Fuel filter change
Discussion in '3rd Gen 4Runners (1996-2002)' started by Orchemo, Sep 11, 2020.
  1. Sep 11, 2020 at 8:09 AM
    Orchemo
    Orchemo [OP] New Member
    Going to change my fuel filter, 220K, just because of high miles.
    Factory or aftermarket?
  2. Sep 11, 2020 at 8:45 AM
    Clutchplate
    Clutchplate New Member
    96 4runner 3.4 Liter
    Factory
    canadian.bacon, Toy4X4 and negusm like this.
  3. Sep 11, 2020 at 10:26 AM
    Orchemo
    That is where I was going too. I assume it is the original now, so the replacement is a one time purchase, so why not used what has worked.
    Toy4X4 likes this.
  4. Sep 11, 2020 at 10:36 AM
    Not just "what has worked". What has worked for over two hundred THOUSAND miles. So yeah, go with TOYOTA.
  5. Dec 3, 2020 at 11:33 AM
    gretzky2857
    gretzky2857 New Member
    2002 4Runner
  6. Sep 30, 2021 at 10:16 PM
    sarmad
    sarmad New Member
    sarmad
    4 runner SR5 PREMUIM 2020
    Hello . Is this fuel filer same PN for the SRF 2020 and where is the filter location exactly in the car i searched could not find it.my car VIN:JTEBU5JR0L5787803
  7. Oct 1, 2021 at 11:27 AM
    PhantomTweak
    PhantomTweak New Member
    Patrick
    OREGON
    1999 4Runner, bone stock
    Definitely go with OEM. Look at long the factory installed one lasted. I want another that can do that!
    Good luck, whatever you decide.
    Pat☺
    sarmad likes this.
  8. Oct 2, 2021 at 6:38 PM
    No. Not even close.
    I am pretty sure your car has a fuel filter sock attached to the fuel pump in the tank. You probably have to drop the tank to change it.
    You don't have to worry about that for a decade or so.
    sarmad[QUOTED] likes this.
  9. Oct 2, 2021 at 8:11 PM
    Just make sure you tighten the line nuts good. I “snugged” mine down, but realized it had a little leak right away. So gave just a little more torque to the flare nuts (guess that’s what they are) and good to go.
    sarmad likes this.
  10. Oct 3, 2021 at 12:00 PM
    PhantomTweak
    Patrick
    OREGON
    Don't forget to never, EVER, reuse the crush washers.
    No matter how good they look, how long they've been installed, nothing. If you've touched the crush washer with the banjo bolt, and need to remove it, for any reason, throw it away. Don't put it back on.
    It's a good idea to get several of whatever size crush washers you need for a job. Like the fuel filter. It takes 2. I would get 6 new washers. The cold start injector takes 2 different sizes, so I get 4 each.
    I always get OEM washers from Toyota. They're not very expensive at all, and are well worth the price.
    I also always start by torquing to the FSM spec'ed value. Then, if needed, I can snug them down due to a small leakage. Just don't over-do it. If you have to really honk down to get the leak stopped, just replace it. Better to do that than strip the banjo bolt threads. It's easy enough to pressurize the system to test for leaks, too. Just use the test jumper to fire up the fuel pump. Maybe a poor choice of words, there, but you get the idea.
    Remember, also, that they are both magical, and malicious. If you have one washer left for a job, it will leap, yes LEAP like a kangaroo, from your hand, bounce around like it's in a pachinko machine for a while, then, instead of landing on the ground, it will vanish. Literally vanish. You might HEAR it hit the ground, but it will be gone. Nowhere to be found. Thus, you can't finish the job, until you get more washers. Malicious.
    Good fortune, and have fun!
    Pat☺
  11. Oct 3, 2021 at 6:50 PM
    Just changed mine today. Easy peasy. Just use two line wrenches, one on the filter and one on the line. Crack them loose before you loosen the bracket. Enjoy the fuel shower.
    Also swapped in a new TOYOTA rack. That was NOT easy peasy.
  12. Oct 4, 2021 at 11:55 AM
    PhantomTweak
    Patrick
    OREGON
    I think, to prevent that, you can pull a fuse that runs the fuel pump while the truck is running, and wait for it to die of fuel starvation. I don't remember which fuse it is right off the top of my head, but it sounds reasonable to me.
    Let the truck drain out it's fuel lines for you, ta-da! No shower. Say thank you to your truck, don't forget. They can get tempramental if not treated "right" after all.
    Much like women. I hope my lovely wife doesn't see this post...
    Just wait till you go to change the fuel filter on a first gen 4Runner! Mounted on the block, up under the intake manifold. Mounted backwards, too. The front hose is from the tank, the rear hose goes to the engine. Weird way to do it. 2 bolts, and the top one is virtually impossible to see, or reach. Even with the access hatch in the wheel well removed.
    And then, if it leaks...many many bad names and dirty words indeed.
    I am SO glad they designed the filter to last a good long time.
