Fuel pump noise.. Good or Bad ?
Discussion in '3rd Gen 4Runners (1996-2002)' started by Hank69, Feb 14, 2023.
  1. Feb 14, 2023 at 10:40 AM
    Hank69
    Hank69 [OP] New Member
    Hank
    2002 Blurple 4runner
    Thanks for reading.
    I have no idea what the fuel pump sounded like or if it any made any noise at all when it was new, however I can hear it quite well when I start up, and also intermittently while I'm driving.
    I have had other vehicles with electric fuel pumps and don't really remember hearing the fuel pump.. or if I did, I really had to listen for it.
    So, is this something I should be concerned about, or is this normal.?
  2. Feb 15, 2023 at 7:50 AM
    Toyota fuel pumps are really strong but after 20 years, it could go out. I replaced mine when I got an evap code and I replaced all those parts on the tank as well.
  3. Feb 24, 2023 at 1:16 AM
    Hank69
    Hank
    Thank you!!!!
  4. Feb 25, 2023 at 12:18 PM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    I've owned only 2 FI 4Runners, a first gen 87, and a 3rd gen 99. Both of them I could hear the fuel pump quite clearly if I turned the key to start without engaging the clutch or the Clutch Cancel switch. Not obnoxiously loud, but clearly hearable.
    I believe it's just the way the fuel pumps are. Maybe something about the fuel tank's acoustics, but in any event, no trouble hearing it at all.
    Have fun!
    Pat☺
    Hank69[OP] likes this.
  5. Feb 26, 2023 at 8:18 AM
    Hank69
    Hank
    Thank you ..!
