Headlights not working
Discussion in '5th Gen 4Runners (2010-2024)' started by archlyte, Nov 11, 2022.
  1. Nov 11, 2022 at 5:26 AM
    archlyte
    archlyte [OP] New Member
    2016 4runner
    Hey folks, I have a 2016 4Runner. The headlights are not working. However the high beams do work. After looking at the diagram online it seems that there are two fuses, one for each headlamp. Therefore I think it’s a relay. Has anybody had this problem before? If so I need a good wiring diagram for replacing the relay. I bought it used and i’m unable to find the manual.
    thanks…
  2. Nov 11, 2022 at 9:20 AM
    Braumeister
    Braumeister Kampai, bitch!
    Bentley
    Northern MI
    2021 TRD Off-Road Premium
    Not sure about the 2016, but my 2021 has separate fuses for high and low beam lights. If you haven’t checked already, that’s where you should start.
    Also not familiar with the specific relay for 2016 headlights, but this explains how to wire a typical 4 pin relay which is likely what you’re dealing with:
    https://proelectronicsguides.com/how-to-wire-a-4-pin-relay/
    Hope this helps. Good luck!
  3. Nov 11, 2022 at 10:04 AM
    Too Stroked
    Too Stroked New Member
    Tom
    South shore of Lake Ontario
    2021 SR5 Premium
    Have you verified that the low beam filaments are good and / or you have power at the sockets? Go for the simple stuff first.
