Hose placement question
Discussion in '3rd Gen 4Runners (1996-2002)' started by thatmotoguy, Feb 3, 2023.
  1. Feb 3, 2023 at 12:26 PM
    thatmotoguy
    thatmotoguy [OP] New Member
    2002 2WD 6Cyl 4runner
    Hey guys,
    First post here, I've been a shade tree mechanic for about 10-15 years now and have done many hard jobs but I've been excited because I inherited this 3rd gen 4runner, 2002 6cyl and it was leaking oil horribly. The valve covers were basically under .5-1mm of old oil. Went to tackle the job with too much confidence and didn't label and take everything as slowly as I should have but I was hoping this forum could help.
    I have the lower and upper plenum back on and most hoses to this point in the job connected back to where they should be but this hose has been blowing my mind. I must have knocked it off or missed it in my DIY because I can not find where it goes. Does anyone have any ideas?
    Wanted to find out before I put the throttle body back on in case other parts need to come back off.
    I greatly appreciate your guys expertise, hoping someone can help.
    EDIT: Also excited to join the forums, I hope I can help someone out in the future with a situation
    attaching images...
  2. Feb 4, 2023 at 5:29 AM
    No idea on the hose ,but Welcome
  3. Feb 4, 2023 at 10:25 AM
    2018 Limited
    2018 Limited New Member
    BDR
    2018 Limited
    Welcome. You can try pulling up a graphic on an oem Toyota parts page online. Try looking in the cooling or AC section and attempt to match up that pipe on the parts fiche. I took a quick look myself and found a part similar in shape but you would probably do better to confirm its identity with part in hand. Maybe worth a look.
  4. Feb 5, 2023 at 7:27 AM
    Ahdofu
    Ahdofu New Member
    Matt
    I don't gave access to my car so this is just based on my memory
    I think this is your PCV hose. The 90 degree metal end of the tube goes to the driver side valve cover. I think on top of the valve cover there is a hole toward the firewall where this end goes. The other end must go somewhere on the intake side.
  5. Feb 5, 2023 at 11:40 AM
    thatmotoguy
    Thank you guys for the welcome and responses, still haven't concretely narrowed it down but I'm waiting on replacement hoses to the intake from McGeorge. Expensive for some hoses but I expect the car to last a long time if properly taken care of
  6. Feb 5, 2023 at 1:32 PM
  7. Feb 5, 2023 at 4:03 PM
    Ironguy New Member
  8. Feb 6, 2023 at 9:11 AM
    I think it goes on the back of the intake near the firewall.
    See some pics here of my 2002:
