Had it less than a day and tire shop scratches a wheel
Discussion in '5th Gen 4Runners (2010-2024)' started by GrimJeeper91, Jan 25, 2024.
  1. Jan 25, 2024 at 12:29 PM
    GrimJeeper91
    GrimJeeper91 [OP] New Member
    Terry
    2024 TRD Off-Road
    Yokohama AT's, Bilstein 5100's, Talon's Garage full skids.
    The day after picking up my TRD Off-Road I went to the tire store to get some AT's put on. The first tire they broke down I noticed they pulled the valve stem to replace it. I told them the 4R is brand new, it only had 32 miles on it and they didn't need to be replaced. They went ahead and did it anyways and managed to put a 1" long scratch on one of my wheels. Needless to say, I'm not happy because it was avoidable if they would have just listened to me!
    Fast forward three weeks and I've finally been told by the company handling my claim that they will pay for a replacement wheel. It took them long enough! They will be sending me a check for the wheel and the installation. I'm thinking I should go ahead and put the scratched wheel on the spare (with the show surface facing up). Is there any reason I shouldn't do this? I'm guessing it's probably a bit wider than the steely that the spare tire is on now (which I'm assuming is a 7" rim?).
    On a side note, I just got wheel pricing my the dealer I bought it from, not the closest dealer. I didn't realize how much stealerships vary in parts pricing. Here's what I found:
    Dealer I purchased it from: $583
    Closest dealer: $694
    Another 30 minutes away: $385
    Those prices don't include tax. If you need replacement parts call around to check pricing (or Google if you have a part number).
    Rick G. likes this.
  2. Jan 25, 2024 at 12:46 PM
    Using the scratched rim as the spare is a great idea. I don't think there will be any issues with the difference in widths.
    You could also sell it online (here or FaceBook market place) for a steep discount. That way you pocket a couple of bucks. Oh, and dealerships ALWAYS have the highest prices for everything.
    Technologic80 likes this.
  3. Jan 25, 2024 at 12:55 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
    Hey OP @GrimJeeper91
    Sorry to hear that, damn, and I'm afraid it's not the first time I've heard of dealership flunky's scratching 5th Gen 4R wheels. Wow, that's frickin expensive.
    As for the spare steely, I've done a lot of research on this guy. It is a bit unclear, but some sources say your steely is the same width as your 4R trims wheels (7-1/2"). But, is that incorrect, and are they all 17x7, even on a limited?
    I missed the opportunity to measure my steel rim when I had an LT285/70 put on it. Just thinking out loud, I still have my spare off the truck in garage, I bet I could measure the width with a tape measure up to the tire laying on ground if I just take some reference measurements and minus the tire portion..
  4. Jan 25, 2024 at 1:02 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    In the event I get a flat I figured it would be nice to have a matching wheel. I'm still keeping the stock tire for the spare instead of having a 5 tire rotation and needing to deal with the TPS for the spare.
    I know there are no deals at stealerships, I just didn't expect such a large price difference for the same part from dealers 30 minutes apart.
    Something to keep in mind if you need to replace a wheel or any other part. If insurance is covering it and making you do the legwork to document the replacement cost then find the highest price you can and pocket the difference. Unfortunately I didn't claim as much as I could have. If you're out of pocket then obviously you're finding the best deal you can.
  5. Jan 25, 2024 at 1:11 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    It was a tire shop (America's Tire), I'm not crazy enough to have a dealership install new tires. I'd hate to think what they would charge!
    I figured the steely was either 7 or 7.5" so I'd be surprised if there was a problem putting my scratch wheel back there.
    Spare Parts likes this.
  6. Jan 25, 2024 at 1:11 PM
    AFIK, Limiteds come with a matching spare wheel, along with TPMS already installed.
  7. Jan 25, 2024 at 1:13 PM
    Sorry for your troubles on a brand new ride. Sometimes I wish I had all steel wheels, so I could just paint f*ckups with a spray can.
