Going from sliders to steps…?
Discussion in 'General 4Runner Talk' started by Jackstraw, May 26, 2022.
  1. May 26, 2022 at 6:36 PM
    Jackstraw
    Jackstraw [OP] New Member
    Matt
    2018 Pro Trickie Woo
    I’ll be honest with y’all - I feel a little sheepish asking this question but I’d like to know what my options are for removing welded on sliders and / or whether or not there’s the option to add steps to the sliders? We purchased the rig used and the sliders were already on it. Of course they add to the “off road cool factor” but the runner is my wife’s DD and the sliders are not helpful as steps; in fact, they’re more of hindrance. Do any of you know if there are steps that I could bolt onto the sliders, even if that means compromising their structural integrity? If there’s no such animal, would a sawzall be ok to cut the sliders off, or probably best to have a shop do it? If I remove the sliders altogether it’d be nice to be able to sell them.
    Any insight is appreciated.
    grizzlypath likes this.
  2. May 29, 2022 at 10:32 AM
    BionicRandy
    BionicRandy New Member
    Randy
    TX Hill Country
    Lots of goodies
    Ouch. Having cut welded-on sliders off a Tacoma once, I would recommend trying some bolt on steps first. It is a lot of work grinding the junk off the frame after the sliders are cut off and the sliders will be buggered up and thus may be hard to sell. I don’t have the link, but there is a thread about this somewhere on here. I think N-Fab makes bolt ons for sliders.
    Jackstraw[OP] likes this.
  3. May 29, 2022 at 10:38 AM
    kolter45
    Denver
    Inferno Pro & BRM Sport
    Honestly I’d keep them. It’s a pain in the ass because you’ll have to have a shop do it if you want to put steps on. It needs to be removed correctly. Then the frame will need some TLC & anti rust paint before your able to bolt to the frame again. Good Luck!
  4. May 29, 2022 at 1:25 PM
    As mentioned, you probably wont be able to sell them…too much extra work to re-fabricate them to be able to mount them up again.
    The expanded metal welded onto the stepping area looks like a good idea, but in reality they turn out to be cheese graters for your pants/legs when you are getting out. If that is what is bothering you, you could have someone remove them by carefully grinding off the welds on the expanded metal pieces. You could have some flat plates welded on top as steps after, then repaint the sliders. It sucks, you'll have to repaint them while on the vehicle since they’re welded on.
    For the life of me, I don’t understand why anyone would weld these to the frame on a 4runner. There are so many threaded bolt holes that work perfect for bolt ons. In this case, seeing how tubes ends are directly welded onto the side of the frame rail, I bet bolt on sliders with plenty of backing plates area would be stronger. Those tube ends look like they would deform the sides of frame of they took on too much weight.
  5. May 29, 2022 at 5:11 PM
    Jackstraw
    Matt
    Thanks BR, I appreciate hearing this. I’ll try looking for those N-Fab steps and thread
  6. May 29, 2022 at 5:31 PM
    Jackstraw
    Matt
    The truck is my wife’s DD and the sliders are too high to practically use as steps so she has to go over them. I’m a tall guy at 6’6” and it’s a bit of a hassle for me, so I can imagine what a PITA it is for her at 5’6”.
    The truck is a 2018 Pro that we bought used. The previous owner installed a CBI bumper, winch and the sliders and to be quite honest with you it was an impulse buy on my part. She was very content with her Hyundai Tucson, but I’d become obsessed with getting a 4Runner. Of course, welded on sliders just added more “cool” factor and I felt they added value but didn’t take into consideration her being the one having to get in and out 4-6 times a day. We both love the rig but are now willing to sacrifice my dreams of fearlessly bombing through rock gardens for my wife’s convenience.
    BionicRandy likes this.
  7. May 29, 2022 at 5:46 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    It’s hard to tell from the pictures and I’m totally not an expert in this area. But would it be possible for a fabricator to weld a top plate on these without removing them? Making them more functional as a step? Maybe someone else can chime in. (Don’t beat me up)
  8. May 29, 2022 at 6:11 PM
    Jackstraw
    Matt
    If anything, steps would need to be welded on under the sliders. The problem is the sliders are too tall. The truck has a slight lift and is on 33s. It’d be easier to get in and out without the sliders because as it is now you have step over the sliders to get in (it may sound weird but that’s easier than stepping on them to get in and out). Thanks for spitballing though, that’s why I posted here looking for ideas.
