Gen 5 Custom Gear Shift Knob sources?
Discussion in 'General 4Runner Talk' started by Navajo, Apr 2, 2024.
  1. Apr 2, 2024 at 3:59 PM
    Navajo
    Navajo [OP] New Member
    5th Gen
    Icon Stage 7, BFG 285x17x70,Icon 6speed wheels, RSG Sliders, C4Fab Front Bumper, RCI armor, pedal commander, more to come!
    I want to replace my gear shift knobs on my Gen 5 with something like machined custom aluminum or metal gear shift type knobs. Any source recommendations would be appreciated.
  2. Apr 2, 2024 at 4:02 PM
    BobbyB
    Bob
    Marietta, GA
    2021 White TRD Off Road
    One design to consider is the FJ Cruiser shift knob that matches the transfer case knob on the TRD trims.
    Cheers,
    Bob
    Navajo[OP] likes this.
  3. Apr 2, 2024 at 4:26 PM
    Bought brand new 2016 After May 2021: -Approx 3" lift/level: Bilstein 5100's, OME 2884 590lb 3" front lift springs, SPC UCA's, ICON 158506 2" lift rear coils, diff drop -Mickey Thompson Baja ATZ LT285/70R17 Load E -Mickey Thompson Sidebiter ll 17x9, 0 offset, 5 backspace -Pro Comp black spline lugs ^installed by 4WheelParts^ -New brakes and rotors by brake shop -4-piece ARB skid kit -Smittybilt 2" nerf steps -MBRP black exhaust tip, chopped OEM -Drivers side OEM FJ oh shit handle -All blacked out emblems -Blacked out roof rails -4x WeatherTech window rain guards -OEM custom rear mud flap deletes -KICK BACK MUD FLAPS 12" WIDE - BLACK TOP AND BLACK WEIGHT -FRAM EXTRA GUARD CA10835 engine air filter -1797 LED tricolor fog bulbs Yellow 3000K White 6000K Blue 15000K 28W 4000LM -Armour paint lower rear bumper -Front bumper high stage high clearance cut -Fenders cut straight across, pink reservoir sprayed black -4Runner Lifestyle sequential fog fangs -4Runner Lifestyle smoked taillight decals -Pedal Commander -Rear passenger cargo mounted 120v truck tire pump -4x Spidertrax 1.25" black aluminum wheel spacers -Yota Twins Paracord Hatch Strap sand camo -Teton Workshop hard anodized matte black aluminum shift knob -Ditch flood lights 4 LED 20w 1400lm w/ OEM hood mounts on OEM style dash switch -Backup flood lights under bumper 6 LED 18w 1500lm on OEM style dash switch -Body Mount Chop; cut, weld, paint -Fender mount chop, re-weld, paint -Fender Liner cut behind wheel (I cut liner in front of wheel clean off at top of viper cut) -Wheel well firewall hammering, painting ^done by Arc One Industries^ -valance cap trim -Agency6 Black Shackle Block 2" US Certified 6061 T6 CNC machined aluminum -DRT fab universal hitch skid -ACDelco inner tie rods, outer tie rods, bellows -Full Dr. KDSS switch kit -March 31 Behind grille 13-1/4" 32 LED light bar + wide-angle, eagle-eye lens 6000lm on OEM style dash switch -RAA Powder coated steel roof rack cargo basket, 1" side rails, 64" x 39" x 6", 250lb limit -roof gas can, water can, shovel -PEAKTOW PTT0063 Hitch Mount Cargo Carrier 51-1/2 x 17-1/2 x 4 inches 500 lbs. Capacity (trips only) -July/2023: purchased first needed SPC balljoint replacement kit - newly released, upgraded non-zerk sealed joints 25002 -July 15/2023: The Original Universal EZ Flares, 1". All four corners -Dec. 2023: removed bumper cover and crash bar, drilled frame, installed Apex Overland KDSS Recovery Points -Jan. 2024: SPC balljoint replacement kit - upgraded non-zerk sealed joint design 25002 -Feb. 3/ 2024: 4x KC Wire Hiders, for roof rack lighting Feb. 13/2024: New ditch lights, on new Rago Fabrication Extension brackets. 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Replacing 3inch EVERGEAR clear lens ditch light pods w/ yellow lamix-x In progress: 4th, 5th, and 6th set of off road lights Electrical components and wiring purchased, not started -roof rack scene lighting - EVERGEAR ea. 1,350 lumens, 30w, 3-¾" round floods. Custom, side mounted w/ galvanized flat bar And -roof rack upper ditch lights - 3inch Quad Row Amber Pods from LED-Club. 32W 3200Lm 16-LED Spot Beam. Bar clamp mounted to front corners And -roof rack reverse amber pods / secondary hazard lights. 20W 2000Lm 2-LED Spot Beam. Bar clamp mounted to rear side And -roof rack F1 smoked chase light w/ lighting effects. Custom bolted to rear side -POR15 rust proofing line-up, 3-step process PAUSED until 70⁰ weather Bought, in the garage queue: -BlueFire 6-Circuit Fuse Block with LED Indicator & Protection Cover -Blue Sea Systems 100A Circuit Breaker w/ reset lever -Rust prevention •New can POR15, 2x Black Fluid Film, long spray nozzle attachments, 2x PB Surface Shield, 1x Chainwax •partially used POR15 Degreaser, Metal Prep Wanted - PerryParts or Wheelers bump stops, self fabricated limb risers (seasonal, removable), 1" body lift, powder coated center winch bumper w/ large bar (got no tss), rear steel bumper w/ tire carrier for an LT285 Kumho on steely, sliders, bolt on cat shields
  4. Apr 2, 2024 at 4:30 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    Just a caution: those metal gear shift knobs get hot in the desert sun.
    djwantke and 5thToy like this.
  5. Apr 2, 2024 at 7:30 PM
    5thToy
    5thToy New Member
    Northern Nevada
    2019 SR5P
    This, and extremely cold in the winter. Where I live it gets over 100 in the summer and single digits in the winter. My Ellis Precision is in a drawer out in the garage.
    Teton Workshop for the win.
  6. Apr 2, 2024 at 7:40 PM
    3JOH22A Toyota Gigolo
    RAV4 TRD knob https://www.ebay.com/itm/182055933629
    Lexus IS-F carbon fiber (mine 4Runner):
    Navajo[QUOTED][OP] likes this.
  7. Apr 2, 2024 at 8:09 PM
    Correct
    Good hack I’ve heard is to keep a hand towel or shirt in the truck to cover the knob while it’s parked
  8. Apr 4, 2024 at 12:27 PM
  9. Apr 4, 2024 at 12:29 PM
    314Runner
    314Runner New Member
    Chris
    23’ ORP
    I’m with Bob on this one. The FJ knob matches really well and won’t get scalding hot in the summer like a machined knob would.
    MeefZah and djwantke like this.
  10. Apr 11, 2024 at 6:46 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    2020 GX460
    Man I'd be fucking with that thing non-stop. I want one.
  11. Apr 11, 2024 at 6:54 AM
    Going to guns!
    Ironically you can get one of these for not much more than a set of Teton Workshop shifter knobs.
