HELP! Water Pump keeps leaking after 3 different installs!!
Discussion in '3rd Gen 4Runners (1996-2002)' started by tommyCO, Sep 13, 2022.
  1. Sep 13, 2022 at 5:30 PM
    tommyCO
    tommyCO [OP] New Member
    Tom
    1997 4runner limited 3.4L automatic
    Hey Everybody,
    I am about to lose my mind here... Very long story short:
    Replacing my timing belt, water pump, cam/crank seals, tensioner, pulleys, etc, etc on my 1997 3.4L 4runner. After basically reassembling everything the first time and minutes away from starting my truck the water pump started leaking badly once the coolant level got high enough to enter the block and water pump! I took mostly everything apart again, put it all back together for a second time and same story... Then took it apart again and re-installed for a third time and SAME PROBLEM!
    The water pump is leaking in the bottom left (if standing in front of the truck, opposite side of the thermostat) everytime.
    The first time I tried the metal gasket, no FIPG
    Second time, ONLY FIPG
    Third time, FIPG + Paper Gasket
    After looking at both the block and the old water pump closely today it appears there is some fairly significant "pitting" that occurred on the old water pump when I removed more of the old gasket from it.
    Is it possible the old water pump fused to the metal on the block over time and when I removed it actually pulled metal from the block and damaged the mating surface for the new water pump on the block?
    It seems like this may be what happened as after closer inspection the block appears to have a tiny bit of damage in the place where the leak has been persistent.
    OR - Is it possible the replacement water pump was not machined to the correct spec in that spot and buying another could solve the issue??
    Also, the old water pump WAS NOT LEAKING before doing this job. I was do for a change and trying to be pro-active.
    ANY INPUT is greatly appreciated! Thanks in advance!!
  2. Sep 13, 2022 at 6:29 PM
    Did you use an AISIN water pump?
    If not, that's most likely the problem.
    That pump also comes with a metal gasket with an integral rubber gasket.
    No gunk should be needed.
  3. Sep 13, 2022 at 7:01 PM
    Assuming pic 2 & 3 is the old pump?
    Need a gasket of some sort between there.
  4. Sep 13, 2022 at 7:14 PM
    Ahdofu
    Ahdofu New Member
    Matt
    Apologies if you have already ruled some of these already
    1. Have you confirmed that it is really a leak from the mating surface of the water pump and not from one the hoses? ex: oil cooler hose?
    2. If this is really caused by the leaky mating surface, did you assure yourself that you had removed all the old gasket material, .., etc from the engine block and bolts completely before installing the new water pump? I typically use something like a hobby knife with a straight edge to remove the old stuck on gasket material.
    3. If the mounting surface is clean and the gasket is new, then the next possibility could be that the water pump's housing is warped. Not sure whether this is easy to decipher or not by examining the water pump's contact surface where the leak is occurring.
  5. Sep 13, 2022 at 8:11 PM
    tommyCO
    Tom
    Hey everyone,
    Thanks for your reply's!
    To answer some questions and further clarify:
    - New water pump installed was Toyota part number 16100-69398
    - New water pump did come with the metal gasket. No FIPG was used, and it leaked.
    - Pic's 2 & 3 is the old water pump that come out. There was a paper gasket with FIPG on the old water pump that was removed.
    - The leak is NOT from a hose. I actually ended up replacing the oil cooler hose that connects to the water pump to be 100% certain it was not that. I can say for sure it is leaking at the mating surface of the block and water pump. All old gasket material has been cleaned and removed. Upon putting on the new water pump for the first time the surface was completely stripped and cleaned.
    - If the water pump mating surface is warped am I completely screwed?
  6. Sep 14, 2022 at 6:02 AM
    Daddykool
    This may be a bum suggestion, but since you're in so deep, would it be worth re-trying the original pump with a new OEM gasket (the one negusm mentioned) after cleaning it up really well? If that doesn't leak, it may at least tell you the block is ok.
  7. Sep 14, 2022 at 6:26 AM
    2Toys
    2Toys Imperial Star Cruiser
    Gordon
    2019 4Runner TRDORP
    This looks to me, from the pictures, to be a corrosion problem - mostly on the water pump side, but a little on the mounting face on the block. The inside edge of the removed water pump where the coolant flows is corroded. Your question about the water pump mating surface on the block being warped: not likely it is warped, but could be leaking because of the corrosion from the old water pump. There does seem to be some pitting on the block side in the picture. Maybe some Permatex applied to the area where pitting is seen and then reinstall the replacement pump with a new or serviceable metal gasket. Should you use the Permatex, you may want to let that cure a bit before filling the coolant system.
    Regarding the possibility of the replacement not being machined to spec - possible, but not likely. Especially if you bought the water pump directly from Toyota.
  8. Sep 14, 2022 at 10:22 AM
    I'd try the permatex. I'm going to agree the block looks a little beat.
