Help identifying rims
Discussion in '3rd Gen 4Runners (1996-2002)' started by blinktwice, Feb 10, 2025.
  1. Feb 10, 2025 at 12:48 PM
    blinktwice
    blinktwice [OP] New Member
    2000 4Runner Limited
    3" suspension lift 33" tires Magnaflow outlander exhaust
    Can anyone identify these rims? They came with the car but I noticed that all 4 wheels have spacers. And the rims don't appear to fit without the spacers. I'm confused as this means they aren't OEM?
    The tires are 265/70/r17 I understand stock are 16"?
  2. Feb 10, 2025 at 12:53 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar (Limited rear bumper version) Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ Apache CF220 Springs) (Rear: IMS59-50575 w/ C59-677v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Deleted DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: Sherpa Crestone Sport roof rack Aiden James Customs Gear Plate w/ Slide Out Tables Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights w/ oem style switch OVS Nomadic 6.5' Awning AVS Low Profile Vent Visors AVS Bugflector II Diode Dynamics puddle lights Diode Dynamics 921 XPR Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes (cut for rear bumper/ bash bar) AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Those appear to be 4th Gen wheels.
    Same lug pattern between the 3rd and 4th gen I think... So I doubt you're dealing with hub adapters...
    Didn't the "limited" edition of the 3rd Gen come with larger brake calipers? Is that causing the issue when trying to mount 16" wheels?
  3. Feb 10, 2025 at 1:01 PM
    blinktwice
    They are blue spacers and appear to be quality ones not some cheap Chinese ones.
    I ordered steelies w/winters from costco ordered standard 4runner size 265/70/r16 but I didn't know the 3rd gen limited had bigger calipers than 4th gen
    Thank you for the input
  4. Feb 10, 2025 at 1:03 PM
    1SilverRunner
    Tejas
    I'd bet $20 on them being 1.25" spidertrax wheel spacers.
    Do they look like this?
  5. Feb 10, 2025 at 1:04 PM
    blinktwice
    Yes they are exactly like that! Same colour also
  6. Feb 10, 2025 at 1:05 PM
    1SilverRunner
    Tejas
    They are just wheel spacers put on on achieve a wider stance.
    Are you still trying to install 16" wheels?
    Guessing since you posted about this in another thread
  7. Feb 10, 2025 at 2:17 PM
    blinktwice
    Okay I didn't remove spacers to try the 17" they just looked like they might not clear
    I ordered 16s already!
  8. Feb 10, 2025 at 2:19 PM
    1SilverRunner
    Tejas
    Nice. Once you get them on you should update the thread(s)
  9. Feb 11, 2025 at 6:48 AM
    Never heard of that. Limited was just an interior upgrade for the most part. The towing package didn't even come with larger brakes.
  10. Feb 11, 2025 at 9:02 AM
    1SilverRunner
    Tejas
    Incorrect. Certain trim models came with 297mm rotors. Others came with 319mm rotors.
    Gen 3 stuff.
  11. Feb 11, 2025 at 12:47 PM
    Those wheels came on 2nd Gen TRD sport Tacomas as well as 4th gen 4runnners.
    1SilverRunner likes this.
  12. Feb 11, 2025 at 6:27 PM
    https://www.tacomaworld.com/threads/wheel-specs.30754/
    These had +30mm offset, fine for 4th/5th gen suspension, but too high for 3rd gen, so spacers are needed.
  13. Feb 18, 2025 at 6:16 AM
    blinktwice
    So here are the 16" stock steelies ordered through costco with 265/5/r16 michelin x ice winter tires with 1.25" spidertrax spacers (thank you to members above for identifying)
    Love the colour accept the spacers add !
