Grill conversion to trd Pro from off road
Discussion in '5th Gen 4Runners (2010-2024)' started by 4Runer, Feb 11, 2023.
  1. Feb 11, 2023 at 4:03 PM
    4Runer
    4Runer [OP] New Member
    2022 TRD Off Road 4 Runner
    22 TRD of road converted grill to trd pro style. Please see photo. Seems that the radiator to grill is too short
  2. Feb 11, 2023 at 4:51 PM
    Is that an OEM part or a Chinese take off?
  3. Feb 11, 2023 at 5:24 PM
    4Runer
    It’s OEM I lgot it from Toyota
  4. Feb 11, 2023 at 5:28 PM
    wdsteven
    wdsteven New Member
    if everything else looks good and bolts up just put a piece of flat stock with 2 holes in it to bridge the gap and bolt it in.
  5. Feb 11, 2023 at 5:30 PM
    4Runer
    I thought about that too
  6. Feb 11, 2023 at 5:31 PM
    Maybe that grill insert isn’t seated in correctly. I don’t recall others having the same problem. Hopefully someone on this forum with the same upgrade will chime in.
    It does look good.
    5thGin and suaveflooder like this.
  7. Feb 11, 2023 at 5:33 PM
    4Runer
    Everything seems to be perfect except that. It’s almost like the other bracket needs to be changed out to be longer
  8. Feb 11, 2023 at 5:34 PM
    wdsteven
    wdsteven New Member
    I thought about that too but in the picture it does look to be fitting good.
  9. Feb 11, 2023 at 5:48 PM
    5thGin
    5thGin New Member
    5th Gen
    Everything should line back up. I had some tabs that I had to slide over that previously clicked in. After that, mine went smooth.
    Slopemaster likes this.
  10. Feb 11, 2023 at 5:51 PM
    wdsteven
    wdsteven New Member
    Measure that tab on the old one you took out and see if it is the same length.
  11. Feb 11, 2023 at 5:53 PM
    suaveflooder
    suaveflooder New Member
    Send it back if it’s doesn’t fit. I have a venture (basically an ORP) and had zero issues with things lining up
  12. Feb 11, 2023 at 6:31 PM
    4Runer
    Stressful
  13. Feb 11, 2023 at 6:43 PM
    wdsteven
    wdsteven New Member
    Take a deep breath ... exhale
    Just take a moment to measure the tab length that does not go in place compare it to your original one and if the same it is possible misaligned something take time to redo it if it is shorter and everything else look and fits good it is not a big deal to make a little flat bracket to bridge the gap and be done with it that is what I would do but you can always return it and hope for the next to fit but??
  14. Mar 6, 2023 at 12:25 PM
    Windplr
    Windplr New Member
    Coos Bay, Oregon
    2022 ORP Lunar Rock
    Just wondering if you were able to figure out what the issue was? I have an oem TRD Pro grill on the way for my '22 TRD ORP.
    Also looking for opinions. Is isopropyl alcohol to clean the surface of the painted piece that receives 'garnish' sufficient? Or should I use an adhesive primer?
    4Runer[OP] likes this.
  15. Mar 6, 2023 at 12:27 PM
    4Runer
    Yea they ordered the wrong parts at toyota. It was supposed to be a 2022 and the guy ordered a 2015
    Captain Spalding, 5thGin and Windplr like this.
  16. Mar 6, 2023 at 12:46 PM
    Thepremier141
    Thepremier141 Member
    Nate
    Northern California
    ‘22 SR5P
    Alcohol to clean the surface will be fine.
    Windplr[QUOTED] likes this.
