Help needed - mechanics can’t figure it out
Discussion in '3rd Gen 4Runners (1996-2002)' started by Falkor, Oct 31, 2020.
  1. Oct 31, 2020 at 6:03 PM
    Falkor
    Falkor [OP] New Member
    98 4runner
    I have a 98 4Runner and it started to lose power when speeding up. They’ve checked everything from gears, fuel lines, computer and who knows what. They are telling me to basically quit on it: however, I am attached to it although it has 373000 miles on it. I am looking for some insight or guidance.
  2. Oct 31, 2020 at 7:02 PM
    kbp810
    kbp810 rebmem wen
    I assume you had adequate fuel pressure if they checked the fuel lines? Fuel pump would still be my first assumption though. Might have enough umph left to keep it at idle and lower speeds, but it’s not keeping up when the throttles down.
    Most anything else I can think of would probably throw a code eluding to what’s going on.
  3. Oct 31, 2020 at 7:33 PM
    Try another mechanic. A weak fuel pump will do something like this. How old is the fuel pump? If it is original..worth a shot to replace it with a quality Denso.
    Tama1968 and kbp810 like this.
  4. Nov 1, 2020 at 2:55 AM
    How about air filter? It sure sounds like a fuel related problem.
  5. Nov 1, 2020 at 4:52 AM
    borimex4runner
    borimex4runner New Member
    AZ
    2019 4R ORP
    sounds like an incompetent mechanic. take it to a different shop. a real mechanic will troubleshoot it and then it would be up to you as to whether or not it’s worth it to spend “x” amount of money in it. did they do a cylinder compression check?
  6. Nov 1, 2020 at 5:52 AM
    Fourtoad
    Fourtoad Gatorgrl's Yotas
    Gatorgrl
    SWFL
    1991 V6 5 speed super clean, Black and grey
    Stock with headers and after market wheels.
    I would normally buy your logic but I can tell you all the joy we had with our Gen 2 Runner when we were sorting out her drivability issue that was NOT throwing a code and my husband is an ASE master mechanic that worked for Toyota. After many many hours and hundreds of parts and relays we put in her it ended up being the circuit opening relay and the main relay. If it had been a customer car, the labor hours would have superceded the value of the car.
  7. Nov 1, 2020 at 5:55 AM
    Fourtoad
    Gatorgrl
    SWFL
    My suggestion would be looking at putting a fresh engine in it. At almost 400,000 miles, that engine might be just worn out. Would be cheaper and better just to replace than rebuild at this point. Also check that your catalytic converter isn't failing and blocked. We did away with ours and it was new!
  8. Nov 1, 2020 at 6:03 AM
    4Runner fun
    Ryan
    Nebraska
    Just my uneducated guess. With that many miles could the catalytic converter be partially clogged? If fuel is present it must either be spark or airflow. With the always possible exception of a bad wire etc.
    Good luck & keep us posted!
    Fourtoad and borimex4runner like this.
  9. Nov 1, 2020 at 6:12 AM
    This was my thought as well. Definitely worth looking into.
  10. Nov 1, 2020 at 7:33 AM
    2000sr5
    2000sr5 New Member
    2000 SR5
    Ive had this happen in a VW. All of a sudden just no power. Idled fine, just couldnt accelerate. Easy to check. Just unbolt the header and take it for a very loud drive.
    negusm and Thatbassguy[QUOTED] like this.
  11. Nov 1, 2020 at 8:13 AM
    My 99 4Runner did the same thing when trying to speed up. Ending up being the fuel filter. Change the fuel filter and it ran fine.
  12. Nov 1, 2020 at 9:11 AM
    bear1998
    bear1998 New Member
    Bryan
    2011 Shoreline Blue Pearl Limited, ...2004 Dark Blue Sport 4.7l .
    If you think it might be the CC....just drive it at night...if its clogged...itll be cherry red....
    negusm and Fourtoad like this.
  13. Nov 2, 2020 at 6:52 AM
    Yes, CC is another culprit and easy to check.
    There are only a few things on these cars that will allow it to idle fine, have no power at speed and NOT throw codes. Which have all been mentioned here.
    Air - Clogged Air Filter.
    Fuel - weak fuel pump or clogged filter.
    Exhaust - Clogged cat.
    And honestly, with clogged air filters or weak fuel pump you probably more than likely get a misfire code at some point. (you didn't specifically say there are no codes)
    Clogged cat is the one that always seems to pop up that causes this problem. Rule that out first.
    bear1998, Thatbassguy and Fourtoad like this.
  14. Feb 6, 2021 at 6:30 AM
    RoxToy00
    RoxToy00 New Member
    rocky
    3rd owner of 2000 2whldr 4runner
    none
    My bet was clogged cat. How about an update? did you figure out the problem?