  9. Sep 14, 2022 at 3:52 PM
    tommyCO
    Tom
    DaddyKool - Thanks for the suggestion. Not a bad idea to test if the block is in fact warped/damaged!
    2Toys - I like this: "Maybe some Permatex applied to the area where pitting is seen and then reinstall the replacement pump with a new or serviceable metal gasket. Should you use the Permatex, you may want to let that cure a bit before filling the coolant system."
    Dillusion - Thanks for your input as well!
  10. Sep 14, 2022 at 4:45 PM
    Not sure about the warping possibility, but I wouldnt go there until you deal with the pitting
    Do you think the leak is coming from this area? (Pitting at bottom of pic by locating pin)9558CB84-AF35-40F0-833F-D11476DD7231.jpg
    I bet this corrosion pitting spans the inside and outside of the main sealing/compression portion of the gasket. The coolant would have a straight shot out of the engine if that’s the case. If it were me, I’d focus on filling these pits with Permatex. I’ve heard thin applications are recommended, it’s probably worth researching the best way to apply it. My suspicion is that you want to build in material into those pits by spackling it with a razor blade so only the pits have permatex in.
    But please dont take my guess for it, permatex might have some specific suggestions, or even products made for that purpose.
    edit: the pitting that’s occurring in a curve shape around the locating pin actually looks like the shadow of the compressing part of a gasket. If that’s the case, the gasket wont ever be able to seal until the pitting is addressed.
  11. Sep 14, 2022 at 8:51 PM
    tommyCO
    Tom
    Thanks McSpazatron, I really appreciate your input. I think my plan is a thin application or two of Permatex on the pitting and let that cure. Then a new Aisin water pump (just to be sure) and metal gasket. Won't be able to get to it until next week, but fingers crossed!..
  12. Sep 14, 2022 at 8:52 PM
    tommyCO
    Tom
    If anyone else has any other suggestions I am all ears!
  13. Sep 14, 2022 at 9:49 PM
    If you got a TOYOTA pump from a dealer, it IS an AISIN pump.
    If you got a TOYOTA pump from Amazon or Ebay...there are counterfeits running around and sometimes you can tell because the impellers are cheaper.
  14. Sep 15, 2022 at 6:28 AM
    2Toys
    Gordon
    2019 4Runner TRDORP
    I would not let the Permatex cure without the water pump being installed. You will need a smooth surface on the Permatex to interface with the water pump to prevent leaks. The only way to get that is when the Permatex is wet.
  15. Sep 15, 2022 at 7:29 AM
    standard
    standard New Member
    Pacific Northwest
    1999 4Runner SR5 4WD
    stock so far, what could he possibly need
    The mating surface on the block should look like the mating surface on the new pump. To me it looks like the block is scored and pitted, it this correct? If you try or tried to prep the block with sand paper or steel wool, did you back this with a strait flat piece of metal? Even a scraper can cause divots if not used carefully.
  16. Sep 15, 2022 at 7:38 AM
    standard
    standard New Member
    Pacific Northwest
    if i were trying to fix this i would prepare the block surface for a coat of jb-weld flowed into the low spots and then made flat when it is cured, and then use the gasket. it will seal if it finds good mating surfaces. the problem i see with permatex is relying on it to take up the space that shouldn't be there, and i don't know how to do that without introducing permatex into the pump body. does that make any sense? it seems to me that the iron is eroded, if that's true i'd be inclined to repair the iron surface.
    negusm likes this.
  17. Sep 15, 2022 at 10:14 AM
    Permatex is fine some don't come with gaskets and tell you to use it.
    Used Permatex on my old Camry before and no issues. Just make sure its cured before starting her up.
  18. Sep 16, 2022 at 4:47 AM
    Ahdofu
    Ahdofu New Member
    Matt
    Thanks for looking into this. Since you used a Toyota part, I now very much doubt that the part is warped. Your earlier conjecture seems to be right on. Having said this I am still baffled as to why you still got a leak by adding coolant having installed the water pump with FIPG. I would have thought that the FIPG would have worked to seal that area even if it hadn't cured simply because the engine wasn't running.
    If you were to run a razor's edge on the engine block where the leak is occurring, can you confirm that all is flat and nothing is protruding? Obviously where there is pitting, the edge will just slide over it and that is OK.
    One other thought. Make sure the threads on all the mounting bolts are clean and corrosion free. This way you will not get a false torque reading in installing them.
  19. Sep 16, 2022 at 8:14 AM
    iamincrediboy
    iamincrediboy New Member
    South FL
    It looks like the original seal was on its way to failing due to the edges of your old pump and block surfaces. Like @standard mentions rebuilding that and then putting FIPG is likely your best bet. Something like this https://www.jbweld.com/product/steelstik-epoxy-putty-stick and just form it as smooth and consistent with surrounding shape as you can get. Pretty certain you arent going to clad weld right there.
