How important is airing down for sand?
Discussion in 'General 4Runner Talk' started by cchopan, Aug 7, 2021.
  1. Aug 7, 2021 at 8:12 PM
    cchopan
    cchopan [OP] New Member
    Collin
    New England
    2017 Limited
    I have a stock 2017 Limited that I have taken to the beach once or twice already and I did not air down. Obviously it’s not “necessary” because I did fine but how much of a difference will it really make?
    Should I wait until I’m actually stuck to air down? Or is there advantages to doing it proactively.
    Thanks!
  2. Aug 7, 2021 at 8:36 PM
    Mtbpsych
    Mtbpsych New Member
    Airing down when you’re stuck will more than likely do nothing, and might make you pop a bead. If you’re on stock limited tires airing down won’t be much of help since they’re street tires. Just drive cautiously, and maybe investing in some self recovery traction boards might not be a bad idea if youre at the beach frequently.
    i.e. know your limits.
    LandCruiser likes this.
  3. Aug 7, 2021 at 8:43 PM
    LandCruiser
    LandCruiser I have Toyotas
    East Bay Area
    5th Gen OG TE
    Not going to get a lot of float with low profile tires.
  4. Aug 7, 2021 at 9:15 PM
    olliechristoper
    olliechristoper New Member
    Chris
    It all depends on the type and depth of the sand. I air down to 20psi to start for places like Glamis, Dumont Dunes, and Pismo.
  5. Aug 7, 2021 at 9:42 PM
    This will vary. I have access to a private beach and drive on it a few times a year. The second time I drove on it I started bogging down and sinking in an area where sand had piled up during a flood. I was able to redirect and use some momentum to get back to solid ground.
    I started airing down before going back there and haven't come close to getting stuck since.
    My point is that it may not always be necessary, but it will always make a difference. Even with the low profile Limited tires, you can get some flotation by airing down. I would start out at 25 PSI or so and go lower if necessary.
  6. Aug 8, 2021 at 7:00 AM
    jetmechG550
    jetmechG550 New Member
    Frank
    2021 Off Road Premium
    If you're going to OBX (Carova), yes it's necessary. You might get by for a while but you also beat the shit out of the beach. If you're going to Daytona, then no it's not necessary
