Help! How to detach / unclip OEM trailer harness?
Discussion in '5th Gen 4Runners (2010-2024)' started by fastboarder, May 28, 2023.
  1. May 28, 2023 at 2:37 PM
    fastboarder
    fastboarder [OP] New Member
    rsz_unnamed.jpg Need a bit of help. I've exhausted the search function which comes up with plenty of how to's in extending the factory harness.
    My question is how to detach or unclip the 2 OEM connectors which go to the OEM 7 pin connector? Before I get mad and get start yanking I am going to take a break and ask the experts. Pic attached on the 2 connectors and connector mount. Thanks!!
  2. May 29, 2023 at 7:16 PM
    Startrek
    Startrek New Member
    what mod is it?
  3. May 29, 2023 at 9:16 PM
    skistoy
    skistoy New Member
    2022 Lunar Rock Trail Edition
    BFG KO2
    Usually they have some tabs you need to push in as you pull them apart.
  4. May 30, 2023 at 1:10 AM
    fastboarder
    For this mod I wanted to remove the small harness to solder in connecting wires for the yellow and white wires (reverse hot/ground) and a diode on the positive. Putting auxiliary reverse lights in the bumper which will operate on a switch or reverse operation. Switch is the bluetooth Auxbeam 8 gang switch.
    I found a eTrailer page which somewhat showed how. One you have to pry up, the other is more of a tab. Well camouflaged tab lol.
