Going to the beach with stock HT tires?
Discussion in 'General 4Runner Talk' started by Aniki, Sep 29, 2021.
  1. Sep 29, 2021 at 7:17 AM
    Aniki
    Aniki [OP] New Member
    2021 Metallic Gray Venture
    Got the new Venture with HT stock tires. Is it possible to drive this on the beach after airing down? I just find it a waste to switch it out to AT for now, only have 700miles on it. Thanks.
  2. Sep 29, 2021 at 7:29 AM
    You should be fine with a little common sense.
    Aniki[OP] likes this.
  3. Sep 29, 2021 at 7:34 AM
    It's not hard to sell stock tires when they are new. I have no experience with stock tires as I sold them right after I bought mine. I post them on FB market place and Craigslist.
  4. Sep 29, 2021 at 7:58 AM
    fajitas21
    fajitas21 New Member
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Stock tires don't look like much but do pretty well in the sand if you stay on harder pack. Air down, don't go somewhere alone if you're not sure, and consider the tides when you traverse a place so you're not stranded when high tide rolls back in.
    LandCruiser and Aniki[OP] like this.
  5. Sep 29, 2021 at 8:17 AM
    Aniki
    Thanks for the tips. Yeah I’m not planning anything crazy, just driving down to a fishing spot. From what Ive read there are somewhat designated areas/lanes to where you’re allowed to drive into, so I’m assuming the sand should be packed.
  6. Sep 29, 2021 at 8:25 AM
    fajitas21
    Lee
    Collierville, TN
    2020 ORP
    Custom scratches
    Yea in those cases you'll likely be just fine. I would, however, bring you a tow strap. You might need it. You might find someone else needs it. Either way, cheap insurance.
    *NOTE* If you pull someone else out. DO NOT DO IT IN REVERSE. That gear is not meant for shock loads.
  7. Sep 29, 2021 at 11:15 AM
    Rich60
    Rich60 Fishin' beats workin
    Richard
    Maryland
    2021 4Runner Trail Edition, 2008 Taco DCSB OR, 2008 4Runner V8 Sport
    Best advice is to always air down to @20lbs, bring a tow strap, a shovel, unditching boards, and a piece of wood suitable as a base for a jack. Don't always count on the sand to be packed down or consistent from one area to the next. Its sand for god's sake.
    Good luck and have fun. The HT tires will be fine - an overly aggressive tire tread can get you into trouble.
    Rich
  8. Sep 29, 2021 at 4:17 PM
    Aniki
    Good point about the sand, they always shift. I got all mentioned recovery gear aside the track pads. Still researching for a decent one aside from max trax. Do you have any recommendations? Thanks.
