HELP!!!! My Wife Melted Her Passenger’s Seat!!
Discussion in '5th Gen 4Runners (2010-2024)' started by Jason71, Oct 5, 2024.
  1. Oct 5, 2024 at 4:19 PM
    Jason71
    Jason71 [OP] New Member
    Jason
    2022 Nautical Blue Metallic SR5
    2” Suspension lift, roof rack, 33” tires, blackout trim, HRE wheels
    1st post here guys, so go easy. I bought a slightly used 2022 SR5 with a 3rd row for my wife a couple of years ago. It was right during Covid when the prices were the highest. ‍♂️ I took it to a custom shop soon after and had a 2”suspension lift, 33” tires, roof rack and blacked-out trim all done. She loves it and so do I. It currently has just shy of 20k miles. Well, evidently today she decided to leave a can of OFF spray laying in the seat and melted an area approximately dead-center on the seat cover (passenger side) about the size of a dime. It looks like hell, and just wanted some input on what you guys would do. I’m currently at work, so I’ll try and post some pictures after a bit. It has Softex covers. (I think that’s what they are called)
  2. Oct 5, 2024 at 4:26 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Not that big of a deal . There’s been no change in seats from 22 to 24 . Order a new cover from the dealer and either put it on yourself or have an upholstery shop put it on .
    LCJ77 and icebear like this.
  3. Oct 5, 2024 at 4:28 PM
    OdyRunner
    OdyRunner New Member
    Did it just damage the cover? If it only damaged the cover, you can either take it to an upholstery shop, buy a new seat cover and install it yourself, or get a seat cover just for the bottom cushion. You can't place a cover on the seat back as it is equipped with side airbags.
    2ndGen22re likes this.
  4. Oct 5, 2024 at 4:29 PM
    Divorce her. That's what I'd do. Sounds like you have a very solid case. You'll definitely get 4Runner in the settlement.
    Or you can stay married to her, and every time she brings up something wrong you did, you can retort "OH yeah! What about the time you RUINED the leather seat in my beloved 4Runner!?!?!"
  5. Oct 5, 2024 at 4:32 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    Get the part number and order it from Bamwholesale .Factory part but a lot cheaper than just buying it from your local dealers parts department.
    LCJ77, icebear, raimieb and 1 other person like this.
  6. Oct 5, 2024 at 4:33 PM
    Yobruhitsme
    Yobruhitsme New Member
    Denver
    Ineos Grenadier
    Reminds me of the wife who shifted from 2Hi to 4Lo via the manual transfer case shifter while driving at highway speed.. LOLz
    Jason71[OP] and T-Rex266 like this.
  7. Oct 5, 2024 at 4:36 PM
    T-Rex266
    T-Rex266 Moderator Staff Member
    Gonna need to see pix of the damage
  8. Oct 5, 2024 at 4:41 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    This is why I don't use insect repellent on the trail. It doesn't play nice with synthetics. Another vote for OEM replacement.
  9. Oct 5, 2024 at 4:42 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    @Borracho Loco LOL
    you’re not wrong !
    Pepper likes this.
  10. Oct 5, 2024 at 4:43 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    You're lucky she didn't get any of it on the paint, it will eat up the paint badly!!
  11. Oct 5, 2024 at 4:45 PM
    Jason71
    Jason
  12. Oct 5, 2024 at 4:48 PM
    Jason71
    Jason
    This is the vehicle after the mods
  13. Oct 5, 2024 at 4:54 PM
    Spare Parts
    Spare Parts New Member
    Southern Maine
    22 LR ORP
    Runner is ruined, might as well give it away as the resale value just plummeted.
    looks like a great reason to get some seat covers.
  14. Oct 5, 2024 at 4:57 PM
    He could also do this:
    Every time his wife gets out of the truck, he can yell out "Damn baby, you farted so bad this time it burned the seat!" He has to yell it loud enough for everyone to hear it. You know, to shame her.
  15. Oct 5, 2024 at 4:58 PM
    Nick B
    Nick B New Member
    SW Florida
    2010 TE, 2024 ORP
    A new factory seat cover and you’ll be good . No more Off !
    raimieb likes this.
  16. Oct 5, 2024 at 6:06 PM
    vthoky New Member
    Can't deny... a fart joke was the first thing that came to my mind.
    I'd visit the local upholstery shop -- that may be fixable, rather than having to replace it.
    Ironguy likes this.
  17. Oct 5, 2024 at 6:08 PM
    Imdav2u
    Imdav2u New Member
    23 TRD PRO
    Nice truck. Search car-part.com, find a donor truck,cheapest way to replace the cover.
  18. Oct 5, 2024 at 6:23 PM
    Des67
    Des67 New Member
    David
    So Cal
    It happens… get a new softex lower and be done. Not a big deal…
  19. Oct 5, 2024 at 6:34 PM
    icebear Recovered Kia Owner
    You could also slap some Flex Tape on there and call it art.
  20. Oct 5, 2024 at 6:56 PM
    Beachguy
    2024 TRP ORP
    Tell her it’s $2500 to repair. Keep the excess for fun stuff. If she complains about the cost to repair, tell her, “Less bitchin’, more kitchen”.
  21. Oct 5, 2024 at 6:58 PM
    vthoky New Member
    :crapstorm:
  22. Oct 5, 2024 at 7:51 PM
    kenwrob
    kenwrob New Member
    Ken
    2000 Lmtd Elckr 2nd gen SC + 2024 ORP
    TRD Supercharger
    Pix of Wife -
  23. Oct 5, 2024 at 8:01 PM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    And that shit goes on your skin.
    nimby and CIDD like this.
  24. Oct 5, 2024 at 8:01 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    03' SR5 Sport - 12' Limited
    Rocko9999 likes this.
  25. Oct 5, 2024 at 8:05 PM
    MI-FL off roader
    Brett
    Merritt Island, FL
    Yea not so much for me. Citronella candles or one of the electronic repellants. Imo putting OFF or sunscreen on your skin is a health risk.
  26. Oct 5, 2024 at 8:07 PM
    catbrown357
    Tempe
    2011 Limited 4WD
    100% agree.
  27. Oct 5, 2024 at 9:33 PM
    Definitely the most entertaining thread in a while.
  28. Oct 5, 2024 at 10:50 PM
    4runningMan
    4runningMan New Member
    New Mexico
    So, the mosquito repellent melts vinyl. Good to know, I guess. Yikes. I'll be cutting back a little lol.
  29. Oct 6, 2024 at 4:23 AM
    Welcome. That's not bad at all. I did worse to my step father's exploder leather seats when i smoked. But as George Costanza says, " you have hand!"
  30. Oct 6, 2024 at 2:12 PM
    3JOH22A Toyota Gigolo
    It's like inhaling oxygen is a toxin that slowly kills you over 75 years or so.