  8. Jan 25, 2024 at 1:17 PM
    1SilverRunner
    1SilverRunner My boy, blue
    Tejas
    22 TRD Off Road Premium
    Front Bumper: C4 Fabrication Low-Profile Bumper Warn Evo10-S Winch w/ Warn wireless adapter Extreme LED dual color light bar w/ Cali raised LED OEM style switch Bumper Cover Trimmed For Clearance Rear Bumper: 80% Off Road Rear Bash Bar Armor: RCI Skid plate package C4 Gas tank skid RCI Rear diff skid RCI Shock Skids RSG Angled/ Plated Sliders Total Chaos Cam Tab Gussets Total Chaos Spindle Gussets 41.22 Hitch Slider Suspension: Dobinsons IMS long travel shocks: (Front: IMS59-50574 w/ C59-352 Springs) (Rear: IMS59-50575 w/ C59-675v Springs) Apex Chassis Tie Rod Assemblies (KIT410) Apache Off Road UCAs Apache Off Road HD Rear Links (Upper and Lower) Apache Off Road Rear Sway Bar Links Dobinsons Track Bar Front Sway Bar Delete DuroBumps Rear Bump stops PerryParts Front Bump stops DRKDSS Track Bar Correction kit Dobinsons Diff Drop Wheels/ Tires: RRW 17x8.5 -12 RR6-H Wheels 285/75/17 Falken A/T4W 1.25" SpiderTrax Spacers BMC, Pinch Weld Folded. C4 High Clearance Fender Liners Performance: OTT Tuned Scan Gauge II for Temp Monitoring Yota Shop Diff Breather Storage Solutions: LFD Cross-Bars Aiden James Customs Gear Plate w/ Slide Out Tables *Backordered. Rado Designs Molle storage panels and top shelf Glove Box organizer Center Console organizer Interior: Diode Dynamics LED Interior lighting (Warm white ftw) Meso Customs Hatch lights Meso Customs Door Handle Covers Ram ball mount for Garmin In-Touch Mini II FitCamX Dash Camera Scosche phone mount Weathertech floor matts Misc: Nano Ceramic Tint (Including windshield and sunroof) Midland MXT575 and Ghost Antenna Cali Raised LED 27W Ditch Lights OVS Nomadic 6.5' Awning AVS Low Profile Vent Visor AVS Bugflector II Diode Dynamic puddle lights LasFit Reverse lights LED license plate lights Ark Splash Guards Ark Mud Flap Deletes AJT Push-To-Start Button +Midland handheld GMRS radios, Baofeng UV-5R Ham radio, recovery gear, water purification system, lifeboat food rations, trauma kit, fire extinguisher and fire starting kit stay on board.
    Stealership is right. These price fluctuations are wild.
    Good call on putting the outside(show side) of the wheel up. If you put it the other way the hanger would damage the wheel; And the wheel is more likely to catch mud and other junk.
    I've had my spare out a couple times now. I can't think of a reason this wouldn't work.
    My only issue was on the 7" wide spare wheel there wasn't enough offset to clear my UCA with a full sized spare tire(285/70/17). It would have required a spacer if I were to use it on the front. It also hung very low which worried me since when I offroad I'm already hitting my rear bumper all the time... wanted to preserve as much departure angle as I could.
    Long story short I ended up putting a skinny 33" in there (255/80/17) as it works with my SPC upper control arms and won't require a spacer. It also doesn't hang as low.
    You would be avoiding the first problem because you have a matching wheel size. It may impact your departure angle a bit though.
  9. Jan 25, 2024 at 1:22 PM
    Time to find a new tire shop.
    I just recently had new tires put on my 1st gen Tacoma. I found a good price estimate at a tire shop and then presented it to my service advisor at the dealership I use. He matched the price and I preferred Toyota install the tires. They always get the balance right.
    For me it pays to have good repor with the local dealership if possible.
  10. Jan 25, 2024 at 1:39 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I've been working with this America's Tire for probably 20 years and do have a good rapport with them. Just an unfortunate screw up on their part. Had they left the valve stems alone like I suggested there wouldn't have been any problems.
  11. Jan 25, 2024 at 2:15 PM
    It happens, don’t understand why they would want to replace a TPMS on a brand new car.
    That’s a head scratcher.
  12. Jan 25, 2024 at 2:25 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    They only replaced the valve stems. They moved the TPMS from the factory stems to the new stems. And yes, it is a head scratcher. Why bother when the vehicle is so new. All you do is add additional risk to the job.
  13. Jan 25, 2024 at 2:40 PM
    Bluesky 07
    Bluesky 07 Not a New Member
    Russell
    Northern Georgia
    Silver ‘07 Sport V6 4WD @ 265K miles
    “Deep” Satoshi grille | X-REAS delete / TRD Offroad front springs & Bilstein 4600 shocks + FJC rear springs | Weathertech front & rear mats | Tinted front windows | Floor Armor cargo mat | TPMS bypass | LED interior, tag, & reverse lights | BlueSea Systems console USB power ports | Gentex 453 autodim mirror w/Homelink & compass | Kenwood DDX373BT HU + Audiovox backup camera | Fumoto F-103S | Bazooka tube subwoofer | Kenwood speakers & KAC-M1804 amp | Philips H9/9011 headlight bulbs | Rexing V1 Gen3 dash cam | Map light mod | Breather mod | Off-road Nav Setup | Power Stop Z36 brakes | OBD Fusion diagnostics
    Try parts.toyota.com and it will allow you to see the online pricing for dealers in your area. Some offer discounts, others sell at retail. I buy the majority of my replacement parts that way and pick them up at the dealer and they also often offer free shipping over a specific amount.
