Fuel leak I can not solve
Discussion in '2nd Gen 4Runners (1990-1995)' started by Taboot22, Dec 26, 2021.
  1. Dec 26, 2021 at 8:02 AM
    Taboot22
    Taboot22 [OP] New Member
    Will
    1994 grey 4runner
    Ride leveler w/2" lift. 33" BFG all terrain
    Hi,
    My name is Will and I'm new to the forum. I have a 94 w/ the 3.0 and it has a bad fuel leak. I have replaced the injectors with all new o-rings and seals. New o-rings in the injector cups. The fuel leak continues. Here's the funny part, the leak only happens when the truck is running. The fuel pours off the back of the engine on the passenger side. It started slowly and has progressively gotten worse. I stopped driving the truck and am at a loss as to where this leak can be coming from. Any help is greatly appreciated.
    Peace
  2. Dec 26, 2021 at 9:35 AM
    trlhiker
    trlhiker Lazy Bum
    1992 4Runner SR5 V6 4X4
    The only way you are going to find it is to either trace the fuel or and use a strong flashlight and inspection mirror. Good luck.
  3. Dec 26, 2021 at 9:56 AM
    Justthemechanic
    Justthemechanic New Member
    Nevada desert
    94 4Runner SR5, 5 speed, 3.0
    OME 2” lift, BudBuilt armor, RRO sliders, Spartan rear locker
    Look at the fuel pulsation damper, it screws into the back of the right side fuel rail. You can see it with a flashlight and mirror. Search the Google and there are pictures and videos of the damper.
    Taboot22[OP] likes this.
  4. Dec 26, 2021 at 10:37 AM
    yotagreg8888
    yotagreg8888 New Member
    Greg
    1985 SR5
    OME lift other wise 100 percent stock
    I agree with above post I don't have the 3.slow. I have the slower 22RE but it also has a fuel pulsation damper and it grew a leak. Get OEM.
  5. Jan 2, 2022 at 9:57 AM
    Taboot22
    Will
    1994 grey 4runner
    The problem was the fuel pressure pulsation regulator. The diaphragm had split and was the source of the leak. The truck runs great with the new 4-hole injectors and the check engine light is gone after replacing the bi-metal valve and finding a vaccine line on the back of the power steering pump unplugged. A shout-out to Greg and Tyler at Toyota West in Columbus Ohio for helping assure we ordered the correct parts. It's so nice to have my truck back.
