Front wheels rubbing @ full lock. 2020 4R
Discussion in 'New Member Introductions' started by VA Overland, Jul 15, 2022.
  1. Jul 15, 2022 at 4:46 PM
    VA Overland
    VA Overland [OP] New Member
    2020 4R Venture
    None yet
    Installed this set up:
    Bilstein 6112 front
    Bilstein 5160 rear
    1.25” wheel spacers
    UCAs
    275/70R17 Wildpeaks
    On stock TRD wheels, and I have rubbing on the front body mount and fender liner. I didn’t go with the 285s as I read with the 275s they would clear without issues. It appears I did something incorrect on the install to be the only 4R owner that rubs after lift and 275s.
    Any advise on what I did incorrect would be great, or I’ll trim the mount and figure out how to suck the rear fender liner in to stop rubbing.
    Maybe to wide of wheel spacer?4A0FFAC3-0AAD-4443-8F21-5A7F585131B8.jpg259BA556-C252-4625-BAA6-447F915BC8A1.jpg
  2. Jul 15, 2022 at 4:57 PM
    ESCT4R
    ESCT4R New Member
    2022 TRD ORP
    275's shouldn't require any trimming.... it's odd, but I have seen someone else on here with that same issue. Did they do an alignment?
  3. Jul 15, 2022 at 5:03 PM
    LaHh
    LaHh New Member
    Have you done your alignment? Caster plays a huge role.
  4. Jul 15, 2022 at 5:04 PM
    That is very odd. I run 285 wildpeak as well and no issues. If I have to make a guess is the wheel spacers are not right and then the UCA is sticking out too much. Definitely re-install in my opinion.
  5. Jul 15, 2022 at 5:08 PM
    VA Overland
    2020 4R Venture
    None yet
    Alignment was done and rolls straight and true, no shimmy. Going to pull the spacers and re-install wheels and see if that is the issue.
    SlvrSlug likes this.
  6. Jul 16, 2022 at 4:28 AM
    ZackDanger
    ZackDanger New Member
    Western MA
    My guess is that it’s 100% the wheel spacers.
    By pushing the wheels out, you’ve increased the radius of their turning arc.
    (the analogy I use is imagine standing in a closet holding a pie pan close to your chest… now hold it out and spin in place… at a certain point even if you fit before, you’ll start knocking into things)
    Take them off and see what happens.
    nimby and Thatbassguy like this.
  7. Jul 16, 2022 at 4:51 AM
    It's the spacers.
    But, the alignment could be a part of it, also. What are your alignment specs?
    nimby likes this.
  8. Jul 16, 2022 at 6:47 AM
    It's the wheel spacers and your alignment, like @Thatbassguy said.
    You need to do a few things to make a larger tire with that much wheel offset fit.
    Have you done the fender liner mod? It's not clear in your post. Thats where you push the fender liner in front of the tire forward and do a small trim on the fender flare.
    After the fender liner mod is done, then get an alignment where you push your caster forward as far as it will go. If you can get your caster around the +4 degree area, you will push your tire forward in the wheel just enough to stop rubbing on the body mount. And if you do the fender liner mod, you will not rub after pushing your tire forward because you already addressed that area.
    You should be good to go after that.
    ZackDanger and Thatbassguy like this.
  9. Jul 16, 2022 at 8:11 AM
    VA Overland
    2020 4R Venture
    None yet
    Removed spacers, problem solved. Lesson learned. Easy fix.
    Thatbassguy, ChessGuy and Mtbpsych like this.
  10. Jul 17, 2022 at 7:53 PM
    Spidertrax spacers?
    Wanna sell them to me?
    Thatbassguy and SlvrSlug like this.
