Gear shifter bumped while driving.
Discussion in '5th Gen 4Runners (2010-2024)' started by QuocDat, Jun 18, 2024.
  1. Jun 18, 2024 at 11:50 PM
    QuocDat
    QuocDat [OP] New Member
    4runner
    Hi everyone.
    While i was on highway, one time, my dog bumped the shifter from d to n while in 2h. And the second time, a heavy object put on the arm rest flew forward and bumped the shifter from d to n because of a hard and sudden brake, it was in 2h. I feel like nothing bad happened but my OCD blood bug my mind too much. Have any of you experienced this before and in which case would damage the transfer case? I did many google search on this thread but not too much explain or information about these problems. Is it safe to switch from d to n while driving? I’m a newbie into these mechanic related no more than 3 years so have too little knowledge about how thing works. I’m appreciated all of your opinions in this topic. I just babysit my rig cause i want to use it for 30 more years. My rig is 2022 trd off road.
  2. Jun 19, 2024 at 3:39 AM
    MeefZah
    MeefZah ------------
    Lexington, Ohio
    GX460
    It's fine. The only conceivable issue has nothing to do with the transmission but would relate to the engine over revving if you maintained the same gas pedal position when the shift into neutral happened. Even that is unlikely as there is a rev limiter. Of all the things you could worry about I would put this somewhere on the bottom of the list.
  3. Jun 19, 2024 at 3:58 AM
    RUNNER4DAN
    Daniel
    Doesn't need any
    Yes your OCD bug is working overtime.
  4. Jun 19, 2024 at 4:52 AM
    jharkin
    jharkin New Member
    Jeremy
    Boston suburbs
    2023 Black Pro
    I wouldn’t put this on the list at all. Not only is there a rev limiter (which shuts off the fuel injectors at redline), being a drive by wire electronic throttle Toyota probably mapped the throttle pedal response in neutral to prevent overrevving to begin with.
    similarly the transmission has lockouts to prevent anything that could cause damage like going D to R while moving or downshifting too low in S mode. It’s pretty idiot proof, as most automatics have been since before I was born.
    TL/DR: There is nothing at all wrong with shifting from D to N back to D while driving.
    JChiz likes this.
  5. Jun 19, 2024 at 5:30 AM
    FN2187
    FN2187 Stormtrooper
    Earth
    2019 TRD ORP w/ KDSS
    If memory serves me correctly, shifting to N and depressing the brake pedal was recommended in the event of the Toyota stuck accelerator pedal fiasco some years ago so...
    I would say not only is it fine, but actually recommended by Toyota
  6. Jun 19, 2024 at 6:09 AM
    It’s fine and sounds like you should put stuff in the back.
    icebear, Trail Runnah and glwood54 like this.
  7. Jun 19, 2024 at 7:11 AM
    catbrown357
    catbrown357 New Member
    Tempe
    2011 Limited 4WD
    Your transmission is going to just fine. However, you should rethink where things are in the cabin when you're driving. Most people will never have this happen in a lifetime of driving, yet you seem to have it happen twice in a short period of time. Keep distractions and safety hazards out of the driver's area. For your sake, and all of the rest of us that share the roads with you.
  8. Jun 19, 2024 at 9:41 AM
    D to N is harmless. N to D while moving at highway speeds can cause a sudden jerk. So apply brakes and slow down a little (within reason if you're in traffic) when shifting from N to D.
    My shifter is usually in the S-mode gate, so it cannot be accidentally bumped to neutral.
    Stop putting unsecured heavy objects on your armrest :boink:
    TrailSpecial22 and RUNNER4DAN like this.
  9. Jun 19, 2024 at 12:00 PM
    QuocDat
    4runner
    Thank everyone. I will organize things in my truck.
  10. Jun 22, 2024 at 6:38 AM
    Grandpawmoses
    Grandpawmoses Dirty Old Man
    David
    2024 4R TRD Pro
    Too poor to buy anything now
    That happens everytime I have sex in my vehicle.
  11. Jun 22, 2024 at 6:49 AM
    Garlic
    Garlic New Member
    CO
    2024 TRD Off Road
    This happened to me in my 05 wrangler a few times, one time it wouldn’t engage drive again, needed to have it towed to the dealer. Everything was fine but something had disconnected.
