Heated windshield De-icer front heated windshield
Discussion in 'General 4Runner Talk' started by 4runnerjoe72, Jan 14, 2024.
  1. Jan 14, 2024 at 4:06 PM
    4runnerjoe72
    4runnerjoe72 [OP] New Member
    joseph
    413 centennial ave
    none
    Hi
    i push my front heated windshield button to on it lights up but no heated windshield i see the heating elements on bottom of windshield,checked fuses nothing is blown is there a relay or wire connection to elements?looked in fuse box in engine compartment is there some other relay or fuse that controls this the windshield is in good condition,2012 4runner trail v-6
  2. Jan 14, 2024 at 4:53 PM
    AuSeeker
    AuSeeker Old As Dirt
    Skip
    South Carolina
    2004 Limited
    148062d1425445441-heated-windshield-2014_39e7e0c227171bb3657424bef4fbdd8710e09312.png
    The relay and fuse should be in the fuse box under the hood, look in your owner's manual it should tell you exactly which ones and where in the box they are.
    I have a 4th Gen and I'm not as familiar with the 5th Gen fuse box, but if it's like the 4th Gen there's a upper and lower section to the fuse box, so they maybe in the lower section.
  3. Jan 14, 2024 at 6:12 PM
    Rob41
    Rob41 Veteran
    Rob
    Northern Michigan
    2023 Supercharged 4Runner TRD
    Thanks for the post. I didn't even know I had that :)
  4. Jan 14, 2024 at 6:21 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    So is the relay box next to fuse box ?I checked fuse it’s not blown ,the light on button for de icer lights when I push it but doesn’t heat elements,is relay in fuse box ?
  5. Jan 14, 2024 at 6:21 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    I’ll take photos tomorrow I appreciate the help big time
  6. Jan 14, 2024 at 6:22 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    The windshield isn’t damaged the elements are under glass in front never really used the de icer function in truck
  7. Jan 14, 2024 at 6:24 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    There is a smaller separate box attached next to fuse box that maybe it I’m guessing ?
  8. Jan 14, 2024 at 6:39 PM
    4runningMan
    4runningMan New Member
    New Mexico
    I’ve never thought of it as a de-icer. More of a wiper warmer. Keeps the blade kinda soft so it does a better job clearing. Maybe.
    The defroster does a much better job of de-icing than the wiper warmer in my experience.
  9. Jan 14, 2024 at 6:40 PM
    4runningMan
    New Mexico
    I’ve also read some reports of cracked glass when using the de-icer when temps are too cold.
  10. Jan 14, 2024 at 6:56 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Ideally, I'd use the de-icer when the wiper is frozen to the window. That's a condition I mostly avoid in typical NJ fashion by flipping my wipers up when parked outside and weather is coming.
    I hope the OP's problem is just the fuse.
  11. Jan 14, 2024 at 8:26 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    I know this not the point just trying to find out why windshield heat element doesn’t work
  12. Jan 14, 2024 at 8:30 PM
    4runningMan
    New Mexico
    How do you know it’s not working? Just curious. I assume mine is working, but I’ve never been able to feel heat on the glass.
  13. Jan 14, 2024 at 8:40 PM
    4runnerjoe72
    joseph
    413 centennial ave
    none
    The glass where elements should get warm they don’t my wife has 24 rav 4 with them they get hot mine don’t
    4runningMan likes this.
  14. Jan 15, 2024 at 2:00 AM
    AuSeeker
    Skip
    South Carolina
    2004 Limited
    As I stated above...."I have a 4th Gen and I'm not as familiar with the 5th Gen fuse box, but if it's like the 4th Gen there's a upper and lower section to the fuse box, so they maybe in the lower section."
    I didn't say there were sections side by side, I said a upper and lower sections, the upper section is screwed to the lower section and it has to be unscrewed to access the lower section...but again I this is how the 4th Gen is and I would guess it's the same for a 5th Gen.
    Someone else will have to reply to help you further or you can do a search of the forum or Google for more info, that what I did to find the diagram I posted above to try and help you, now you need to do a little research yourself and read your owner's manual if you haven't done so, it has info on the fusess in it.
