Group 31 battery installed with battery terminals
Discussion in 'Audio & Video' started by blue4runner, Apr 11, 2020.
  1. Apr 11, 2020 at 4:37 PM
    blue4runner
    blue4runner [OP] New Member
    Geoff
    2018 blacked out Limited
    matching front window tint, chrome delete, TRD off road wheels with 275/R17 K02's
    Getting closer to running the 1/0 power wire for my new audio system. Installed the Group 31 Odyssey and picked up these 6 terminal solid copper battery terminals for all connections now and later. Not sure where I am going to mount the main fuse yet.
    Oldtoyotaguy likes this.
  2. Apr 12, 2020 at 11:04 AM
    Oldtoyotaguy
    Oldtoyotaguy Paid cash for it
    2018 Toyota 4 Runner Offroad
    Wow, that battery looks great! Where did you get the connectors?
  3. Apr 12, 2020 at 11:12 AM
    blue4runner
    Geoff
    SKy high car audio. They have aluminum terminal blacks as well
  4. Apr 13, 2020 at 7:43 AM
    Oldtoyotaguy
    Are stud terminals an option with Odyssey or is that how they come?
  5. Apr 13, 2020 at 8:16 AM
    They come with regular post as well.
    Oldtoyotaguy[QUOTED] likes this.
  6. Apr 13, 2020 at 7:38 PM
    Starr
    Jonathan
    SouthEast Maui
    Looks very pretty, but makes me think about when the box wrench drops on it.
    photo8, Desert Armor and Oldtoyotaguy like this.
  7. Apr 13, 2020 at 7:41 PM
  8. Apr 13, 2020 at 9:39 PM
    blue4runner
    Geoff
    Good point. I think I will whip up some sort of cover out of some 1/8 ABS sheet. Had not thought that far ahead.
    Starr and nimby like this.
  9. Apr 15, 2020 at 6:00 PM
    Starr
    Jonathan
    SouthEast Maui
    That will work. Big shrink tubing, Scotch 88 tape or pipe insulation wrap, anything. I've done too much damage this way myself, but then I have lived off of big big lead acid batteries for a few decades.
    blue4runner[OP] likes this.
  10. Mar 23, 2021 at 7:16 AM
    Toyota.ARK
    Toyota.ARK New Member
    2021 Magnetic Gray TRD-ORP
    How does the factory alternator work with the group 31? I’m thinking of doing one soon.
  11. Mar 24, 2021 at 1:18 AM
    blue4runner
    Geoff
    I think a stock alternator is fine with a group 31 AGM. I do think that a voltage booster couldn't hurt as AGM batteries need around 14.7 volts or so the literature says.
    I swapped out my alternator recently and added a second group 34 battery connected by a blue sea ML ACR. my car stereo seems happy too, no more light dimming.
    Toyota.ARK likes this.
  12. Mar 24, 2021 at 5:05 AM
    Desert Armor
    Desert Armor New Member
    www.DesertArmorShop.com
    Toyota’s
    The stock alternator works fine to charge the AGM batteries. You will need to top it off though with a charger or solar panel from time to time. The battery with the OEM alt only charges the battery to like 95% or something.
    If you OV Tune the runner (once it gets released, unless it is) you can adjust the alternator setting to make it charge an AGM battery to 100%. The alternator output is computer controlled on Toyota’s.
    Toyota.ARK[QUOTED] and diverdon like this.
  13. Mar 25, 2021 at 7:07 PM
    Toyota.ARK
    Does it require a new tray? Or can you use the factory?
  14. Mar 25, 2021 at 8:24 PM
    Kyblack76
    Kyblack76 New Member
    Layton, Utah
    18 TRD O.R
    Mmm hmmm.
    Alsoz i know Jon Rabe, (^^^ up above) at SkyHigh real real well. (Car audio days)
    Desert Armor likes this.
  15. Mar 25, 2021 at 8:26 PM
    Desert Armor
    Toyota’s
    In a Tacoma you can fit the battery in the factory tray. I’m sure it’s the same in the runners.
  16. Mar 26, 2021 at 1:55 AM
    blue4runner
    Geoff
    I had to get a tray that would fit the length of the group 31 odyssey which is 13" long and requires longer j hooks as well. I just ordered a generic battery tray off Amazon and longer j hooks and a battery hold down clamp. I think that all together it was like $50. I suppose you could put a group 31 battery on a OEM tray but it does not fit in the tray.