    NOS4A2-1[QUOTED] likes this.
  9. May 29, 2022 at 6:46 PM
    maybe if nfab makes a bolt on step, you could take them off for rock gardens ;)
    Real sliders (as opposed to those designed for stepping) can be a pain in the butt for getting in and out, so I get it.
    It took me a good few months to figure out my preferred ingress/egress routine :laugh:
    But at 5-11, it’s probably a bit easier for me than someone of your wife’s height.
    Thankfully, my wife only occasionally uses the 4runner. It’s my DD, so I still hold on tight to my rock garden bombing dreams. :anonymous::D
  10. May 29, 2022 at 7:15 PM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    Just an idea: take a piece of 2” wide 3/16” strap and weld a little stirrup underneath that she can step on. It just needs to be wide and deep enough for the ball of her foot. Stick it on with some self tappers so you can move it until you determine the best spot for it, then make it permanent. If it gets bent up bombing rock gardens you can just bend it back down.
    NOS4A2-1 and Jackstraw[OP] like this.
  11. May 29, 2022 at 7:27 PM
    Jackstraw
    Matt
    I thought of that - I’m glad you mentioned it. I wasn’t sure if it would work but now I’ve got a second opinion. And if it doesn’t work I can blame someone else ;)
    Seriously though, thanks BR:cheers:
    BionicRandy[QUOTED] likes this.
  12. May 29, 2022 at 7:39 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
    Got you, that makes it more clear. My truck isn’t lifted but I just removed my factory steps because I kept scraping the back of my leg getting out of the truck and I really didn’t need them. I installed the Toyota sliders instead because they they are tucked up close to the body. No issues getting in and out. Good luck, post up your solution when you get there.
    Jackstraw[QUOTED][OP] likes this.
  13. May 29, 2022 at 7:53 PM
    NOS4A2-1
    NOS4A2-1 New Member
    NY
    2020 Venture
  14. May 29, 2022 at 8:04 PM
    Jackstraw
    Matt
    NOS4A2-1[QUOTED] and BionicRandy like this.
  15. May 31, 2022 at 8:13 PM
    grizzlypath
    grizzlypath New Member
    2020 ORP-KDSS
    If you're handy/capable with a grinder I'd just cut them off and resell them online. Anyone with some fab experience (or a shop) could easily re-use those sliders. Then I would buy some steps for the 4Runner.
    >weight reduction
    >makes it easier to get in/out
    >less dirty pant legs
    I would think any shop would be able to remove those for you too, doesn't look hard at all.
    Jackstraw[OP] and BionicRandy like this.
  16. May 31, 2022 at 8:55 PM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    It can be done. It is not fun unless you like running a grinder for hours. Grinding welds and the remaining dom tubing off the frame is hard. It will take several hours and probably four or five grinder wheels and flap discs to accomplish. The labor cost for a shop to do it will be very expensive. I only had to grind the welds off of 4 locations on my truck and it was a ton of work. lol His are welded on in 10 locations (those are REAL sliders!), so you can do the math.
  17. May 31, 2022 at 9:11 PM
    Nope. You're assuming there's a leg going to the frame at each of the outer horizontal tubes, but those are just attachment points for the outer portion to the square rail. I only see two welded tubes - there may be three. 'REAL' sliders have four legs attached to the frame.
  18. May 31, 2022 at 9:36 PM
    ElectroBoy
    ElectroBoy Ad astra
    Bay Area, CA
    How about just cutting/grinding off the sliders, you don’t have to make it real pretty and flush.
    Then install OEM running boards to use as steps.
  19. May 31, 2022 at 9:48 PM
    My thoughts exactly. Once the steps are on, you'd never see the frame. As long as it is painted & rust proofed. I don't see the OP ever wanting to attach anything to a flat frame down the road.
  20. May 31, 2022 at 10:00 PM
    BionicRandy
    Randy
    TX Hill Country
    Lots of goodies
    Yeah I assumed they’re all welded on. If I was welding sliders on I would weld all of them! lol The plastic factory steps are very functional. As long as you get factory ones that bolt to the body and don’t mind some yuck stuck on the frame.
  21. Jun 8, 2022 at 2:29 PM
    UofLCardfan77
    UofLCardfan77 Large Member
    Elizabethtown, Kentucky
    There are some bolt on side steps but I'm not sure if they would extend far enough out and down from the sliders to actually work. You could order them from Amazon and if they didn't work just send them back.
