High Clearance Rear Bumper Mods
Discussion in 'Armor' started by 1SilverRunner, Jan 19, 2024.
  1. Jan 19, 2024 at 1:39 PM
    1SilverRunner
    1SilverRunner [OP] My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    I came across a couple tubed rear bumper mods that could keep us from losing our bumpers on every decent obstacle.
    Looking for an armor option that retains my stock hitch and stock location spare
    One is custom pulled from a different forum.
    The other is a diy kit from 80percentoffroad.
    Has anyone seen something like this before?
    Cis915, Rob41 and captrussia253 like this.
  2. Jan 19, 2024 at 2:25 PM
    PJSnow
    PJSnow New Member
    PJ
    New York
    2018 Cavalry Blue TRD Pro
    Those custom cuts are slick and probably a lot of work. Most people will probably opt for an aftermarket bumper but I'm sure there is a market for an OEM look. I personally want some protection but I have no desire to cut the factory plastics. This is another custom job I found on the other forum that I liked:
    Post 4: 20170710_071635 (1024x768).jpg 20170710_071653 (1024x768).jpg
  3. Jan 19, 2024 at 2:48 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    WATCHING THREAD
    I cant really help with the question(s)
    But I'm very interested in rear bumper clearance cut, rear bumper tubing, and bumper tire carrier options
    @captrussia253
    captrussia253 likes this.
  4. Jan 19, 2024 at 3:33 PM
    Old Tanker
    Old Tanker New Member
    Keith
    "Matilda" 2019 ORP
    Front: Hefty. Rear: LFD. Sliders: RSG. Armor: LFD and Bud Built. Tires: KM3. Switchpro.
    I don't see how adding a tube below the factory departure angle can be called "high clearance".
    BashFab, Stoney Ranger and djwantke like this.
  5. Jan 19, 2024 at 3:37 PM
    Stoney Ranger
    Stoney Ranger New Member
    Driftless Area
    '18 SR5 Nauti Blue
    4x Rockers/Skids-Dobi-275's-Fr/R Bpr-Winch-Stickers-ALF
    I bought this one. I'd post a pic of my 4R, but it's full of salt and frozen slush. I bought mine raw and had the bumper painted to match. I also was able to re-use the factory mudflaps with some innovation.
    The X-member had the holes in it already, so we hogged them out and put in lights.
    https://nguyenworksusa.com/shop/ols/products/5th-gen-4runner-plated-low-rear-bumper
    The spare stays in the factory location. I cut out the 2 horse shoe brackets shown in your pic #4, for better spare tire clearance.
    Oh, hell....here it is.
  6. Jan 19, 2024 at 3:46 PM
    Good point, like in Post #2 your subbing plastic for metal.
    @Stoney Ranger has one I like.
    1. Do you have a body lift?
    2. Am I looking at your factory hitch unaffected ?
    Han4Run likes this.
  7. Jan 19, 2024 at 3:56 PM
    1SilverRunner
    Tejas
    The 80%OR option is pretty high clearance. It’s not below the bumper. The bumper is cut in half to install this. When I spoke to the guy running 80percentoffroad he explained that if you get the hitch relocation you’re gaining 5-6 inches of clearance.
    Which is HUGE imo.
    You also have steel put in its place so when you smack your bumper on obstacles you essentially have a slider under your bumper. I really like the idea honestly.
    Maybe I have a different perspective after seeing multiple rear bumpers get destroyed
    Harringbr99 and Stoney Ranger like this.
  8. Jan 19, 2024 at 3:58 PM
    1SilverRunner
    Tejas
    Not sure if this link will work but here’s a clip of a 4Runner with this kit installed. Along with the same shops custom tire swing out. Looks pretty slick if you ask me
    https://imginn.com/p/Ci_lJ6wtk4G/
    Harringbr99 likes this.
  9. Jan 19, 2024 at 4:00 PM
    Stoney Ranger
    Driftless Area
    '18 SR5 Nauti Blue
    1) No, I do not have a body lift. 1.5" rear, 2.0" front.
    2) Factory hitch is the same as it came from the factory. I do take it off when I go off-roading. And the spare goes on the roof.
  10. Jan 19, 2024 at 4:53 PM
    I like a dis
    Harringbr99 and Cis915 like this.
