
    Then I saw a pic of them on 5th gen.....did not like the look. May catch my eye better with some white letter out K02s but didn't look right as is. Was stoked to find the FN wheels 17" replica versions of the 16" TRD beadlock style wheels, will be mounting my set this Spring.
    Would never pay anywhere close to $800 a wheel for these. A while back, I would see these for sale all the time for nowhere near that. Despite these being forged, the 16" beadlock versions sell for much more secondhand too.
    Han4Run likes this.
  8. Jan 10, 2024 at 2:01 PM
    HuskerRunner
    O,NE
    2023 SR5P
    Taco to 4R Mod
    I guess for those whose usage actually requires that strength. For that much my wheels better be forged in Asgard!
    Han4Run and djwantke[OP] like this.
  9. Jan 10, 2024 at 2:11 PM
    Han4Run likes this.
  10. Jan 10, 2024 at 2:40 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Or, it better be forged by the Armorer using Beskar
    TheGreekFreak and 2Toys like this.
  11. Jan 10, 2024 at 2:51 PM
    3JOH22A Toyota Gigolo
    Heavy for a forged wheel.
    Faux beadlock rings gouge easily if you actually take them rock crawling. Then the wheel goes out of balance. Replacement rings are unobtainium. They also trap mud and water.
    The offset isn't good - too low for 33" skinnies, too high for 33" wide and 35"s.
  12. Jan 10, 2024 at 2:51 PM
    nova
    nova New Member
    mike
    Prescott Valley - Arizona
    slightly modified LE
    My wife gave me a set for my birthday a few years ago. They looked amazing especially when compared to the stock LE wheels (which were awful for me).
    Toyota made a 5 bolt for Tundra and the 6 bolt was for some trim level of Tacoma IIRC. Which of course, fit the 4Runner fine. They are hub centric as expected but did need its own lugs.
    I had 5 of them and sold them in 2022. I now have Method 701s.
  13. Jan 10, 2024 at 6:07 PM
    HuskerRunner
    O,NE
    2023 SR5P
    Taco to 4R Mod
    I could be wrong, but I think the difference was in size, not lugs. The 2nd Gen Tacos were only 16s I think.
  14. Jan 10, 2024 at 7:33 PM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    I have a 2nd Gen Tacoma TRD Sport - and it has 17s.
  15. Jan 10, 2024 at 7:51 PM
    HuskerRunner
    O,NE
    2023 SR5P
    Taco to 4R Mod
    Yes, I wasnt clear. 2nd Gen Sports had 17s stock, Limiteds had 18s, and the Offroads and Pros(which got the fake beadlock)had 16s.
    2Toys likes this.
  16. Jan 10, 2024 at 8:04 PM
    nova
    nova New Member
    mike
    The RW 6 bolt is a 17” and fit my LE perfectly. I had stock SR size tires 265/70-17. No issues.
  17. Jan 11, 2024 at 7:56 AM
    The TRD SEMA wheels with 4mm offset are arguably the most off road-capable OEM wheels, because they let the vehicle accommodate 35x10.5-17" skinny tires with minimal effort, just push the tire forward with the alignment cams and do a cab mount chop. Lowest effort path to get into 35s.
  18. Jan 11, 2024 at 8:29 AM
    Thanks man
    Interesting
    So 23lbs is heavy for the category of forged?
    And +10mm offset is bad for those tires mentioned, how so
    (I wouldn't know, I run 9" wide 0 offset w/ 33s)
  19. Jan 11, 2024 at 8:30 AM
    What's their wheel width you think
  20. Jan 11, 2024 at 8:37 AM
    CalcityRenegade
    CalcityRenegade New Member
    Matt
    2023 T4R ORP KDSS
    Only if you're running skinnies, anything else you would want a wider wheen as the TRD wheels are only 7" wide. I have Replika TRD wheels as they were hundreds cheaper and 8" wide with the same appearance.
    djwantke[OP] likes this.
  21. Jan 11, 2024 at 9:43 AM
    For a non-beadlock wheel, 23 lbs is heavy. For comparison, Volk Racing TE37XT in 17x8.5 is 17 lb.
    To run a 33" skinny with little or no trimming, you want offset in the +30mm range, like 4th gen OEM wheels or Tacoma TRD Sport OEM wheels.
    To run a 33" wide or 35" skinny with minimal work, you want offset in the 0mm range.
    +10mm is somewhere in between, so it either requires more trimming, or fouls on the suspension (UCA, spindle gusset) depending on tire diameter.
    The ubiquitous TRD SEMA wheels are 17x7: https://www.tacomaworld.com/threads/wheel-specs.30754/
    djwantke[QUOTED][OP] likes this.
  22. Jan 11, 2024 at 9:56 AM
    This thread is speaking in context of OEM wheels. Sky's the limit with aftermarket of course, with a variety of cheaper wheels and stronger wheels, various forged beadlocks, etc., etc. There are also Teraflex wheels with a second high-flow valve for faster air up/air down.
    On my Tacoma, I run FN Six Shooters in 17x8 0mm purchased through Cochrane Toyota, light and affordable. They get gouged to shit by rocks, but I don't shed too many tears. Already had to replace one after I caught air and the rim lip smashed sideways against a rock, but I did get a picture into the 2023 Tacoma World calendar :laugh:
  23. Jan 11, 2024 at 11:05 AM
  24. Jan 11, 2024 at 11:37 AM
    CalcityRenegade
    Matt
    2023 T4R ORP KDSS
    Oh damn, you a local boy! I am in Calgary and was on Tacoma Town's website just this morning :D
  25. Jan 11, 2024 at 11:37 AM
    Emmantik
    Emmantik New Member
    Coquitlam, British Columbia
    2015 Magnetic Grey SR5P
  26. Jan 11, 2024 at 7:16 PM
    I'm 3400 km away lol, but Tacoma Town is the only reseller of FN wheels in the country, I think.
  27. Jan 12, 2024 at 12:41 PM
    ShakyDog
    ShakyDog New Member
    Steve
    2021 4R TRD ORP Nautical Blue
    My old 2011 Toyota Rock Warrior had these and I love the look. The center caps didn't hold up very well, but they were inexpensive enough to replace.
    Steve
  28. Jan 12, 2024 at 12:53 PM
    BortisYeltzen
    BortisYeltzen New Member
    SLC, UT
    2021 T4R ORP
    In-Progress
    I have the RW wheels on my Tundra. I like them a lot. Unfortunately the center caps are now unobtainable. If anyone knows where to get some, let me know. Otherwise I’ll be 3D printing some replacements soon.
    I have the gloss gray TRD Pro/SEMA wheels on my 4Runner and I like them, they fit 285’s well with a 2” lift and don’t stick out too far and wreck the side of the vehicle with debris. No photos handy.
  29. Jan 12, 2024 at 1:46 PM
    ^You have blank center caps on now? Just get whatever TRD/TEQ/Gazoo/F-Sport decals and stick them on the caps :notsure:
  30. Jan 12, 2024 at 3:29 PM
    Just seen these posts
    Sick guys!
