Gear Oils
Discussion in '2nd Gen 4Runners (1990-1995)' started by trlhiker, Sep 24, 2020.
  1. Sep 24, 2020 at 10:24 AM
    trlhiker
    trlhiker [OP] Lazy Bum
    1992 4Runner SR5 V6 4X4
    I want to go ahead and change out the oils in my diffs and transfer case. I understand the transfer case gets tranny fluid and the diffs get gear oil. The manual shows 2 different types. 75W-90 for the front and 80W-90 for the rear. Can I put 80W-90 in the front and be fine? I cannot remember what I did last time I changed them out. Also can someone point out where the heck the fill port is on the front diff? I cannot find it.
  2. Sep 24, 2020 at 4:14 PM
    Front center almost. Up in there... I used the same Fluid for the front/center/rear. It’s runs SO good I enjoy every minute of it...
  3. Sep 24, 2020 at 6:20 PM
    trlhiker
    I looked in my manual and it says gear oil in transfer case if you have a manual or 4cyl but use Dexron II if 6cyl with auto. I wonder why?
  4. Sep 24, 2020 at 6:39 PM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    When I change the oil in the front and rear differentials I don’t get too concerned about the weight as long as it is GL-5 oil. I would have no problem using 80W-90 in the front and rear diff.
    trlhiker[OP] likes this.
  5. Sep 25, 2020 at 5:48 AM
    vfrpilot
    vfrpilot New Member
    1995 4Runner SR5
    I don't know if the transfer cases on manuals and autos are the same, but the biggest reason that you run Dexron in the auto transfer case is migration. If a seal goes out or leaks between the case and trans, you don't want gear oil mixing with the ATF. My guess is that there is a difference in the make up of the auto transfer case also so that the lubrication is sufficient with the ATF
  6. Sep 25, 2020 at 10:12 AM
    trlhiker
    Thanks all. Now does anyone know where that fill port is on the front diff? For the life of me, I cannot find it.
  7. Sep 25, 2020 at 10:21 AM
    Justthemechanic
    Nevada desert
    It’s on the front of the diff.
  8. Sep 25, 2020 at 12:31 PM
    trlhiker
    Thanks Just, I finally found it. Looks like the skid plate will have to come off. Boy that was nicely hidden.
  9. Sep 25, 2020 at 2:38 PM
    atgparker
    atgparker Cal Poly, ETME 1988
    Andrew
    Mission Viejo, CA
    1991 White 4Runner 3.0 L
    For what it is worth I have been putting 75W-140 Royal Purple gear oil in everything (there is no AT in my 4Runner). The additive package works a charm in the R150F 5 speed when its cold and is providing a quiet clicking in my Grizzly Locker. I haven't replaced the front axle lubrication yet but I would expect the ADD will like it!