  20. Sep 19, 2022 at 1:00 PM
    DaveB
    DaveB New Member
    Dave
    Central Hellinois
    97 limited
    Vehicle Modifications:
    0
    The corrosion is so thin jb weld it very smooth. The block shouldn't have any digits. Use a gasket glue on both sides when jb is cured. There is a brush on style I use. A very thin bead of permatex seal like very thin should cure it. Not sure what antifreeze you used but it's eating the gaskets I wonder what else it's eating now. Dexcool does that crap too.
  21. Sep 19, 2022 at 7:44 PM
    Yeah, I'm thinking that someone is running the wrong antifreeze. Mine at 250k miles doesn't look this chewed up.
  22. Sep 22, 2022 at 7:44 PM
    standard
    standard New Member
    Pacific Northwest
    yeah that's a good point and worth checking out. need to follow the manufacturers directions on this. On some sleeved diesels the wrong coolant can bubble against the water side of the sleeves and corrode them to the point of failure.
  23. Sep 23, 2022 at 8:33 AM
    DaveB
    DaveB New Member
    Dave
    Central Hellinois
    97 limited
    0
    Toyota metal is specific. If you run wrong coolant it will react as if it was a chevy lol. Since they love thier dexcool so much and don't warrenty when it eats the gaskets and motor early.
  24. Nov 11, 2022 at 8:03 PM
    tommyCO
    Tom
    UPDATE: Hey everyone, thanks SO MUCH to all those of you that replied!
    Just wanted to a make a follow up post... Perhaps in the future it helps someone avoid the disaster that I ran into doing my timing belt project.
    As it turns out my "Genuine Toyota" parts were counterfeit crap from China.
    Yes, shame on me for not being aware of how pervasive this problem apparently is across the internet. And not just with Toyota parts... I ordered a timing belt "kit" off ebay from the seller ppartsgarden. After 3 different installs of the water pump with it still leaking I figured out that my water pump was counterfeit and machined incorrectly. One of the corners on the mating surface with the block was not level! So no matter what I did it was NEVER going to work.
    After having this realization I looked more closely at all the other parts in the kit including; the idler roller, tensioner roller, hydraulic tensioner, and thermostat and all of them were counterfeit from what I could tell!
    I ended up re-ordering all the actual Toyota parts again from a reputable legit Toyota parts website because I did not want to install crap parts on my truck. Especially after what happened with the water pump...
    Long, expensive, and very frustrating experience later the job is complete and my truck is running great! But buyer be warned DO NOT BY "GENUINE TOYOTA PARTS" anywhere but a legitimate source! If the price is too good to be true, it's not true.
    2Toys likes this.
  25. Nov 11, 2022 at 8:07 PM
    Good to know you have it figured out.
    Counterfeit parts will even come in the correct looking OEM boxes now. They have no shame.
    Amazon and eBay should be avoided at all cost.
    2Toys likes this.
  26. Nov 11, 2022 at 8:24 PM
    tommyCO
    Tom
    Y
    Yeah negusm, you called it early on in this thread... And, ALL of my fake parts came in what looked like totally legit Toyota boxes and packaging complete with Toyota part number stickers on the outside. Not cool.
  27. Nov 11, 2022 at 9:06 PM
    roboturner
    roboturner Dead Eyed
    ‘98 NW 3.4L 5MT SR5 | '18 6MT DCSB Tacoma | '00 IJM 3.4L TRD Tacoma
    Aircabinman on eBay is the trusted source on Tacomaworld fwiw. Most others are counterfeit :mad:
  28. Nov 12, 2022 at 5:35 AM
    Daddykool
    Glad you got it fixed!
    There's something to be said for getting parts from a real, live dealership, too. Aside from the occasional oil filter, I get all my Toyota parts at a dealership - even wiper blades/refills, which are much more durable than aftermarket. I typically get 20% off just for asking, and I have a place to go for any returns (because online returns can suck sometimes). Plus, the relationship with the parts guy has paid off multiple times over the decades in tips and deals.
    2Toys, negusm and PhantomTweak like this.
  29. Nov 12, 2022 at 6:03 AM
    qcTRDct
    qcTRDct New Member
    2022 ORP KDSS
    Just out of curiosity, counterfeit parts aside, did you do anything to prep the block? Most mechanics will use an angle die grinder with an abrasive pad (a cookie cutter, as I've heard it called). I keep one in my tool box and make sure to hit any gasket surfaces with this whenever I do that sort of job.
  30. Nov 12, 2022 at 12:11 PM
    tommyCO
    Tom
    The old gasket material was badly stuck to my block. After trying with a razor blade, very fine steel wool, a putty knife, and various other things it became clear it was not going to easily come off. I ended up buying a relatively "soft" wire brush that I put on a Dewalt drill and very lightly/delicately/slowly removed the old gasket material. I know some people suggest NOT doing this but for me it seemed like the only way to get the old hardened gasket material off the block. I was very careful and do not apply any sort of heavy pressure to the block when stripping the old gasket material off and it seemed to work well.
    2Toys likes this.