    I scraped both passenger side wheels in a rock garden at Windrock Park a couple of weeks ago. That’s why I have Sequoia takeoffs I bought for $200 on FB Marketplace on my ‘07. And why I’ll drive it forever instead of dropping $50K on a new one that comes with the stress of worrying that somebody may ding a door.
    Just an observation, and likely an unpopular one - knowingly giving a higher price and pocketing the difference is one reason premiums are going up. I get the motivation, most people hate insurance companies and often not without reasons, but nothing is free. They’re not eating the difference, they’re passing it on to their customers.
    djwantke likes this.
  14. Jan 25, 2024 at 2:52 PM
    Deuxdiesel
    Deuxdiesel New Member
    SE MI
    '18 SR5P
    Discount/America's is why I have aftermarket wheels on my 4R and my wife had an extra set of OEM wheels for her GTI. They gouged all four of the originals on both vehicles. I was able to keep the replacements as well as the damaged one's for the GTI. They employ lots of low skill workers who don't really care about the quality of their work at my local DT.
  15. Jan 25, 2024 at 2:54 PM
    Bluesky 07
    Russell
    Northern Georgia
    I’ve had really good luck with DT for 20+ years. The only issue I’ve ever had was a broken lug on my old Xterra. The manager referred me to a shop and it was fixed at their expense the next day.
  16. Jan 25, 2024 at 2:58 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I'm getting it from the dealer I got the quote from and provided to the insurance company. This is the dealer that I bought the 4R from that's 30 minutes from me. Had I quoted the dealer 5 minutes from me the wheel would have cost more so I ended up saving the insurance company money.
  17. Jan 25, 2024 at 3:14 PM
    Bluesky 07
    Russell
    Northern Georgia
    Right, you didn’t do it, but you recommended that other people do it. I could’ve worded that better. In any case, I’m not on a high horse or whatever, not saying it’s right or wrong, just stating the facts of how such things work. In fact, what really surprises me about insurance companies is that they don’t even seem to care what you actually spend vs. what they give you. I had hail damage on my brand new Xterra back in 2002. Insurance gave me a check for $1700 but I went with paintless dent repair and it only cost me $1100. They kind of laughed at me when I called and asked where to return the difference. Boy, was I naïve. LOL
    BTW, I was astounded at the PDR job. The truck was black and it was absolutely flawless. You couldn’t tell anything had even happened to it except for one little spot on the curve between the roof and the side that they just couldn’t get to. But the dent was tiny, and you wouldn’t ever see it unless you were looking.
  18. Jan 25, 2024 at 3:51 PM
    Redwood
    Redwood New Member
    2022 4Runner TRD Off Road
    Besides insurance claims my son has '20 Tundra pro with the BBS forged Trd wheels. One rim has some road rash where he scrapped a curb just cosmetic. Heard that some places can repair and refinish these rims. These rims are pushing $800 a piece. Anybody have experience to share in repairing these rims scratched or otherwise. Have heard it can be done if you can find the right place.
  19. Jan 25, 2024 at 3:59 PM
    steelevo
    Utah
    This is an unfortunate accident and America's/Discount Tire hopefully paid the bill for a new wheel. This is why a tire-changing machine is the next garage toy on my list. Make sure to buy an additional TPMS sensor if you're going to put one up in the spare location.
  20. Jan 25, 2024 at 4:49 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    I initially provided the part number to the insurance company so they could find out what it costs. They pushed it back on me to get quotes for everything and provide the documentation. After waiting three weeks I get to drive 20 minutes each way to the dealer to pick up the wheel (at the replacement cost provided to insurance) and then spend another hour at the tire shop getting things swapped out. I had the dealer quote both the wheel and labor but I'm taking it back to the tire shop. My time isn't free so I don't feel guilty about coming out ahead on the labor side. Particularly since I'm saving the insurance company about $250 by not getting it done at the stealership that's five minutes from my house.
    That's really good feedback on the PDR! I had a baseball ding in my prior car that bugged the crap out of me for years. I wish I would have gone this route!
  21. Jan 25, 2024 at 4:54 PM
    GrimJeeper91
    Terry
    2024 TRD Off-Road
    They just turned it into insurance. My America's Tire has taken very good care of me over many years and this is the first time there was a problem. It was an unfortunate accident and they did their part to get the claim filed quickly so no complaints.
    steelevo[QUOTED] likes this.
