Homelink and garage doors not syncing
Discussion in '5th Gen 4Runners (2010-2024)' started by 23OFP, Apr 21, 2023.
  1. Apr 21, 2023 at 10:05 AM
    23OFP
    23OFP [OP] New Member
    Cory
    Any one else have issues? I have a liftmaster 8355W and a 23 ORP. I've used the homelink app, the toyota instructions, and various youtube videos. I cannot get it to connect at all. I reset the garage and reprogrammed my other car so I know it works. The 4runner just blinks yellow and never syncs. I have a spare opener but its aggravating to get a 50k+ truck and have to use a $7 Amazon clicker. Any special tips?
    MeefZah and CO1224 like this.
  2. Apr 21, 2023 at 10:16 AM
    semprenissart
    semprenissart Mèfi
    2022 4Runner TRD Pro (MGM)
    I can't help you other than telling you that mine works without issue on both liftmaster and chamberlain so it SHOULD work.
    kolter45 and Toy4X4 like this.
  3. Apr 21, 2023 at 10:21 AM
    You need to first set the opener to rolling code mode. I believe that still might be a thing.
    Captain Spalding likes this.
  4. Apr 21, 2023 at 11:30 AM
    Another thought, how are you programming? The Runner to the opener or the opener to the Runner?
  5. Apr 21, 2023 at 11:36 AM
  6. Apr 21, 2023 at 12:38 PM
    Jackmahoffer
    Jackmahoffer New Member
    Spencer
    22 white trd pro
    I had a hard time with mine too. The instructions are correct but you have to find the sweet spot of the remote to overhead homelink. I actually don't remember where the sweet spot was. Either closer to the windshield or the dome light. You're gonna have to play with it.
    Dir4219 likes this.
  7. Apr 21, 2023 at 1:23 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    Yeah, I recently sync'd my '22 ORP. At first it would not program. In my case I just needed to hold the remote garage door opener very close to the button in the truck.
    Dir4219 and kolter45 like this.
  8. Apr 21, 2023 at 1:36 PM
    Acebb
    Acebb New Member
    2023 Black SR5P
    I have a brand new 2023 SR5P and I had the same issue. I was trying to do the sync with the vehicle running. Apparently you have to do it in accessory mode. When I just was in ACC mode and used the transmitter it worked.
    Also, using the "learn" button on the garage door motor never worked, even in ACC.
    You would think Toyota would be better at this...
    Kad2112 likes this.
  9. Apr 21, 2023 at 2:41 PM
    23OFP
    Cory
    Yeah thats the method I tried first. syncing with a clicker. I had it right next to the homelink button. Maybe to close I guess. Also tried with learn button on the opener, no good. Tried with car running and off. Ill try with accessory mode again. This is frustrating as hell
  10. Apr 21, 2023 at 2:49 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    On my '20 I did not use the remote at all. Programming was only between the truck and the opener in the garage. I used these instructions:
    HomeLink
    2018 Limited and kolter45 like this.
  11. Apr 21, 2023 at 2:53 PM
    23OFP
    Cory
    I used the homelink link first. Plugged in my model number and follow directions exactly. No bueno. This shouldn't be frustrating me as much as it is.
  12. Apr 21, 2023 at 4:37 PM
    I had to put my genie opener in learning mode then hold down the homelink and genie opener at the same time.
    I can only assume that the homelink was learning the frequencies and pairing at the same time. Was weird and nothing like i found anywhere online.
  13. Apr 21, 2023 at 5:23 PM
    4Runner_Patrick
    4Runner_Patrick New Member
    2023 TRD PRO Black
    I had the same problem. Had to hold the remote next to the buttons to synch.
  14. Apr 21, 2023 at 5:29 PM
    2ndGen22re
    CR
    Carson Valley, NV
    1990 22RE & 22 AG ORP KDSS
    Wow, I guess I was lucky…..I was dreading programming my garage doors and gate but it went smooth as silk. I even was able to link to my Ghost gate opener on the first try, the 4R setup even has longer range than the standard remotes.
    kolter45, Texrun50 and Steely123 like this.
  15. Apr 22, 2023 at 6:51 AM
    MusashiSushi
    MusashiSushi New Member
    Colorado Springs, CO
    2023 4Runner SR5 Premium Black/Black
    Elka 2.5 DC 3" lift, SPC UCA's, Toytech rear springs, ARB Diff Breather, RSG Rock Sliders & front Skid. C4 front bumper with High Clearance sides and Warn Winch.
    I had problems too with my 23' then I saw the instructions in the book on how to clear old codes. I did that then it programmed just fine.
    kolter45 and Steely123 like this.
  16. Apr 22, 2023 at 10:07 AM
    I know. It’s great. I can press the button when I’m way down the block and the gate will be open when I get there.
  17. Apr 22, 2023 at 11:06 AM
    OverRunner
    OverRunner rebmeM weN
    Jared
    Denton, TX
    ‘21 ORP w/KDSS
    I followed the directions and couldn’t get mine to program. I tried three different sessions and could never get it to sync. I actually got made fun of a bit for having the garage door remote for so long, because I couldn’t figure it out. Finally, I started trying random things that weren’t in the instructions. I’m not near them now, but I had to press the button either once more or once less than the directions advised. I was able to program all three buttons on the first try after that. I remember being incredibly frustrated.
