Help! Severe phantom rubbing/grinding
Discussion in '5th Gen 4Runners (2010-2024)' started by Ongar, Aug 6, 2024.
  1. Aug 6, 2024 at 2:15 PM
    Ongar
    Ongar [OP] New Member
    Hi all,
    I bought a 2011 trail edition with ~260k miles about a month ago, and I am experiencing a severe rubbing or grinding that I cannot track down. The truck came with 285/65r17 tires that are brand new on the stock trail wheels. It has a 1.5 or 2" leveling lift on the front, otherwise the suspension is stock.
    In the city and on highways the truck drives great. The problem comes when I am driving tight twisty mountain roads, especially downhill. When I am braking going down hill and turning to the right, I sometimes experience a very sudden and intense rubbing or grinding. The truck slows down and the steering pulls in that direction. After I slow down enough the sound/sensation stops. At first I thought shit the tires are rubbing on the body mount or upper control arm when the suspension cycles.
    Just to be sure though, I got some masking tape and applied it to the areas where it could rub, and reproduced the behavior. What is shocking to me is that the tape is completely undamaged. The tires are not rubbing on the body mount or upper control arm. I checked the tires and looked under the truck to see if I could find any obvious places where something is rubbing or grinding but there is nothing.
    I really only get this problem occasionally, and if I slow down significantly before entering the turn I dont get the effect. Just today the problem happened when I was coming downhill, turning into a right corner at about 25 or 30mph and my steering wheel was at about 1/4th of a turn to the right from center. Maybe its my imagination, but it seems that when this happens, it is much more likely to happen again in a short period of time.
    I'm really stumped at this point. I want to avoid dumping more and more cash into a high mileage vehicle chasing this problem, so if anyone has a lead I would greatly appreciate you pointing me in the right direction.
  2. Aug 6, 2024 at 2:42 PM
    What tires do you have?
    Don't need to put tape anywhere. Look for clean spots in the wheel well. Tires rubbing against stuff will clean off dirt and make it obvious where its rubbing.
  3. Aug 6, 2024 at 3:22 PM
    Ongar
    Ok sure, but the tape helped me definitely eliminate rubbing as the cause.
    The tires are back country at2. Wouldn't be my first choice but hey thats what it came with.
  4. Aug 6, 2024 at 3:33 PM
    Are you at full steering lock when you hear the grinding?
  5. Aug 6, 2024 at 3:37 PM
    Ongar
    Thanks for the input, I will give those things a shot. I doubt it is the steering stops though, as the noise happens when I am nowhere near being at full lock. Brakes are definitely a good place to look, but I would have thought the problem would happen more frequently
  6. Aug 6, 2024 at 3:39 PM
    You still have front mud flaps?
    Not even sure those had.
  7. Aug 6, 2024 at 4:04 PM
    Ongar
    No front mudflaps, Not sure if they ever existed either.
  8. Aug 6, 2024 at 6:24 PM
    TrailSpecial22 New Member
    PA
    Loose LCA shifting under load?
  9. Aug 7, 2024 at 7:03 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    I was thinking this as well. A 2011 with 260K is VERY likely to have worn out LCA bushings. How do I know? I have a 2011 with 190K. They are close to being done, and I get rubbing at weird times. I have a set sitting in my garage ready to go. I just need the weather to cool off here in AZ before I tear into it.
  10. Aug 7, 2024 at 9:42 AM
    PA
    i replaced m 2011’s at 160k because you could see the bushings splitting and cam bolts were all frozen up.
  11. Aug 7, 2024 at 11:28 AM
    Rocko9999
    Rocko9999 New Member
    2011 Limited
    Are they loose at all? How can one tell by looking at them?
  12. Aug 7, 2024 at 12:38 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    Just like any other rubber bushing, they are cracked and sort of a gray color.
  13. Aug 7, 2024 at 12:51 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Keep applying tape.. you will eventually reveal where tire is touching
    Rocko9999 and TrailSpecial22 like this.
  14. Aug 7, 2024 at 7:32 PM
    Gripster
    Gripster New Member
    2016 Trail Premium
    Could it be a wheel bearing? Have you checked wheels for any play if jack it up?
  15. Aug 8, 2024 at 6:38 AM
    Garlic
    Garlic New Member
    CO
    2024 TRD Off Road
    Thread title makes it sound like you’re dealing with a freaky ghost
  16. Aug 8, 2024 at 8:21 AM
    Rocko9999
    2011 Limited
    As others mentioned-have you checked bearings and all brake components? Something on the wheel may be loose. Does it happen in both directions-left and right?
  17. Aug 8, 2024 at 9:29 AM
    totmacher
    totmacher New Member
    Daniel
    West TN
    2018 SR5 Nautical Blue
    done some stuff to it
    If it's fine around town and only happens on twisty downhill, I wonder about brakes or wheel bearings. That kind of driving is likely building more heat in those 2 areas than what normal driving would do. Check the slide pins on the brake pads for worn gouged spots. At that mileage, maybe just do front wheel bearings to be sure anyway? You might also want to do LCA bushings anyway, again just because of mileage you know they are worn.
    How does power steering fluid look? Could it be steering freaking out that you feel? Twisty road would be working steering fluid pretty good. Fluid change is easy enough. I use a turkey baster with a piece of tubing to suck old fluid out of reservoir then pour in maxlife ATF. 1 time won't get all the fluid swapped out but once may be enough to feel a difference if old fluid is burnt. You can always go back a week or month or more later and repeat to get more fresher fluid in.
