HELP NEEDED - Electrical
Discussion in 'New Member Introductions' started by Assman69, Sep 22, 2024.
  1. Sep 22, 2024 at 7:47 PM
    Assman69
    Assman69 [OP] New Member
    2010 4Runner limited
    2010 limited 137k miles
    I have been having a ton of electrical issues the last few weeks.
    The most prominent problem is intermittently my push to start will not turn green and the car will not start. All lights works, key fob unlocks doors, car will go into acc, just won’t start. If I disconnect the battery for awhile it will start just fine. Scanned for codes and got P0504 which is brake switch A/B, P1603 which says engine stall history, and C1422 which says VSC interruption for engine convenience.
    Today I was driving and the AC light started flashing and the AC started blowing warm air, then shortly after the traction control and ABS lights came on, scanned for codes again and got B1422 which is the AC compressor, along with P0504 again.
    All of these issues are intermittent, car will be fine for a couple days, then all of a sudden these issues will occur. Any help would be appreciated!
  2. Sep 23, 2024 at 6:11 AM
    jeepster09
    jeepster09 "Old"-Member....
    Twin Cities MN
    4Runner 2008 Sport
    A work in progress.....
    On a long shot.....check the battery in your remote, maybe it's weak and having issues sending signal.
  3. Sep 23, 2024 at 6:14 AM
    jeepster09
    Twin Cities MN
    4Runner 2008 Sport
    Ahhhh duplicate post.
  4. Sep 23, 2024 at 8:33 AM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Bad battery cable and bad ground are my first two guesses. Alternator starting to fail is also possible. I would start by inspecting the cables and testing the battery and alternator.
    jeepster09 likes this.
