Gas smell in old oil + chunks = ???
Discussion in '5th Gen 4Runners (2010-2024)' started by Sleestaks, Oct 25, 2023.
  1. Oct 25, 2023 at 10:03 AM
    Sleestaks
    Sleestaks [OP] Shape-shifting Reptilian Alien
    2018 OR, Magnetic Gray
    Tires only
    Yeah, I know, another oil change question. But I don't drive my 4runner much, only 1 trip a week about 45 minutes hwy each way there and back. Otherwise it's short trips around town. So that's where I'm thinking the gas smell in the oil is coming from. I changed my oil at 6,500 miles @ 11 months. However, when I dumped the old oil, using a funnel with a strainer, I saw chunks of I don't know what [see pic].
    So anyone got any thoughts on the gas smell and these here chunks? :(IMG_1438.jpg
  2. Oct 25, 2023 at 10:13 AM
    Are the chunks metallic or soft? Any recent engine work?
  3. Oct 25, 2023 at 10:14 AM
    Sleestaks
    Tires only
    Seemed a little hard, but to tell you the truth I couldn't really tell through my gloves. No recent work.
  4. Oct 25, 2023 at 10:16 AM
    I was thinking RTV but not sure. Maybe send a sample to blackstone for testing but they don't really say what could be an issue though.
    Sleestaks[QUOTED][OP] likes this.
  5. Oct 25, 2023 at 10:16 AM
    Sleestaks
    Tires only
    What's RTV?
  6. Oct 25, 2023 at 10:20 AM
    Sleestaks
    Tires only
    Shit, I wasn't too concerned about it, but after a little looking around on the net, I'm a little worried that something may be amiss.
  7. Oct 25, 2023 at 10:25 AM
    RTV sealant. Sometimes it's used to seal parts together where a gasket isn't available or needed.
    All I can think of is a stuck injector putting too much fuel in a cylinder. However some combustion gasses do make into the oil normally which is why it gets dirty over time. It could really be nothing. Is the engine running weird?
  8. Oct 25, 2023 at 10:26 AM
    Sleestaks
    Tires only
    Nah, engine is running smooth. Like a said, short trips around town mostly. So I'm hoping it's just that I need to change my oil more frequently and the black chunks were just gunk and buildup or something.
  9. Oct 25, 2023 at 10:27 AM
    auspilot
    auspilot Old Member
    2020 TRD OR
    Dobs IMS, lots of small stuff
    Are you sure there wasn't something in your oil drain pan before you drained the oil into it?
    backpacker and 7Runner like this.
  10. Oct 25, 2023 at 10:38 AM
  11. Oct 25, 2023 at 10:40 AM
    scon36
    scon36 New Member
    Steve
    RTV stands for Room Temperature Vulcanization. It can be in the form of a silicone sealant. Think silcone caulk but for other applications.
  12. Oct 25, 2023 at 10:54 AM
    Daddykool
    You could also disassemble the filter if you still have it. If that's devoid of these chunks, then likely nothing harmful is getting to the engine.
    Rocko9999 and Sleestaks[OP] like this.
  13. Oct 25, 2023 at 10:59 AM
    Sleestaks
    Tires only
    Already got rid of the filter, but don't remember seeing anything in there. And no, the strainer in the funnel caught all of those chunks.
    Really really hoping that it's just buildup and gunk due to short trips and stuff not burning off and the fact that I didn't change my oil for 11 months -- did that because I only had 6,500 miles since last change.
  14. Oct 25, 2023 at 11:00 AM
    Sleestaks
    Tires only
    Yikes?? What are you thinking that could be? Something bad?
  15. Oct 25, 2023 at 11:05 AM
    Sleestaks
    Tires only
    Aw shit -- just realized that I used a new oil pan, one of those box kind that you can seal up with the screw lid and pour the old oil out of -- it's made of black plastic. I'm wondering if there were some bits of it inside from manufacturing. Occam's razor maybe??? :facepalm:
  16. Oct 25, 2023 at 11:42 AM
    No clue, sorry, just appears abnormal.
  17. Oct 25, 2023 at 11:51 AM
    Worrying about nothing.
    Sleestaks[OP] likes this.
  18. Oct 25, 2023 at 1:39 PM
    backpacker
    backpacker New Member
    2023 TRD ORP
    In that case, those could be some of the waste from drilling the holes where the oil enters the pan. I noticed some of those still slightly attached on mine before the first time I used it.
  19. Oct 25, 2023 at 6:42 PM
    Doh! Lol. Yeah, never strain the dregs of a oil drain pan, unless you need to feel anxiety. Next time, if you need to strain oil to check on a vehicle, do it with oil that is draining directly from the engine oil pan. Or into a clean sample container. But I wouldn’t even bother with that, I’d inspect the oil filter pleats instead.
