Holding gears?
Discussion in '5th Gen 4Runners (2010-2024)' started by ham4run, Sep 27, 2020.
  1. Sep 27, 2020 at 9:24 AM
    ham4run
    ham4run [OP] New Member
    2019 TRD ORP
    Hey all, new to the Toyota fam and 4runners and looking for a sanity check of sorts. I have a 19 ORP and comparing this to my previous vehicle, it seems to ‘hold a gear’ when going down hills. Basically going down some hills in the ORP I can maintain a speed down the hill without using the brake or manually downshifting, and the truck doesn’t seem to be downshifting either. My previous vehicle would’ve gained speed the whole time down the hill unless I manually downshifted or rode the brake a bit and the downhill assist kicked in and it would downshift accordingly.
    Any insight is appreciated, sorry for the long winded question!
  2. Sep 27, 2020 at 11:44 AM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    What's the question? There's not a single question mark in that whole paragraph haha
    Thatbassguy and Agent_Outside like this.
  3. Sep 27, 2020 at 12:06 PM
    Ironguy New Member
    If you have Cruise Control engaged it will try to maintain the set speed.
    Thatbassguy and ham4run[OP] like this.
  4. Sep 27, 2020 at 12:11 PM
    ham4run
    2019 TRD ORP
    lol question was in the title!
  5. Sep 27, 2020 at 12:12 PM
    ham4run
    2019 TRD ORP
    no cruise control engaged. I’m assuming what I’m experiencing is normal, just wasn’t expecting it. Seems like the torque converter is locked and just holding speed. I can literally drive down modest hills with my foot slightly on the gas and not increase speed. Sound normal?
  6. Sep 27, 2020 at 12:22 PM
    In overdrive? Or S5? In sport mode the transmission usually stays in the selected gear, unless you punch the throttle and it downshifts.
  7. Sep 27, 2020 at 12:22 PM
    Ironguy New Member
    Have you accidently nudged the shift lever to the left and it drops a gear?
  8. Sep 27, 2020 at 12:29 PM
    ham4run
    2019 TRD ORP
    In OD, shows D on the HUD, rpm stays fairly low, like below 2k, but vehicle speed remains pretty consistent. Maybe this truck just has a lot more engine braking then I’m used too?
    I did drop it into sport/manual shifting and it did change the HUD to the corresponding gear and it did drop a gear.
  9. Sep 27, 2020 at 12:34 PM
    They DO engine brake sometimes. But, it's usually when you're braking.
    It could have something to do with what you're used to. Mine only seems to gain speed on steeper hills.
    ham4run[QUOTED][OP] likes this.
  10. Sep 27, 2020 at 12:42 PM
    ham4run
    2019 TRD ORP
    Thanks, I feel it may be me not being used to it. It doesn’t shift weird or anything, just different experience.