  18. Apr 22, 2023 at 2:28 PM
    Shilo5000
    Shilo5000 New Member
    Lucas
    OC
    ‘22 TRD PRO
    Still has never worked for me. Inspired by these posts I just tried all these methods (video, no remote, everything). I’ve had it over a year and every time I pull out the remote to open the garage, I cry a little. Hopefully someone with luck posts something that works, but I’ll probably die with a garage door in my hand.
    Nemo and MeefZah like this.
  19. Apr 22, 2023 at 8:10 PM
    wax poetic
    wax poetic Raking like a mofo
    21 Super White TRD OR
    Got mine working today haha :D (was actually pretty bummed when I realized that I didn't have this built in in a '21 vehicle) Thanks 3m removable velcro strips!
    Nemo, icyhotahs, nimby and 2 others like this.
  20. Apr 22, 2023 at 8:15 PM
    Shilo5000
    Lucas
    OC
    ‘22 TRD PRO
    Brilliant
    wax poetic likes this.
  21. Apr 23, 2023 at 4:54 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    OP I feel your pain. I have given over 3 hours of my life, I bet, to trying to get my opener programmed. If someone posted a tip, I followed it. If a video existed, I watched it. I read the manual like 16 times. I went to Homelink's site and read their instructions 142 times.
    And still fucking nothing.
    I absolutely cannot get mine to take (Liftmasters, 2 of them).
    What is maddening is that my wife's Outback with the SAME FUCKING SYSTEM she got to take in like 3 seconds. Even more annoying, while I was fiddlefucking with my remote I somehow managed to deprogram all the remotes except somehow for her Homelink system which just reset itself somehow to the new code with no intervention needed on her part.
    At this point I am done with trying to program the fuckers to the 4R.
    I am just using a regular remote, like a plebian. I did disassemble it and hide it in the visor though so I guess that's kind of cool...?
    Crunch11b and Shilo5000 like this.
  22. Apr 23, 2023 at 6:57 AM
    icyhotahs
    icyhotahs NEw mEmBER
    Samuel
    Sacramento, CA
    2022 ORP Super White
    Method 703 - Nitto G2 - C4 Ladder - UpTop Rack - EIbach 2.0 Coilovers & Load Levling Kit (250) Victory Strike Sliders - Dometic 55 - EcoFlow Delta
    @MeefZah I think your remote knows you're short tempered
    Shilo5000 and wdsteven like this.
  23. Apr 23, 2023 at 8:14 AM
    08TXRunner
    '20 SR5P
    Really weird. The method in the manual didn't work for me so I used that link on my new '20. Worked the first time. I'd be frustrated too.
  24. Apr 23, 2023 at 10:58 AM
    I'm surprised how many having issues with the garage door opener where many comment that it works, even on BMW. I wonder what's missing with those who were not able to program. May be uncommon garage door opener?:notsure:
  25. Apr 24, 2023 at 7:41 PM
    23OFP
    Cory
    Still no luck accessory mode, clicker then learn button, nothing. Clicker it is
  26. May 12, 2023 at 11:40 AM
    20204runnerguy
    20204runnerguy New Member
    2020 4Runner TRD Pro
    Lights
    I've had the same issues, followed the steps in 4Runner manual, Homelink, etc and nothing seemed to work. I tried this approach https://youtu.be/Tv0FG43gcx0 (video in this thread from April) and it worked for me.
    His steps are different than Toyota manual and what Homelink recommends, but I'll be darned...his method worked!!!
    Let's see if it lasts...
  27. May 12, 2023 at 11:52 AM
    It took me multiple attempts, but I finally did it. I knew it could be done. There is no way I was going to admit defeat and give up on something that so many others before me had accomplished.
    Jostack likes this.
  28. May 12, 2023 at 2:08 PM
    20204runnerguy
    Lights
    Persistence...
  29. May 12, 2023 at 5:25 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    I had a similar issue with my Genie. The website essentially defined two processes. If you get through the first one and it still doesn't work, you go to Phase 2. My interpretation is that the Homelink learns from your remote, but that learned signal doesn't work by itself. You have to put the garage door opener in learning mode to get it to accept the Homelink. I was afraid after that worked, it wouldn't accept the regular remote anymore, but it did.
    It took most of an hour to get it going. Now I can go back and reprogram the Homelink on my wife's Subaru, since that pairing failed after doing just the first process.
    Jostack and Steely123[QUOTED] like this.
  30. May 12, 2023 at 5:50 PM
    backpacker
    2023 TRD ORP
    By the way, my hypothesis is that what the Homelink learned from the remote lacked some kind of preamble synchronization, so what it was transmitting was a shifted (perhaps circularly shifted) version of the desired signal. The second phase (garage door opener learning) gets the opener to accept that shifted version. Somehow it still accepts the one from the original remote, so it's able to resolve the shift, but not accepting a copied signal without learning is probably a security feature.
