Help with brakes
Discussion in '2nd Gen Builds (1990-1995)' started by Duranyoung89, Jan 15, 2019.
  1. Jan 15, 2019 at 4:36 PM
    Duranyoung89
    Duranyoung89 [OP] New Member
    Duran
    1994 green 4runner
    72 Chevy axle swap front and rear Chevy leafs front and rear Chevy 1 ton master cylinder and conversion on 35's
    I'm having a problem getting my brake system to work I switched everything over to Chevy axles and brakes and put a Chevy 1 ton master cylinder on in exchange for the stock Toyota one I got the adapter kit from sky offroad the kit came with a extension rod that goes from the brake booster to the new cylinder I installed the kit but after found that I had no play in my petal because the rod was to long I looked for a shorter rod but no one sells one so I trimmed the rod I got play so now the master cylinder has a full stroke but I went to bleed the lines and now I cant get fluid to the front lines I have checked all possibilities has any one else had this problem when doing the swap thank you
