Gas door/hood release mount under dash
Discussion in '4th Gen 4Runners (2003-2009)' started by Jennifer, Jul 23, 2023.
  1. Jul 23, 2023 at 3:01 PM
    Jennifer
    Jennifer [OP] New Member
    Just brought my little princess her first car. 04 4Runner. I had to replace the brake accumulator motor. Unfortunately for me, when I was putting the under dash panel, under the steering column back on and the gas door/hood release cable assemblies were in, in such a manner so that the cables were hanging down, I noticed that the lower panel under the steering column had broken off, the mount to some, I'm guessing, metal assembly.
    Question; I don't suppose anyone here has any 'good' photos up under the drivers dash (looking up) so I can see what the mount just behind the hood release/gas door cable mounts looks like?
  2. Jul 23, 2023 at 4:28 PM
    xtremewlr
    xtremewlr New Member
    Todd
    Tucson, AZ
    2003 4Runner V8 Limited 4WD
    Lots with more in the works
    You can just use a zip-tie to get them tucked under the dash, instead of trying to replace the part they clip into. This is what I did with mine. Just make sure they aren't binding when you do it.
  3. Jul 24, 2023 at 3:02 PM
    Jennifer
    that's what I wound up doin!
    xtremewlr likes this.
