Help with his
Discussion in '3rd Gen 4Runners (1996-2002)' started by 4unner, Feb 17, 2025 at 6:53 PM.
  1. Feb 17, 2025 at 6:53 PM
    4unner
    4unner [OP] New Member
    Monday
    2001 Toyota 4Runner SR5
    None
    Was driving 4Runner, all a sudden I felt a minor thud in break pedal, then brake got stiff and ABS & E-brake light came on. Any suggestions ?
  2. Feb 17, 2025 at 7:40 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    The parking brake light is controlled by a switch that is depressed by the lever, so it is weird it would come on if the lever wasn't moved.
    You should check the brake lines and master cylinder for physical damage. I don't have ABS, so any ABS related issues I can't help with.
  3. Feb 17, 2025 at 8:34 PM
    that'smy4runner
    that'smy4runner New Member
    Maybe the brake booster. Is it cold? They can freeze up, and its a scary thing. Don't know if that would trigger the lights though
  4. Feb 18, 2025 at 12:39 AM
    steelevo
    Utah
