Headlight low beam issue
Discussion in '5th Gen 4Runners (2010-2024)' started by quinteale, Nov 27, 2024.
  1. Nov 27, 2024 at 11:11 AM
    quinteale
    quinteale [OP] New Member
    Hello,
    I have this problem on my 4runner 2016 and cannot figure out what the issue is; it's even weird to describe.
    I have changed both headlight lightbulbs and the passenger side works good but the driver side is the one with issue.
    When you stand in front of the 4runner you see the bulb is on but in reality doesn't illuminate. Is there a problem with the lightbulbs? or what else can it be?
    I am not an expert on cars or anything alike so my knowledge is very minimum.
    High beams on both side work great
    Thank you in advance for any help and advice.
  2. Nov 27, 2024 at 11:26 AM
    Oakboro, N.C
    Does the problem switch over when you switch bulbs from side to side?
  3. Nov 27, 2024 at 11:29 AM
    quinteale
    Still the same problem the right side keeps acting the same way.
  4. Nov 27, 2024 at 1:48 PM
    scanny
    scanny New Member
    Ontario, Canada
    2Toys and Too Stroked like this.
  5. Nov 28, 2024 at 6:31 AM
    Do you have a photo of the low beams projecting onto a wall that will show the issue?
  6. Nov 28, 2024 at 6:38 AM
    Impractical buy
    Impractical buy New Member
    Windy City (ish)
    2015 Limited
    IMG_0270.jpg Poor ground connection?
    Dabigono likes this.
  7. Nov 28, 2024 at 1:34 PM
    Dabigono
    Dabigono Just Joined
    2020 4Runner
    Yes, definitely check resistance, especially the ground side.