    I always change the fuel filter if I have the intake off for ANY reason. It makes it easier by far. Not really easy, per se, but easier, at least.
    Have fun!
    Pat☺
    sarmad likes this.
  13. Oct 5, 2021 at 10:32 AM
    ...and not have a free fuel shower? NEVER!
  14. Oct 5, 2021 at 12:15 PM
    PhantomTweak
    Patrick
    OREGON
    Oh! I didn't realize that you WANTED a free fuel shower. I apologize :D
    You REALLY want a good fuel shower, pull the fuel lines off the fuel filter on a 1st gen, 2wd, longbed, pickup. The one on the frame rail, just aft of the wheel well. Without clamping them off with the vice-grips made for that sort of thing. <Ahem>
    Not that that ever happened to *me*. Not more than once anywho... :tinfoilhat: :(
    Have fun getting your fuel showers! They always make me nauseous...
    Pat☺
    sarmad likes this.
  15. Oct 9, 2021 at 6:30 AM
    sarmad
    sarmad New Member
    sarmad
    but the filter location still not clear for me .
  16. Oct 9, 2021 at 6:38 AM
    Because you don't have one like on our older cars.
    From what I can see, on your 2020, the only filter is just a sock style filter inside the gas tank. You need to drop the gas tank to replace it.
    You should not have to worry about it on a 2020 until probably 2030.
  17. Oct 13, 2021 at 12:49 PM
    Trekker
    Trekker Regular Member
    1997 3rz 5spd
    The 3rz-fe 4runner has its fuel filter under the intake manifold and is a huge PITA to change. The 5vz-fe has its filter easily accessible under an often missing plastic shield that runs along the frame on the driver side. Just an FYI
  18. Jun 30, 2022 at 9:42 PM
    sarmad
    sarmad New Member
    sarmad
    I need your suggestions for how long time i should change it and what is the filter P.N or any suggested brand we can use if not toyota .
  19. Jul 1, 2022 at 6:38 AM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    You are in a section meant for a different generation 4Runner.
    You realize that right?
    You're asking about parts you don't even have.
  20. Jul 1, 2022 at 12:50 PM
    sarmad
    sarmad New Member
    sarmad
    I asking for SR5 not other model and for the time required to change the filter i think this standard
  21. Jul 1, 2022 at 3:10 PM
    Kwikvette
    Kwikvette Kwik Fab
    Multiple
    I'll rephrase since I didn't make it obvious enough.
    You are in the wrong section, generation wise.
    Your 4Runner has a completely different powertrain than the vehicle in discussion.
    You have a 2020; the topic of discussion applies to 1996-02.
    Your 2020 has an internal sock-style filter that is non-serviceable; it is located inside the fuel tank.
    1996-02 variants have a fuel filter that can be replaced, and location is based on the engine type whether it's the 5VZ or 3RZ.
    Do you understand now?
  22. Aug 26, 2022 at 1:29 AM
    sarmad
    sarmad New Member
    sarmad
    Thanks no need this tough way to answer
    Hank69 likes this.
  23. May 27, 2023 at 1:14 PM
    MotorWestPerformance
    MotorWestPerformance MotorWest Performance, Inc.
    Martin
    Chatsworth, CA
  24. May 28, 2023 at 9:33 AM
    Nighthawk
    Nighthawk New Member
    2001 4Runner
    Hi, (I’m new here). Replaced my original fuel filter awhile back with an aftermarket fram g6680 easy and no problems. After about 10 years I thought I would be a good 4-Runner owner and replace it again (with the same brand). Leaked like a sieve on startup, after tightening more to no avail, I reinstalled the old filter, and no leak. Jammed in one of the inside box flaps of the new filter was a tiny Ziploc, with two rubber and two metal washers “ don’t remember any in the previous one” and no instructions on orientation in or on the box or at their website. After a number YouTube videos not even mentioning them, I’m going to recommend you spend the extra $ and go with OEM. Not worth the headache in this situation.
  25. May 28, 2023 at 1:44 PM
    PhantomTweak
    Patrick
    OREGON
    Best choice is always OEM. No question.
    Not to mention always, ALWAYS replace the crush washers with new ones. The metal washers. Sounds like Fram was nice enough to include two metal crush washers for you. If not, get some from Toyota. Never reuse crush washers. It's a good idea to have a number of spare crush washers for ANY project. Why? Look at how many times you removed and replaced the filter. You SHOULD have used new washers every single time you removed and replaced the filter. Doesn't sound like you did, but you SHOULD have.
    All the fuel systems' crush washers should be replaced with new any time they're removed for any reason. That's why you should get a few of any crush washers you might encounter in any fuel system project. And NO, they are NOT all the same. I won't even swear the two on the fuel filter are the same, although I may be wrong on that. It's been a LONG time since I replaced the filter on my 87 4Runner which I sold a couple of years ago.
    I wish you all the best!
    Pat☺
