Help - Water Leak (newb)
Discussion in '5th Gen 4Runners (2010-2024)' started by T4RNewGuy, Nov 6, 2024 at 10:52 AM.
  1. Nov 6, 2024 at 10:52 AM
    T4RNewGuy
    T4RNewGuy [OP] New Member
    Today
    2021 SR5 4x4
    Hello all,
    My first post. I have a ‘21 sr5 4wd, no sunroof purchased in Feb ‘24.
    FIRST, no sunroof.
    I just figured out what is going on, but I cannot solve the problem. Hopefully you can help.
    Super dry summer and fall where I live. However, when I first purchased after a rain I’d get in and there’d be a quarter sized bit of water on the rubber floor mat. Didn’t think much of it. There was a little bit of a musty smell. Didn’t rain much all summer, or I’d be parked in a garage.
    After a recent big rain, again, quarter size bit of water on the mat, and I see some condensation on the parking break. I pull the rubber up and the carpet is soaked on the driver side. The problem wasn’t of course the small drip on the mat, but it was soaking the carpet.
    I will remediate the carpet once I solve the problem. But wondering if this is a known issue???
    I have no sunroof or roof rack mods. My door seals are clean and fresh. Door panel drains seem clear. Drains at the base of the wipers seem clear and drain freely to the ground. Windshield appears to be OEM. No wrecks or car fax issues when purchased. Also, I’m 100% sure it’s not the a/c lines. That ran on full blast all summer with no issue, it’s only after a rainfall.
    I’m stumped. Could the wiper drain have some kind of hole in between the engine compartment and dash?
    There is no issue in the engine compartment, but I do notice some rust actually starting on the steering component above the pedals.
    Help appreciated. Love this ride other than this issue.
  2. Nov 6, 2024 at 11:19 AM
    Most is always the sunroof.
    But since you don't have I'd honestly grab the water hose.
    Rocko9999 likes this.
  3. Nov 6, 2024 at 11:26 AM
    T4RNewGuy
    Today
    2021 SR5 4x4
    I’ve tried to reproduce with the hose. I can’t. It’s only there after a rain. Ugh.
  4. Nov 6, 2024 at 11:27 AM
    T4RNewGuy
    Today
    2021 SR5 4x4
    Do you know if there are drains under the driver carpet for non sun roof models?
  5. Nov 6, 2024 at 11:30 AM
    I don't think so.
    Maybe if can get hands on a smoke machine can smoke it from inside and see if anything comes out. Little better than getting everything wet.
  6. Nov 6, 2024 at 11:50 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Tape the windshield seals where it meats the body with blue painters tape. Make sure it's tight. Next rain check for water. In the mean time dry out the carpet before it mildews.
  7. Nov 6, 2024 at 1:51 PM
    T4RNewGuy
    Today
    2021 SR5 4x4
    thanks for that thought, that would at least eliminate or confirm it’s a windshield issue. I’m afraid there’s probably already some mildew. I’ll be ripping out carpet and replacing no doubt. The entire floor is soaked and it clearly has been happening for some time prior to my ownership.
  8. Nov 6, 2024 at 1:58 PM
    Rocko9999
    2011 Limited
  9. Nov 6, 2024 at 2:34 PM
    T4RNewGuy
    Today
    2021 SR5 4x4
    Thanks so much. This guy had the same issue I think. Cites a grommet by the brake reservoir and hood latch cable as the culprit.
    I know what a brake reservoir is, but grommets and cowlings are a little above my vocabulary presently. I’ll work on it though.
    TY for pointing out this old thread.
    Spare Parts likes this.
  10. Nov 6, 2024 at 3:43 PM
    It sounds like water is traveling down the hood latch cable and leaking into the cabin. Either through the rubber boot where the electrical harness and brake cable enters, or the water is traveling inside the cable sheathing, and dripping out where it connects to the parking brake pedal
    My bet is that the water is somehow getting inside the cable sheathing and just running inside it until it meets the connection at the pedal. Which would mean water is getting inside the sheathing at the latch mechanism in front, or there is a break in the sheathing somewhere along it.
  11. Nov 6, 2024 at 4:44 PM
    T4RNewGuy
    Today
    2021 SR5 4x4
    That’s a really good thought.
  12. Nov 6, 2024 at 4:47 PM
    Noodles
    Noodles New Member
    Water drain hose in the body and maybe leafs clogged the drainage under the windshield.
  13. Nov 6, 2024 at 4:50 PM
    T4RNewGuy
    Today
    2021 SR5 4x4
    Thanks for weighing in, what’s “water drain hose in the body” mean? I checked the drains at the base of the wipers, those seem very clear.
