GLOVE BOX DOOR REMOVAL
Discussion in '5th Gen 4Runners (2010-2024)' started by scott1387, Apr 18, 2022.
  1. Apr 18, 2022 at 10:50 AM
    scott1387
    scott1387 [OP] New Member
    scott
    2014 4runner limited
    I NEED TO REPLACE MY DAMAGED GLOVE BOX DOOR. CAN ANYONE PLEASE HELP ME TO REMOVE AND INSTALL. I PURCAHSED A NEW ONE FROME TOYOTA. KINDA PRICY BUT MY WIFE WANTS ME TO REPLACE.
  2. Apr 18, 2022 at 2:17 PM
    Surly Shawn
    Surly Shawn New Member
    Illinois
    2021 Silver TRD Off Road
    Gobi Ranger Rack, Victory 4x4 Molle Panels, Strawfoot Window Covers, R4T Blackout Emblems, USR LED Interior Lights, TRD Cold Air Intake...
    icebear, esnone and Doubleduty like this.
  3. Apr 18, 2022 at 2:59 PM
    08TXRunner
    08TXRunner New Member
    '20 SR5P
    HAVE YOU TRIED TO TAKE IT OUT YOURSELF?
    4runningMan likes this.
  4. Apr 19, 2022 at 6:42 AM
    scott1387
    scott
    My 4runner is a 2015 limited.. I looked at taking it out just not sure what to to remove..There is a yellow pin on right side of glove box.
    Nor sure if that has anything to do with it..Thanks Shawn but that glove box is from early years. I also have a 2006 4runner, no problem on it to remove glove box door
    Surly Shawn likes this.
  5. Apr 19, 2022 at 3:59 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    I pulled the glove box and surround on my 2021 OR to route a front mounted camera cable thru the firewall to the Head Unit this weekend. I followed the instructions on the link below to get the job done.
    It’s fairly straight forward and the only tools needed included a trim panel remover, Flat Blade and Phillips Screwdrivers and a 10mm socket.
    You will remove the passenger side sill plate, the passenger side kick panel, the knee airbag and then the glovebox assembly. I was able to get everything out in about 15 min going slowly. Everything went back together smoothly… Hope this helps you get your project done.
    Cheers,
    Bob
    4runningMan, Surly Shawn and MeefZah like this.
  6. Apr 20, 2022 at 6:22 AM
    scott1387
    scott
    Thanks for the info..sounds like alot just to replace the door..I will try to follow those steps posted in the link this weekend.
    wyldrr89, grizzlypath and Surly Shawn like this.
  7. Apr 20, 2022 at 6:38 AM
    Surly Shawn
    Illinois
    Good luck! Keep us posted.
  8. Apr 10, 2024 at 7:33 PM
    4Runner007
    4Runner007 New Member
    2021 4 runner Limited
    2” level front
    Hi yall! Need to replace my glove box door on my 2021 limited. I don’t see a link you referred to BobbyB. Any chance you can send it my way????????
  9. Apr 10, 2024 at 9:33 PM
    Do you not see the link in post #5?
  10. Apr 10, 2024 at 10:00 PM
    4Runner007
    2” level front
    I don’t for some reason…
    glwood54 likes this.
  11. Apr 11, 2024 at 6:04 AM
    Now showing?
  12. Apr 11, 2024 at 6:10 AM
    4Runner007
    2” level front
    Yup! Got it! Thank you!!
  13. Apr 13, 2024 at 4:37 PM
    Doc's16SR5
    Doc's16SR5 New Member
    '16 4runner
    none yet
    i just did this yesterday to get access to the gray garnish panel that is cracked, as i'm sure everyone else's is also, for all years. this is a toyota problem and i am going to send them a message with photos and see what happens. those panels are expensive.
  14. Sep 1, 2024 at 5:54 PM
    wyldrr89
    wyldrr89 New Member
    2020 Silver 4Runner TRD OR
    did it work out for you
  15. Sep 1, 2024 at 8:26 PM
    Steve Berman
    Steve Berman New Member
    there is a YT video on this, it is a pita.
  16. Sep 1, 2024 at 8:41 PM
    wyldrr89
    wyldrr89 New Member
    Can you link it plz
  17. Sep 1, 2024 at 9:19 PM
    Steve Berman
