Gear Shift Plastic Insert Dislocated
Discussion in '5th Gen 4Runners (2010-2024)' started by ItsmeTee, Sep 1, 2021.
  1. Sep 1, 2021 at 5:26 PM
    ItsmeTee
    ItsmeTee [OP] New Member
    2015 Charcoal 4Runner
    Hello. For some reason the plastic insert underneath the gearshift has dislocated. This now causes the gearshift to not easily change from park to drive to reverse. Is there a way to fix or do I have take apart the whole thing? What would cause this to become loose?
    mrmike7189 likes this.
  2. Sep 1, 2021 at 5:43 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    It's super easy to take off.
    Unscrew the shift knob
    Pull towards the roof equally on both sides of the entire plastic piece
    Fix whatever is out of place
    Reverse order
    Profit
  3. Sep 1, 2021 at 6:19 PM
    Old goat
    Old goat Trout chaser
    Hudson Valley NY
    5th gen
    My 2015 was doing same thing...wound up being neutral safety switch. That plastic piece offers no resistance while shifting through the gears. I disassembled my console, lubed all points of contact, and it was still difficult to shift. There are several you tube videos on the subject. Hope this helps!
    mrmike7189 and ItsmeTee[OP] like this.
  4. Sep 2, 2021 at 9:11 AM
    ItsmeTee
    Thank you! I will try to remove the console also look at the neutral safety switch.
  5. Sep 3, 2021 at 6:42 PM
    BroRunner
    BroRunner New Member
    2015 4Runner Trail Edition
    First thing I did was unscrew the shifter and 4wd knobs. Then I pulled up on the main plastic cover/piece starting from the rear where you have the rear window switch (easiest to start from the cupholder side though). There are 2 clips in the rear. This offers a bit of resistance so some force is required.
    Once those popped I moved to the front and pulled up again and there are 2 clips there as well. Then carefully unplug the wiring harness for your rear window and heated seats (located passenger side closer to the rear of the vehicle).
    Pull the leather cover off the 4wd shifter shaft. Then remove the main plastic cover entirely. Once inside there are 2 more pieces of plastic to remove. These have little locking hook/tooth design. 4 of these per piece. Do not use force with these or they will break. If I recall the first piece was a black one to remove around the shifter, the second is a clear plastic piece that actually holds down the sliding shifter cover thing that you labeled in your picture.
    I removed mine the other day for unrelated reasons and cleaned that part. If you need I can post photos or video to help. It’s easier than it sounds, 2 minutes of work at most once you know what you’re doing.
  6. Sep 23, 2022 at 3:20 PM
    Juan2022
    Juan2022 New Member
    Juan
    RGV
    2022 4 Runner TRD Pro
    None
    My 2022 4 runner just started doing this, from park to reverse, hard to move either direction.
  7. Dec 20, 2022 at 4:10 PM
    mrmike7189
    mrmike7189 New Member
    mike
    2020 silver SR5 4x4
    My 2020 had same issue. Neutral Safety switch replaced under warranty. Must be a common defective part?
  8. Dec 20, 2022 at 4:11 PM
    mrmike7189
    mike
    2020 silver SR5 4x4
    Did this myself and lubed the shift linkage with WD40? shifts nicely now!:yes:
